Shimano RX100 question
Old 02-12-07, 09:47 AM
HereNT
無くなった
HereNT's Avatar
Bikes: I built the Bianchi track bike back up today.
I just picked up a set of these brakes at a swap meet yesterday for 15$. But it looks like there are pieces missing. The threaded part that goes through the fork and bridge doesn't have anything there.
Where would I find the pieces for this? I have a new Kona Paddy Wagon frame that's going to be here in a week, and I kind of want to be able to use brakes on it from the start. Would the LBS that's going to be building the bike probably have these?
Thanks for any help.
HereNT is offline
Old 02-12-07, 01:09 PM
Al1943
Liked 7 Times in 6 Posts
A well equipped LBS should have what you need.
Al1943 is offline
Old 02-12-07, 01:11 PM
Steev
Steev's Avatar
Are you saying the mounting bolt is missing or that there's no nut on the bolt?
If the bolt is missing, I think you're out of luck, if it's just the retainer then you should be able to get them at any LBS as some forks require longer recessed bolts than come standard. I would guess that the Paddy Wagon would use recessed bolts.
Perhaps you can post a picture so we can better answer.
Steev is offline
Old 02-12-07, 01:32 PM
HereNT
無くなった
HereNT's Avatar
The bolts are there, just there's no nuts on the bolts. Like this:
I'm guessing that's not an uncommon part, so I'll be fine giving these to the LBS to put on the frame? This is the stock one on the bike that I test rode, it looks pretty similar...
HereNT is offline
Old 02-12-07, 02:35 PM
Treefox
Young and unconcerned
Treefox's Avatar
Bikes: Yeah, I got a few.
Yeah, you should be fine.
Treefox is offline
