Tuebeless vs tubes with sealant inside
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
I didn't want to hijack the similarly-named thread, so I am starting this one.
I've read a few recommendations (eg Rene Herse website) that suggest putting sealant inside a conventional butyl inner-tube, if the tube has a removable valve core that would make this possible. The idea is to have some of the puncture protection without the problems that some tires (eg Rene Herse) seem to have when running tubeless.
Does anyone do this? Are there any obvious down-sides? Does it actually help at all with punctures (like enough to enable someone to finish a ride home without having to change out a tube)? I don't expect miracles, but would it work less well sealing a puncture than simply running tubeless?
TIA
TIA
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
I’ve tried sealant in clinchers a couple of times without success. Interested to hear others experiences.
Liked 3,443 Times
Quoted: 167 Post(s)
Liked 92 Times
Yes, tubed clinchers. I have used Continental Revo and CaffeLatex in rear tubed clincher tires. I think I have had 2 flats and the sealants came close to sealing but not quite. I think the secret is stopping soon enough after running over debris to make sure you remove it so that the sealant can work. Last puncture I continued to ride and the tire softened, but I thought it was going to seal. When I stopped, I found a 1/2" piece of wire, and when I removed it, the tube was toast.
So, I cannot conclude that sealant has helped me. I suppose there is the possibility that it has sealed some minor punctures without my knowing it.
I do continue to use the Effetto Mariposa CaffeLatex in my butyl sewup tires. With sewups, using sealant and carrying a folded tubular is all you've got.
Likes For gkamieneski:
Quoted: 6196 Post(s)
Liked 4,811 Times
I'd just go completely tubeless if I was to consider that. You'll likely get all the con's and not enough if any of the pro's.
Liked 3,443 Times
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
Quoted: 1461 Post(s)
Liked 1,486 Times
If you're having a lot of problems with flats, I suppose it's worth a try.
Likes For msu2001la:
Quoted: 1400 Post(s)
Liked 1,885 Times
sealant in tubes is pretty much standard operating practice for off road motorcycles
also common with garden and farm tractors
Likes For t2p:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Edit: There is a thread that seems to mention a sealant that is meant to be used with tubes. https://www.bikeforums.net/bicycle-m...l-sealant.html
It's like riding a bicycle
Likes For urbanknight:
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
20 or so years ago a friend tried the tubes with sealant inside. He got a puncture in the rear tire and it was a hoot to see the thing ejaculating as it spun around. Bunch of it ended up on his jersey, IIRC.
Quoted: 680 Post(s)
Liked 949 Times
the biggest problem is PSI. lower psi tires say below 50 psi the sealants can work. but at 70 PSI it was more miss then hit once in awhile it would work. I Tried several of them. but the higher psi just would blow the sealant out. also you have to be able too find what's in your tire for it to seal often it was flush with the tire and I could not find it. on my 50 psi tire with flat out it has caught several punctures and now after 3000 miles I have not had to add air to the tire in am onto. usually its 1 to 2 weeks I lose 5 or so PSI
Likes For fooferdoggie:
Quoted: 431 Post(s)
Liked 460 Times
Agree; I've done this with my 38-42mm gravel tires (40psi) and it worked ok, enough to get me home on a couple of occasions. On mountain bikes, 26x2.1" at 30-35psi, they work fine. Never really tried it on 23-25mm slicks. Skeptical of the higher pressure and lower volume, and also the extra few grams on the road bike.
Likes For tFUnK:
Quoted: 741 Post(s)
Liked 412 Times
Muc Off Inner Tube Sealent
I have used it. It has sealed small punctures. It supposed to last the life of the tube, whatever that means. I ride at 70 psi on one bike 60 psi on the other.
Likes For colnago62:
Quoted: 4409 Post(s)
Liked 1,566 Times
Seems like you'd have to quantify how well tubeless works in high psi road tires before you can compare the success of self-sealing tubes to them. I've certainly mounted an awful lot of new tubeless tires after the original would not seal after a puncture.
And then you have the problem of quantifying punctures you don't know about because they sealed immediately.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Liked 1,566 Times
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times
Putting sealant in a butyl tube will work to an extent, but puncture resistance would be better if a TPU tube were used. TPU is much more elastic in the first place, but also does not tear like butyl (or latex, for that matter) so the resistance to various tire intrusions is better.
TPU is also much lighter, so feel would be improved, too.
Also, I don’t think it’s accurate to indict Herse tires generally as being problematic for tubeless. The Extralight casing is because the sidewalls are barely coated in rubber, but the Standard casing sets up tubeless fine, and I’m certain the Endurance casing does, too.
I’ve run both Extralight and Standard tubeless, so those comments are based on my experience as well as understanding tire construction.
Quoted: 3955 Post(s)
Liked 7,303 Times
Liked 1,566 Times
Given that they work with normal rims and tubes, can be filled with sealant away from the tires and are easier to change a flat on the road - what's the downside? I don't want to deal with sealant at all, but if I was doing some sort of big tour I would consider putting some in my tubes.
Likes For Kontact:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I've used sealant in tubular tires and it works great so it would probably work in clinchers but I've not tried.
Likes For Germany_chris:
