2016 Specialized Crosstrail Comp Disc v Sport Comp Disc
Old 08-21-15, 01:36 AM
DaveD1
2016 Specialized Crosstrail Disc v Sport Disc
Hi all,
Its been years since i owned a bike and i'm currently in the middle of ordering one through my local bike to work scheme.
The bike won't really be used for commuting, more so for fitness and getting out and about with the kids. I will be on some small trails around my local park.
I had settled on getting the 2016 Specialized Crosstrail Sport Disc but when i went to order it yesterday i was told it won't be available for at least another 3-4 weeks, but my LBS could get me the Crosstrail Disc within a week. They said the main difference between the two is the Sport has hydraulic disc brakes whereas the Comp Disc has mechanical discs. The Crosstrail Disc is cheaper too.
Any thoughts? Based on my intended use i'm kinda been swayed towards just going for the Crosstrail Disc, or should i wait? I'm not sure i'll need hydraulic brakes. I'm assuming the mechanical discs would be superior to the normal V (?) brakes that would have been on my last bike (15+ years ago).
Spec of both:
Crosstrail Disc
FRAME
Specialized A1 Premium Aluminium, Fitness Geometry, fully-manipulated butted tubing, IS disc mount, fender/rack mounts
FORK
Custom SR Suntour i-NEX, custom Multi-Circuit Damping, custom coil spring weights, 63mm travel, hydraulic lockout, preload adjust, 1-1/8" steerer, alloy lowers, Hi-Ten 28mm stanchions, post disc mount
HEADSET
FSA, semi-integrated bearings
STEM
Forged alloy, 4-bolt, 10-degree rise
HANDLEBARS
Specialized, 6061 alloy, 8-degree backsweep, 5-degree upsweep, 25mm rise, 25.4mm
GRIPS
Specialized Body Geometry XCT, lock-on
FRONT BRAKE
Tektro Aries, mechanical disc, organic pads, 160mm rotor
REAR BRAKE
BRAKE LEVERS
Tektro
FRONT DERAILLEUR
Shimano FD-M191, top swing, dual pull
REAR DERAILLEUR
Shimano Altus, 8-speed
SHIFT LEVERS
Shimano SL-M310, RapidFire Plus, 8-speed
CASSETTE
Shimano, 8-speed, 12-32t
CHAIN
KMC X8, 8-speed, w/ reusable MissingLink
CRANKSET
Specialized Stout, forged alloy, 48/38/28T, w/ chainguard
BOTTOM BRACKET
Square taper, cartridge bearings
PEDALS
Nylon, w/ reflectors
RIMS
Alloy, double-wall, disc
FRONT HUB
Specialized, Hi Lo disc, QR, 32h
REAR HUB
SPOKES
Stainless, 14g
FRONT TYRE
Specialized Trigger Sport, 60TPI, BlackBelt protection, 700x38mm
REAR TYRE
SADDLE
Body Geometry Targa Sport, steel rails, SWAT compatible mounts, 155mm
SEATPOST
Alloy, 2-bolt, micro-adjust, 12.5mm offset, 27.2mm
SEAT BINDER
Alloy, 31.8mm
FRAME
FORK
HEADSET
STEM
Specialized, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS
Specialized, double-butted 6061 alloy, 9-degree backsweep, 5-degree upsweep, 15mm rise, 31.8mm
GRIPS
FRONT BRAKE
Tektro Auriga, hydraulic disc, resin pads, 160mm rotor
REAR BRAKE
BRAKE LEVERS
Tektro, hydraulic
FRONT DERAILLEUR
Shimano Altus, top swing, dual pull
REAR DERAILLEUR
Shimano Alivio, 9-speed
SHIFT LEVERS
Shimano SL-M370 RapidFire Plus, 9-speed
CASSETTE
Shimano, 9-speed, 11-34t
CHAIN
KMC X9, 9-speed, w/ reusable MissingLink
CRANKSET
Specialized Stout, forged alloy, 48/36/26T, w/ chainguard
BOTTOM BRACKET
PEDALS
RIMS
FRONT HUB
REAR HUB
SPOKES
Stainless, 14g
FRONT TYRE
REAR TYRE
SADDLE
SEATPOST
SEAT BINDER
Alloy, 31.8mm
DaveD1 is offline
Old 08-21-15, 06:48 AM
avidone1
avidone1's Avatar
Bikes: 2016 Specialized crosstrail comp disc
I don't know where your getting your information from but it's all wrong. Unless perhaps your from some country I'm not familiar with.
