Cannondale CAAD12 BB30A Creak
Old 08-22-19, 11:02 PM
Robert A
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 559 Post(s)
Liked 63 Times in 45 Posts
I have a 2019 CAAD12, still under warranty. Bike has been to LBS twice for creaks and ticks in BB, and is going back yet again. LBS says Cannondale doesn't warrant the issue and has suggested replacing the unit with a Wheels Mfg PF30 BB for around $120 including labor. I'm aware that some BB30s has this issue, but always assumed Cannondale would cover any needed repairs if the bike was still warranty. I believe the BB replacement includes a narrower, and less stiff, spindle.
I've written to Cannondale and am waiting to hear back. Meanwhile, does Cannondale stand behind this issue? And is the dealer's suggestion to replace the BB an appropriate fix?
Thanks,
Robert
Robert A is offline
Old 08-22-19, 11:33 PM
menkar
I've put grease on the spindle where it goes into the bearings as others here have suggested and the creak goes away.
I did have a Hollowgram PF30 which creaked once but it turned out that the lock ring holding the Spidering wasn't tightened properly at the factory.
menkar is offline
Old 08-23-19, 04:18 AM
Lrdchaos
Quoted: 83 Post(s)
Liked 18 Times in 13 Posts
My 2015 supersix evo developed a creek and clanking sound in the BB. The bike was under a year old by was replaced under warranty by cannondale. How old is Your bike?
Lrdchaos is offline
Old 08-23-19, 06:10 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
You need to have the bearings reinstalled with loctite bearing retention compound. They need to be held in place by the bearing press for 24 hours while the loctite cures. The loctite can push the bearings out of place when curing. This will stop the creak for years.
And no, this is not a warranty issue.
topflightpro is offline
Old 08-23-19, 06:42 AM
JasonD67
Bikes: BMC Teammachine SLR02 Disc, Cannondale CAAD 4
Quoted: 77 Post(s)
Liked 16 Times in 10 Posts
The LBS where I bought my BMC in February had signs on all their new C-Dales that they had replaced the factory BB's with upgraded ones because of the problems C-Dale was having, so not surprised you're having issues.
JasonD67 is offline
Old 08-23-19, 07:23 AM
Robert A
Quoted: 559 Post(s)
Under one year. It's been a problem all throughout the year. What was your process for getting Cannondale to make the replacement?
Robert A is offline
Old 08-23-19, 07:24 AM
Robert A
Quoted: 559 Post(s)
Why is it not a warranty issue?
Robert A is offline
Old 08-23-19, 07:27 AM
Lrdchaos
Quoted: 83 Post(s)
I took it into the shop and they replaced it under warranty. I would call the shop again and express my displeasure and insist that a faulty bb is a warranty item.
Lrdchaos is offline
Old 08-23-19, 07:29 AM
Robert A
Quoted: 559 Post(s)
Was your problem the widely reported ticking/creaking sound from the BB, or was it more than that?
Robert A is offline
Old 08-23-19, 07:34 AM
Lrdchaos
Quoted: 83 Post(s)
It was a mixture of a creak/tic and squeal. The creaking and ticking is annoying as hell. We spend too much money on these bikes for that bs. My spec stumpjumper MTB started creaking and they removed the bb and cleaned/greased everything and it quieted down.
Lrdchaos is offline
Old 08-23-19, 09:43 AM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
This is the right answer. Ive got two bb30 cannondales and do my own bearing replacements and going on almost 10,000 miles and no creaking.
redlude97 is offline
Old 08-23-19, 09:47 AM
Robert A
Quoted: 559 Post(s)
I'll mention this to the dealer. Meanwhile, I wrote to Cannondale and they suggested that I ask the dealer to submit a warranty claim through dealer channels. So let's see what they come back with.
Keep in mind that this bike is less than a year old and the problem began when the bike was almost brand new.
Robert A is offline
Old 08-23-19, 11:09 AM
topflightpro
Because it's considered an installation issue, not a manufacturing one, even if the bearings come pre-installed from the factory.
(Side note: I have had the bearings pulled and reinstalled in the manner I mentioned on every BB30 frame I've owed - all 6 of them.)
Old 08-23-19, 11:14 AM
Robert A
Quoted: 559 Post(s)
Isn't installation essentially workmanship?
"Cannondale bicycles are warrantied against manufacturing defects in materials or workmanship."
Robert A is offline
Old 08-23-19, 12:33 PM
redlude97
I would say they won't warranty it because bearings are a wear item, so unless it creaked off the factory floor they aren't going to replace them under warranty
Old 08-23-19, 12:46 PM
Robert A
Quoted: 559 Post(s)
Agreed, but this started when the bike was almost brand new. Bearings don't wear out after three months and 400 miles. I've asked the LBS to submit a warranty claim to Cannondale, so we'll see what they say.
Robert A is offline
Old 08-23-19, 01:11 PM
topflightpro
Are they ceramic? The ceramic bearings in my Caad 10 didn't make it 6 months.
Old 08-23-19, 01:18 PM
Robert A
Quoted: 559 Post(s)
No idea, but the dealer hasn't reported this as an issue after taking the BB apart twice. They're suggesting a BB replacement with the threaded unit.
Robert A is offline
Old 08-23-19, 02:07 PM
ARPRINCE
ARPRINCE's Avatar
Bikes: 2021 Tern Verge X11 + Cannondale 2016 CAAD12 eTap + 2011 Synapse Alloy 5 Ultegra
Quoted: 150 Post(s)
Liked 24 Times in 16 Posts
I'd try the loctite first as others mentioned (let it cure).
ARPRINCE is offline
Old 08-23-19, 02:09 PM
Robert A
Quoted: 559 Post(s)
https://www.youtube.com/watch?v=ecT_6vjjjGQ
Will do, but first I want to see how Cannondale responds to my warranty request.
Robert A is offline
Old 08-23-19, 08:07 PM
Adonis72
Quoted: 11 Post(s)
Liked 8 Times in 6 Posts
I feel ya man, who wants to buy a brand new bike and deal with that crap. I had one same issue, fixed 500 miles later same crap, I understand you can easily fix it with the loctite fix but Cannondale has known about this issue for years and done nothing, unacceptable.
Adonis72 is offline
Old 08-23-19, 08:48 PM
Robert A
Quoted: 559 Post(s)
Surprised me that they stayed with the same system for the new generation that just came out.
Robert A is offline
Old 08-23-19, 10:59 PM
Princess_Allez
Quoted: 173 Post(s)
Liked 57 Times in 40 Posts
I'm betting all the manufacturers are aware of the BB30 creak and they, therefore, don't warranty it.
Princess_Allez is offline
Likes For Princess_Allez:
Old 08-24-19, 07:31 AM
topflightpro
If they’ve pulled the bearings twice, you need to replace them. You can pull and replace once, but twice is asking for problems.
Wheels Manufacturing are my go to for quality and affordable BBS and bearings.
Old 08-24-19, 11:41 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
Yes this is basically the setup that BBInfintite sells. They use their version of Locktite and sell it in their bottom bracket kit. The other thing that can help is making sure all surfaces are completely clean with now residual grease or dirt.
colnago62 is offline
