Bikesdirect Mini Velo upgrade thread
#127
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 10 Times
Yes, it has a rubber band that slides to one side or the other. I took them off and installed tape.
Speed Uno
Dawes Kingpin 2speed
Speed Uno
#128
Liked 6 Times
Well, heres mine :
Re-tape-ed & re-cabled ( shorter housing in white ), old school Vetta saddle, Schwinn xs bmx pedals, Elite cage, 8mm crank bolts.
Likes For martinus:
#131
So what did YOU do to it?
Bikes: 2006 Fetish Penna, 2014 Fuji Cross 2.0
I bought rim tape, and a new set of handlebars for mine. I can't wait to get them on.
Likes For martinus:
#133
Quoted: 11 Post(s)
Liked 10 Times
I like the white cable housing.
[IMG][/IMG]
[IMG][/IMG]
Speed Uno
Speed Uno
Likes For Dynocoaster:
#134
Oops. I bought new rim tape saturday, but didn't install it. I had a rim tape failure tonight... Well there's my excuse to go hog wild and get this bike in Nero-shape.
#135
All ur bike r belong Enki
New upgrades:
-Found a magic gear of 47x13, allowing me to lose the derailleur-mounted chain tensioner (Rocket BMX 10H 47T chainring, Dimension 13T BMX cog, KMC Z610HX single-speed chain).
-Origin8 quill stem adapter w/ 80mm Civia Bryant stem.
-Intense Micro Knobby-R tires.
Likes For martinus:
#138
Mine arrived last night. I have two bike projects splayed all over the basement that need cleaning up tonight before I get started, but that's some motivation right there!
#140
#141
Liked 6 Times
Thanks, no java on this comp... https://sheldonbrown.com/gears/ : o)
Looks like, these little guys will never be *fast* ... : o( ... not even with a 56/11.
#142
Liked 6 Times
Raised my FD. : o)
Had some free time ... an x-330 dontated parts, along with an old college franken bmx commuter.
52/12 ... with a 48 inner. This is ~90 gi, at 90 c/rpm, thats 24 mph. Much better, then the stock gearing, ( 20 mph @ 90c ) maybe now the tires are the next speed factor/excuse . ( link just in case https://www.thorusa.com/ )
I also had a chance to weigh it . : o(
... I'll find out on tomarrows commute.
#143
Built mine up last night. 53cm size, no modifications except I took the wheel reflectors off, bathroom scale method says 26.6lbs. It was sooo hard not to stay up late last night and start swapping stuff around. I have at least two double cranks in the basement that would look better on this bike, not to mention a triple if I wanted to give this thing some rock crawling gears. I have a threadless stem adapter just begging to be installed with a nice shiny alu stem that should give me enough length to replicate body position on my good road bike. I have bar end shifters (and an 11X34 9sp cassette) that need using. The list goes on. I'll probably just do the rim strips and go get some initial ride impressions first. This thing is going to be a riot.
Likes For martinus:
#145
Liked 6 Times
Fixed the chain length issue, on lunch ...
but, not with a longer chain ... instead I made a tiny franken cassette. : o)
I used a Forte(hope it lasts) 11-32 ...AND, a Sram 12-23 .
So... I now have a 11-21, 8 sp ! ( 11,12,13,14,15,17,19,21.)
Shifts suprisingly well, considering the sloppy ( indexed ) levers.
~98 GI with the 58T
~98 GI with the 58T
#147
Quoted: 11 Post(s)
Liked 10 Times
451 wheels and skinnier tires may make it go even quicker.
Speed Uno
Speed Uno
#148
Rim tape installed. Tires are sitting at 110psi. I feel like a big man, I got the wire bead tires on without tire levers. :-)
#150
Love the white on black. Mine's black too and I'm thinking white all around. My only mods so far are rim tape and keo's (black, b/c that's what I have laying around). The corncob cassette is a great idea.
