epic fails in bike mfg
Old 07-14-15, 11:12 PM
rdtindsm
Ran over my road bike a month ago – forgot it was leaning against the passenger side of the car. But the good news is that BD was having a sale on full Ultegra Kestral Evoke.
Within the first couple of rides, I started hearing a noise that sounded a little like my shoe brushing the crank, but it wasn’t. Tried different shoes and pedals; sound still there. The bike has a bb30 crank on it and research indicated these bb’s are prone to noise.
So I took the crank off and realized that I wasn’t familiar enough with the system to want to take the bearings out. Left that for the ace mechanic at local bike shop to do since I had already made an appointment to take the bike in.
He pulled the bearings (actually adapters to a 24mm spindle), greased things, and put things back together while asking me if I had any extra washers. No, I had paid particular attention to what I was disassembling. But there was a gap between the crank and the bottom bracket – he had to put spacers in Evidently, Kestral spaced the bottom bracket by only pressing it in part way and it was the unsupported bb that was making the noise. I had noticed the bearing projecting, but had no experience with bb30.
Ok, $!-!i+ happens, but I’ve worked assembly and process are closely control. No way people should have been taken that type of shortcut. To my way of thinking, that was a major fail. I am defining a major fail as being systematic and repeated.
Examples:
Way back when, one of the gang got access to frames by Witcomb. They were evidently moving some production to the US from England where they were a respected brand. The price was very attractive, about 50% normal retail. 5 were ordered.
Every frame had a little raised blip opposite a braze on for water bottle cages where somebody had been ham handed with the drill press.
Reynolds made fork blades in two style: one that had a constant taper, and one that had a small step in the middle. One of the bikes had a fork with one of each. My frame eventually broke at the down tube / head tube lug because the brazing hadn’t penetrated that deeply.
Back during the bike boom of the mid 70’s I tried to open a shop. There were many problems with the venture which I won’t detail, but one was bikes were hard to come by. One practically had to order a container to assure stock and there were many odd bikes trying to fill the demand.
One was a bike called a Cazenave which was actually listed as a ‘Best Buy” by one of the consumer mags. It was a typically equipped French bike with Simplex ders, CLB Mafac clone brakes, and an orange peel paint job. Gearing was the typical 52/42 coupled with a 14/28 fw. More than you may want to know, but significant to the story.
The chain stays were half domed at the freewheel end. Unfortunately, there wasn’t clearance to the 14 t cog which rubbed. They corrected this by putting a thick washer on the axle. This threw the chain line off, so the bike was more than just prone to dropping the chain on downshifts to the small chainring. The situation could be improved, but not full corrected, by loosing the cotter pin and moving the chain ring inboard as allowed. I had occasion to open up the bb and found they all had sand in them.
What horror stories to you have? Looking for systemic problems that left the factory. Lambert / Viscount is too easy to qualify.
rdtindsm is offline
Old 07-15-15, 12:47 AM
TrojanHorse
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Quoted: 1107 Post(s)
Liked 64 Times in 47 Posts
LOL, bikes direct assembly issues.
TrojanHorse is offline
Old 07-15-15, 02:23 AM
Wingsprint
Quoted: 5 Post(s)
Is this seat taken? Mind if I join you? This should be a great show!
Wingsprint is offline
Old 07-15-15, 04:44 AM
rms13
Quoted: 276 Post(s)
Liked 6 Times in 3 Posts
LOL, BD having a sale
rms13 is offline
Old 07-15-15, 05:08 AM
Rowan
Quoted: 1454 Post(s)
Liked 85 Times in 40 Posts
This from a guy who ran over his bike.
Rocks and glass houses...
Rowan is offline
Old 07-15-15, 06:58 AM
therhodeo
Quoted: 63 Post(s)
Assumed this was a Trek thread.
therhodeo is offline
Old 07-15-15, 07:23 AM
PepeM
PepeM's Avatar
Quoted: 2739 Post(s)
Liked 119 Times in 59 Posts
When? Missed the last one.
PepeM is offline
Old 07-15-15, 07:41 AM
dippitydoo
inpd bout to roll up here with "STOP BASHING BIKES DIRECT..... halo bikes suck"
dippitydoo is offline
Old 07-15-15, 07:46 AM
bt
I once bought a used frame that the previous owner ran over.
bt is offline
Old 07-15-15, 07:50 AM
dr_lha
Bikes: 2016 Black Mountain Cycles Monster Cross v5, 2015 Ritchey Road Logic, 1998 Specialized Rockhopper, 2017 Raleigh Grand Prix
Quoted: 374 Post(s)
Liked 15 Times in 11 Posts
Yes, if you buy a cheap bike in a box with a BB30 you're destined for trouble, at least, that was my experience when my BB30 BB failed after 150 miles of riding. Luckily with a bit of loctite and some $20 bearings, everything is fixed up and working now.
dr_lha is offline
Old 07-15-15, 08:30 AM
TrojanHorse
SuperGimp
Also LOL at "Kestrel" doing anything. Forgot that one earlier.
Old 07-15-15, 08:34 AM
RPK79
Custom User Title
RPK79's Avatar
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times in 14 Posts
With your sample size of one you don't know if it was systematic and repeated.
RPK79 is offline
Old 07-15-15, 08:44 AM
Clipped_in
Rubber side down
Clipped_in's Avatar
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times in 105 Posts
Another crabon bike asplodes!!!
Clipped_in is offline
Old 07-15-15, 10:17 AM
Yellowbeard
Yellowbeard's Avatar
Quoted: 12 Post(s)
Most of the V-brake-equipped Treks I assemble come with the front brake pads on backwards.
Yellowbeard is offline
Old 07-15-15, 10:39 AM
thump55
I got 99 problems....
thump55's Avatar
Location: Does anyone know where the love of God goes, when the waves turn the minutes to hours?
Liked 3 Times in 2 Posts
Does this mean ISO:9001 is not working? Holy crap.
thump55 is offline
Old 07-15-15, 11:04 AM
BoSoxYacht
BoSoxYacht's Avatar
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
I see many road bikes with SRAM components.
Epic Manufacturing Fail.
BoSoxYacht is offline
Old 07-15-15, 11:20 AM
bt
I'm starting to see some road bikes with mountain type disc brakes.
bt is offline
Old 07-15-15, 11:24 AM
andr0id
andr0id's Avatar
Quoted: 1422 Post(s)
Liked 7 Times in 5 Posts
I'll gladly play the part of the BB30/press fit bottom bracket hater. I won't even have to act.
andr0id is offline
Old 07-15-15, 01:14 PM
PiLigand
Climbing: Ropes or Wheels
PiLigand's Avatar
Bikes: 2012 Scott Foil 30, Homebrew Windsor Fens Build, 2015 Fuji Touring, 1980 Univega
Boom! Shots fired. That hurt, man!
PiLigand is offline
yannisg
Bicycle Mechanics
11
06-09-16 12:49 AM
rocdoc
Bicycle Mechanics
7
05-28-15 03:09 PM
eragon
Touring
3
06-04-12 05:15 PM
hkboy313
Bicycle Mechanics
3
05-31-11 07:53 AM
gadabout007
Bicycle Mechanics
3
05-14-11 03:53 PM
