Preventative lubing of Campy Mirage levers?
Recreational Road Cyclist
Quoted: 255 Post(s)
Liked 252 Times
I am doing some maintenance on a little-used 1999 Bianchi Sen Remo 9sp, equipped with Campy Mirage levers. Will be replacing the original shift & brake cables & housings. The levers seem to shift okay, maybe a bit stiffly. I have read here at BF of riders dousing the innards of shift levers with PB Blaster or similar to lube and restore shift/brake levers.
In general, I believe that if it ain't broke, don't fix it, but would it be useful to squirt a little lube into these levers while the cables are out and bar tape off? I understand that Campy levers can be disassembled, but that's not on the menu.
Thanks for your thoughts.
Quoted: 4195 Post(s)
Liked 3,837 Times
PB Blaster is not a lube, it will help degrade any current lube however. Adding a drop or three of suitable oil to the shift pod internals is a good idea. Campy has had a few lube ports molded into some versions of their Ergo levers, one form the inside face and one form above, both under the body hood. I use Phil, FL Wet and Chain L for this once a year, or so. I would not inject thick grease or use thin penetrants. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1815 Post(s)
Liked 1,693 Times
Campagnolo shifters don't usually fail because of grease that has thickened with age, at least mine haven't. Rather, what fails is the g-springs or the spring carrier. A few drops of oil can't hurt but a flush could actually make things worse
Quoted: 255 Post(s)
Liked 252 Times
Thanks for waving me off the flush.
