Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Wide Feet, Narrow Budget: Questions on Clipless
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 07-03-13, 08:50 AM
seashmore
Question Wide Feet, Narrow Budget: Questions on Clipless
Here's my deal: I have really wide feet and a really narrow budget but I want to try giving the efficiency of clipless pedals a spin.
I'm tired of wasting energy on regular pedals; lifting my leg does nothing to move me forward.
My foot measures approx. 23 cm/9 in long and 10 cm/4 in wide (U.S. size is a women's 6.5 D), and I have trouble enough finding regular shoes in my size and price range. I'm willing to spend up to $100 on a good pair of biking shoes, but only if I know they're going to fit well and last at least 2 Midwest riding seasons (March~October).
I've also considered trying toe clips. My biggest hesitation with those is that I'm not sure how quickly I'd be able to get my foot out of them should I need to. (I've seen enough other riders unclip seamlessly enough to give me hope there, but toe clips are less common.) Not to mention they seem outdated and clunky.
Is there a way to convert regular shoes to clipless? Any specific suggestions on brands or websites?
Or should I just consider getting a dog to lift it's leg on the whole idea of my riding clipless?
seashmore is offline
Old 07-03-13, 09:13 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Trying shoes in person will be a must. I have wide feet (8.5EE in New Balance), and found a pair of Giro Rumbles that fit nicely. They're 43 EU/9.5 US mens.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-03-13, 10:13 AM
MRT2
MRT2's Avatar
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times in 146 Posts
As far as I can tell, no way to convert regular shoes to SPD. Either try shoes on in person at a LBS, or buy a bunch of shoes from a mail order place and return the ones that don't fit.
Edit. as far as websites, Nashbar always seems to have good deals on SPD compatible pedals and shoes.
MRT2 is offline
Old 07-03-13, 10:43 AM
sreten
Bikes: 20" Folder, Road Bike
Hi,
Toeclips are pretty easy to get out of. Mine are always set the same.
Pro riders used to have them "loose" and then "tighten" them for e.g. a
sprint section, tightened they are not easy to get out of at all I imagine.
To tighten you simply grab the flying toestraps, and to loosen you flip
the release buckles on the toestraps, but I get along fine doing neither.
Yes they are a little outdated and clunky, but so is my budget bike.
I use them with sturdy soled walking trainers I've had for years.
The other option for normal foot wear is variations on "power grips".
https://www.ebay.com/itm/Power-Grips-...item338363608f
https://www.ebay.com/itm/ORIGIN8-PRO-...item565806988c
rgds, sreten.
sreten is offline
Old 07-03-13, 10:49 AM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times in 623 Posts
Try this...works fine for me.
https://store.velo-orange.com/index.p...alf-clips.html
Fred "The Real Fred"
10 Wheels is offline
Old 07-03-13, 12:06 PM
DX-MAN
First, about clipless: they do require special shoes, your chances of making something like soccer cleats work is iffy at best. (I know those have pretty stiff soles, too, but it's REAL tricky, and not worth the effort.) Try on a few brands before you buy, as not all are sized equally. (I go by Euro sizing, my size is 46, and have had problems in the past even with that....)
If you're not ready to go that route, try these:
https://www.cyclocamping.com/proddeta...PG_d_KIT_d_TAN
I used those a decade ago, as a 'transition' to clipless, as the exit motion is the same. The advantage is, you can use regular shoes; the disadvantage is, they wear out a little faster (across the top of the shoe).
DX-MAN is offline
Old 07-03-13, 12:22 PM
seashmore
Originally Posted by 10 Wheels
Those seem pretty sweet. I might have to look for some the next time I go into my LBS to make sure they're compatible with my foot length/pedal position.
The prices on Nashbar seem cheap enough for me to try the buy-to-try-on method, even with the return shipping costs.
I also found an easy-to-read size conversion chart here:
https://www2.bsn.de/cycling/shoe-sizing.html
(mostly posting so I don't lose the link myself)
Old 07-03-13, 01:07 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Welgo has low cost Clipless pedals , they imprint other logos for Big Importers like Performance/Nashbar.
SPD sandals like Shimano's are very adjustable to fit many widths..
they also adjust to suit the sox you are wearing , thick or thin..
To be realistic , its more like Un weighting the leg on the upstroke than actually Pulling the pedal .. Up.
but the step in pedal scheme does help you turn Higher cadence RPM's 100+..
fietsbob is offline
toobusi
Road Cycling
11
05-09-17 07:46 AM
linnefaulk
General Cycling Discussion
17
08-14-14 10:54 PM
mr.grey
38
05-16-13 11:04 AM
The Golden Boy
Classic & Vintage
15
07-04-12 12:15 PM
Tbonedr
3
08-31-11 09:12 AM
