Downtube folding bike
#127
Quoted: 14 Post(s)
Oh dear, hmm i think for myself i would i always opt for a 32 spoke wheel! I really prefer a little overenginering over a bit of added speed. I really hope you will continue to offer the 32 spoke wheelset.
#128
Folding bike junkie!
Problem is the Downtube is a wee bit porky. I can feel its heft while riding it but if feels solid so I don't mind it. It has been quite fun tooling about in the snow. The stock tires which might not be great (ie. inefficient) under normal conditions have been pretty good in the snow and slush. Only other downside is the grease in the steering gets REALLY stiff once the temps are under 20F. I still can't get my gears to shift right but they are closer now. I think I will have to change the length of the cable because no matter how I turn the ferrules, I can't get enough slack in the cable. So a simple adjustment should get it but I haven't had time to mess with it so far other than other basic adjusments. Anyone know what the little inside wheel on the gear shift does? It is a sort of a luck or something? Maybe a tensioner? It seems to do nothing on my bike.
#129
Quoted: 113 Post(s)
Liked 8 Times
bruce
#130
I have fussed with the derailluer for the past our. It appears that one of the brackets is bent. To top it off the little plastic spoke guard has parted company from the derailleur mount. I found my derailleur was actually contacting the spokes on my wheel it was so badly bent. It then would hunt from gear to gear no matter what I did. So now if it is not perfectly adjusted, the chain when going into first gear hops over the backside of the last sprocket and into the spokes.
It is getting to be pretty frustrating. I may just give up fighting with it and drop in a internal hub. I could probably send it back to Yan as well and get them to fix it. Sort of a bummer though getting a new bike and have this sort of issue. There was no external damage to the box but the derailleur bracket is obviously bent if it is contacting the spokes.
I don't want to over stress it and snap it off bending it back either. The problem now is the little spokeguard just spins and rattles as the wheel rotates. That one would be a real PITA to change too I am betting. Hard to get a good feel for the bike when you can't select a gear without it hopping to another one. It makes it easy to almost fall on your face.
I have another one in the box that maybe I'll pull out tomorrow. I will see if it has the same issue. It has a lot of promise. If the average person got one like I did the'd be sending it back for sure. I can't see doing that if I can resolve the problem myself but then again I don't want to spend a bunch of time when it should have worked out of the box.
#131
Bikes: 2003 KHS F20-Westwood folding & enough parts to make several more bikes...
Wavshrdr,
Could you post some photos of the problem? What's the "spoke guard" you're speaking of? (the only thing that came to mind was the dork-disk but that wouldn't be attached to a derailleur) Also, what's the bracket you're referring to. (picture worth a thousand words ;)
I was surprised when I read your previous post expressing difficulty with the derailleur and shifter; I hadn't heard of anyone having such problems with the Downtube before so I figured perhaps it was a setup issue or, as you've indicated, something out-of-whack.
C.J.
C.J.
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
Wavshrdr,
It sounds like you need a new rear derailleur hanger. I will send you one tommorow.
Yan
Yan
#133
Quoted: 282 Post(s)
Liked 24 Times
Yan
#134
Yan thanks. Can I just remove that little plastic spoke guard that keeps the chain from hitting the spokes. I looked at my derailleur carefully and the bracket is obviously bent (assuming it should be parabolic). It has a slight curve to it. I knew it was obviously an issue when the derailleur hit the spokes of the wheel. There are no marks on the derailluer though from any impact.
#135
Quoted: 282 Post(s)
Liked 24 Times
Replacing the hanger will take you 2 min. Tell me if you have any problems. FYI all our bikes have replacable rear deraileur hangers.
Thanks,
Yan
#136
Bromptonaut
Bikes: 1994 Diamond Back Racing Prevail ti; Miyata 914, Miyata 1000, 2017 Van Nicholas Chinook
Quoted: 23 Post(s)
Wavshrdr,
Yan (as well as Whoever is responsible for shipping their bikes) is making sure the bikes are shipped "ride-ready", but something is happening between shipping and receiving. Unless you are an experienced bike mechanic, I would suggest taking any bike that spent some time in ground transportation for an inspection.
I had 3 Downtubes shipped to my address and all three, once inspected at the LBS, had (at least) some minor bending of the derailleur. It may be a coincidence or not, but the box that was delivered by UPS was the only one that 1)did not have holes and were not massively abused and 2) had the derailleur in riding conditions (the other two bikes came from 2 different locations but both delivered by DHL and received some transporting damage). The last one (a silver VIII - just front suspension) came with the plastic spoke guard you mention broke as well, and one entire pedal crank outside the box.
