Kickstand for a bike without a mounting bracket
I've attached a couple pictures of that frame area. Is there any way to install a center-mount kickstand? I hope to avoid
the sort that clamps to the chainstay.
The bike is a Raleigh Cadent 3.
Quoted: 350 Post(s)
Liked 122 Times
There are rear stay mounted kickstands that fit at the point where the 2 stays meet at the dropout. Look for pletscher multi or multi zoom.
https://www.pletscher.ch/index.php/e...nds-en#P10Tab1
But it doesn't always work for every bike. It depends on the angle of your stays. Mine made it stick out too much and I would kick it with my heel.
Quoted: 2482 Post(s)
Liked 2,952 Times
If you must use a kickstand, DO NOT use the style that uses a plate behind the bottom bracket. Your frame is aluminum and would likely be irreversibly damaged. Use a rear triangle mount as recommended above.
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
I typically use a Greenfield with the offset upper plate to clear FD cables.
I always cut up an inner tube or rubber gasket material and glue it to both pieces where it contacts the frame. This allows you to not have to crank it down to "stay crushing" levels and remain in place.
I've also been known to saw a groove in the plate as required for FD cables to operate smoothly.
Welcome to Greenfield Industries, Inc. - Freeport, New York - Quality U.S.A. Die Caster
Quoted: 1438 Post(s)
Liked 1,092 Times
Ooooh, thank you, Trakhak! I guess I stand corrected, as I assume EVERYBODY rides a 25-year-old steel mountain bike like I do. Accordingly, I apologize for the bad advice and will immediately delete my posts!
Thanks everyone, I talked to a local bike shop and they think a center mount kickstand can be made to work. I'll update this again once one has been installed.
