Bottom Bracket Maintenance?
Been riding less due to work hours, so only get out on the weekends. I have noticied that the first few minutes of riding if I put the bike under load, the bottom bracket seems to "grind" a little bit. This goes away after a mile or so.
The bike has 4,000 miles on it and I have never done anything to service the bottom bracket. Should I be dong something about this?
Depends on the BB. If it's sealed, there's not much you can do besides replace it. If it service-able, then dis-assemble, clean and re-grease. Check for play also...another indicator that it's wearing out.
Is it possible that it's one of your pedals?
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
what BB do you have? Riding in rain and/or dusty conditions?
I would probably re-grease the BB if it's been 4,000 miles. However, like mentioned above, you could have a sealed BB, which isn't serviceable. If that's the case, then I would leave it alone if it's working fine.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
if it is sealed, the grinding may just be a bit of dirt working its way along the axle into the BB. You might want to pull the crank out, wipe it clean and regrease the axle before re-inserting. That is probably all you can do.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