About 5 weeks ago, my roomate insisted that his Downtube was perfect and that he needed no Bike mechanic to do what he could do himself. He did some minor adustment on gear and did about 200 miles on it. After my girlfriend traded her halfway to a Downtube identical to his bike and had it tuned at the LBS, it was like 2 completely different bikes. Brakes, gears, overall feeling, it is amazing what some days inside ground shipping can do. The Derailleur was in riding condition but once examined using that little "compass" tool, also showed some degrees off.
As I said on my review, if you add the average US$30.00 for the "pre-flight" check-up + gear adustment at your LBS, it makes the Downtube one of the best value folders in the U.S.
Only if Yan could use the Star Trek method of transportation...bike disappears there, bike appears here!
Feel free to follow me on Instagram
#137
Originally Posted by Rafael Guerra
Wavshrdr,
#138
Quoted: 282 Post(s)
Liked 24 Times
Wavshrdr,
Thus far problems with shipping have been our biggest issue. The top complaints we get are:
#1 Rear reflector broken
#2 Boken Bell
#3 Rear derailleur hanger bent
#4 Spoke Protector Damaged
#5 Paint scratched
Overall, I am unhappy about the problems, however I am very excited that the issues have been so minimal (we have had zero misaligned frames). We have taken steps to rectify these issues in the future. All bikes on our second container were much better packed. The rear reflector and bell were placed in the carrybag, and our third container will have a thicker replacable alloy dropout....I hope it helps!
Thanks,
Yan
#139
Quoted: 14 Post(s)
@ Yan. About the spokes and suspension, that makes a lot of sense actually. SO i am not worried, i am glad you give so much thought to your product. I guess i am a sucker for beefiness because i (also) like non suspended bikes and sometimes use my folder kindoff like a BMX. Does what you wrote mean that Downtube will only develop and sell non-suspended bikes from now on?
#140
Quoted: 282 Post(s)
Liked 24 Times
Thanks,
Yan
#141
Quoted: 14 Post(s)
Oh sorry yes, that is what i meant that you would possibly no longer carry Non suspended models. Glad to hear you will carry both for a while yet, i think they both have their place and (dis)advantages. Keep up the great work. Btw is there a place on the Downtube site yet with lots of clear/detailed pics of your products, that would be nice so i could turn people on to your bikes.
#142
#143
Quoted: 282 Post(s)
Liked 24 Times
Originally Posted by jasong
I also had a huge hole near the derailleur on the box my bike was shipped in, but haven't checked the derailleur alignment. I'm curious if Wavshrdr had his limit screw completely let out for the derailleur hitting the spokes. My clearance is very tight (perhaps I'm bent, which I'll check) between the rim and the derailleur pulleys when aligning to get the pullers just over the largest cog.
Thanks,
Yan
#144
Quoted: 282 Post(s)
Liked 24 Times
I have great news the Downtube VIII and VIIIFS bikes were just listed in roadbikereview.com . I am hoping some of our customers from this forum can help us by writing a review. The Downtube VIIIFS page is at https://www.roadbikereview.com/cat/la...5_5671crx.aspx
and the Downtube VIII is at https://www.roadbikereview.com/cat/la...4_5671crx.aspx
Thanks in advance!
Yan
Thanks in advance!
Yan
#147
Old Noob
Location: Mid-MN not the end of the world, but you can see it from here
Bikes: Downtube VIIIFS folder, 2 Strida 3 folders, HP Velotechnik "Grasshopper" and a Burley "Hep Cat"
If it was up to me. Rik
<img src="https://www.differentperspectiveproductions.com/Clients/yan/logo_alternative.jpg">
Hmmmm.... maybe that doesn't work here. Anyway, I like the one with the letters built into the bike.
Downtube VIII FS folder - his .... 2 - Strida3 folders - his n' hers .... HP Velotechnik Grasshopper - his .... Burley Hep Cat - hers .... Whiz Wheels TT Cruiser W/velo kit - his
Ayn Rand was a prophet ..... it isn't my fault
#150
@#$% cars
Bikes: '02 Schwinn Frontier;'03 Fisher Tiburon; '04 Raleigh Companion; 04 Dahon SpeedPro; 69 Raleigh Sport fixed
Originally Posted by downtube
How about
Thanks!
Yan
Thanks!
Yan