Both the comp disc and the sport disc use hydraulic brakes. the comp disc, which is the more expensive model uses shimano's while the sport disc
uses tektro. there are other differences as well .
Here are the 2016 specs.
Specialized Bicycle Components
avidone1 is offline
Old 08-21-15, 07:12 AM
DaveD1
My apologies, i've been looking at the Specialized website for too long and got the models mixed up
The 2 bikes i'm looking at are the Crosstrail Disc (mechanical) and the Crosstrail Sport Disc (hydraulic).
I've edited the original post.
DaveD1 is offline
Old 08-21-15, 07:20 AM
swoodjr1
Bikes: 1999 Giant Rincon; 2009 Mercier Corvus Al; 2012 Trek Marlin; 2016 trek FX 7.5 when available
I would spend the extra coin and wati for the better bike. More gearing options. Superior brakes. Better derailleurs.
swoodjr1 is offline
Old 08-21-15, 07:55 AM
travbikeman
travbikeman's Avatar
Bikes: The growing fleet: Scott Sub Cross 30, Specialized Crosstrail Sport, Scott Scale 970
Quoted: 298 Post(s)
Liked 48 Times in 34 Posts
How much riding do you foresee yourself doing? If your just going to go on short rides with the family, then the Crosstrail disc should be fine. The really big differences between the Disc and Sport disc as I see it: rear derailleur, gearing and the brakes. The Sport disc is better, but if your only going to put like 15 miles a week or so, the regular Crosstrail disc should be just fine.
Comparison:
Altus vs Alivio - Alivio in my opinion is a bit smoother to shift and stronger. Altus will need to be adjusted more often, but has worked well so far on my Wife's bike
Gearing: The Sport has more gear ranges that helps better with going up a hill. I've also noticed it helps more with going slower if you have a child that is slow on her bike (like my daughter).
Brakes, My son has these mechanical ones and they work well. I have the hydraulic and really the only major usage difference is how easy it's to pull the brake levers. But I have also noticed that cleaning and adjusting my hydraulic brakes are a whole lot easier than the mechanical. Taking the pads out of the mechanical is a bit of pain since Tektro uses a pin that needs to be bent rather than a screw.
If your willing to wait a few weeks, I would choose the Sport. But that's my preference knowing that I've been riding upwards of 200 miles a month now. IF your riding just like 40 or 50 miles a month. Then save your money and get the regular Crosstrail disc.
BUT, this is your decision. A happy rider is one that will keep riding!
travbikeman is offline
Old 08-21-15, 10:43 AM
Mattyb13
Mattyb13's Avatar
Bikes: 2017 Specialized Diverge Comp Carbon Ltd. 2016 Specialized StumpJumper FSR Elite 650B
Quoted: 24 Post(s)
If weight is in any way important to you then WAIT for the comp.
My fiance has the Sport disc, and I had the Comp and now have the Expert disc. The weight difference from the sport up to the Comp or the Expert is dramatic and well worth the additional investment imo.
Mattyb13 is offline
Old 08-21-15, 11:36 AM
Wanderer
aka Phil Jungels
Wanderer's Avatar
Bikes: 08 Specialized Crosstrail Sport, 05 Sirrus Comp
Quoted: 166 Post(s)
Liked 39 Times in 29 Posts
Of your two, I'd wait for the sport. A better bike, all around. Maybe the best buy in that group.
Wanderer is offline
trainchaser
Hybrid Bicycles
40
08-08-15 08:24 PM
nathannew2009
Hybrid Bicycles
9
04-03-15 06:11 AM
chowna
Hybrid Bicycles
11
08-19-14 10:04 AM
Geargirly
Hybrid Bicycles
11
04-14-14 01:02 PM
posaune
Hybrid Bicycles
22
04-13-11 10:38 PM
