Filed my rim seams!
Filed my rim seams!
Old 06-16-20, 07:02 PM
67tony
67tony's Avatar
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 163 Post(s)
Liked 104 Times in 59 Posts
Filed my rim seams!
In another thread it was noted that Sun rims usually had a slight overlap at the bead. It was suggested I'd have to file them smooth, and I balked for a while because of scratching. Well, there was scratching, but I went after it with some 1000 grit sandpaper. Don't know if I did it right, wondering what grit-equivalent finish these rims are machined at, but I think they turned out pretty decent.
Before and after;
67tony is offline
Old 06-16-20, 07:18 PM
67tony
67tony's Avatar
Quoted: 163 Post(s)
Wheels are going on this Allez, which is starting to look like an actual bike!
Quick query: Figuring on a black Brooks, bar tape, toe straps, and housing...should I paint the seat post flutes yellow, red, or neither?
67tony is offline
Old 06-16-20, 07:34 PM
gugie
Dilberteur at large
gugie's Avatar
Bikes: It's complicated.
Quoted: 3271 Post(s)
Liked 1,592 Times in 804 Posts
Brake pads "scratch" the rims. I never understood hard anodization of rims, they all go "bald" at some time, and the coefficient of friction between brake pads and anodized alumium is probably less than on bare aluminum.
Rims are the disc of the brake, and are worn in the same manner.
gugie is online now
semroc
Quoted: 22 Post(s)
Liked 67 Times in 24 Posts
Nice work. I'd paint the flutes red.
semroc is offline
Likes For semroc:
Old 06-16-20, 07:48 PM
SurferRosa
Señor Member
SurferRosa's Avatar
Quoted: 1717 Post(s)
Liked 1,822 Times in 1,029 Posts
Definitely paint the flutes. Not sure on color. That would be saved near the end (along with choosing straps), after I see what the saddle and tape look like.
Black always looks good. And those rim labels might look better without the m13ii part.
Enjoying your process/progress. Everyone should take a stab at wheelbuilding.
SurferRosa is offline
Flying G
Flying G's Avatar
Bikes: 1971 Gitane TDF, 1974 Gitane Interclub, 2001 Serotta Rapid Tour CS3, 1986 Bruce Gordon touring bike, 1972 Gitane Super Corsa, 1978 Michal Johnson, 1972 Lambert Professional Grand Prix, 1983 Vitus (resto project), 1972 Raleigh Professional (resto)
Quoted: 31 Post(s)
Liked 24 Times in 10 Posts
Yes on red!
Flying G is offline
Old 06-16-20, 08:30 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 722 Post(s)
Liked 381 Times in 220 Posts
Don't worry about the scratching, brake pads should take care of that quickly.
Reynolds is offline
Old 06-16-20, 08:58 PM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1577 Post(s)
Liked 467 Times in 274 Posts
I'd go for yellow flutes; more subtle. Some night also recommend alternating red AND yellow flutes.
That's going to be a nice looking bike when you're done
● 1971 Grandis SL ● 1972 Lambert Grand Prix frankenbike ● 1972 Raleigh Super Course fixie ● 1973 Nishiki Semi-Pro ● 1980 Apollo "Legnano" ● 1984 Peugeot Vagabond ● 1985 Shogun Prairie Breaker ● 1986 Merckx Super Corsa ● 1987 Schwinn Tempo ● 1988 Schwinn Voyageur ● 1989 Trek 400 ● 1989 Bottechia Team ADR replica ● 1990 Cannondale ST600 ● 1993 Technium RT600 ● 1996 Kona Lava Dome ●
Lascauxcaveman is offline
Old 06-17-20, 06:29 PM
67tony
67tony's Avatar
Quoted: 163 Post(s)
Yes, I figured the pads would fill in the scratching, but I'm kind of persnickety so the light sanding made me feel better.
Looks like the preference is to paint the flutes. So far I've got one for yellow, two for red, and one for a mix of both. Good thing that can be close to the last thing, it'll give me plenty of time to think it over!
67tony is offline
Old 06-18-20, 10:09 AM
madpogue
Quoted: 1765 Post(s)
Liked 815 Times in 622 Posts
Flutes - either the same yellow as the lug trim, or the same orange (?) as the branding.
madpogue is offline
Old 06-18-20, 11:35 AM
Salamandrine
Quoted: 2310 Post(s)
Liked 560 Times in 402 Posts
A file, being rigid, will leave a more level surface than sandpaper. Better IMO if the rim joint has a lip. If sandpaper is glued to a stick, that'll do the trick as well. BITD I generally didn't bother unless there was a discontinuity severe enough to cause a tick... tick... tick... tick... sound whenever the brakes were used.
AFA scratched braking surface on rims, IME it works better. I'm not sure where this fear of scratching rims has come from. I sand most rims on purpose if there are any issues whatsoever with brake squeal, typically using 220, maybe 320 grit sandpaper.
P600 scratches on aluminum are pretty fine. They'll polish right out with compound.
There is a related issue I've noticed that probably deserves a PSA. Please people, if you get grit stuck and embedded in your brake pads, dig it out! This used to be common knowledge. In the last few years, I've heard so many people's brakes making that tell tale scraping sound on descents, that I have to conclude that most people are not taught to clean brake pads any more.
Salamandrine is offline
Old 06-18-20, 01:28 PM
67tony
67tony's Avatar
Quoted: 163 Post(s)
Yes, the yellow lug trim is very close in color to the decals.
I think the lighting in the pics makes them look more orange than they are.
It's going to be a tough call on what color to go with, especially since it'd be a hassle to change if I don't like my choice.
I've got to admit, the alternating yellow & red is kind of intriguing.
With three flutes on each side, I could go;
Y-R-Y on both
or
R-Y-R on both
or
Y-R-Y on one side, and R-Y-R on the other side.
But...that last idea would not be symmetric, and even though no one would notice, it would likely bother me!
67tony is offline
Old 06-18-20, 09:04 PM
repechage
Quoted: 1850 Post(s)
Liked 687 Times in 538 Posts
the ceramic coated Mavic rims were cool.
anodized rims were for team mechanics to avoid polishing them.
repechage is offline
Old 06-18-20, 09:16 PM
xiaoman1
Awaiting Parole
xiaoman1's Avatar
Bikes: A few too many
Quoted: 928 Post(s)
Liked 911 Times in 567 Posts
Alternate the color...nice build BTW.
Ben
xiaoman1 is offline
Old 06-20-20, 02:07 PM
J.Higgins
Mentally Derailleured
J.Higgins's Avatar
Quoted: 1184 Post(s)
Liked 476 Times in 325 Posts
Hey! How did I miss this thread?
I file the seams on a lot of rims, and I'll have to say that 67tony , you did a great job!
Also... I'd leave the flutes unpainted unless you can exactly match the red or yellow.
Cargo Bike Build: https://www.bikeforums.net/utility-cycling/1228207-grocery-getter-build.html#post22024218
Trek T50 Tandem Build: https://www.bikeforums.net/tandem-cycling/1230829-trek-t50-tandem-test.html#post22066351
Remember, its just a beer commercial. That kind of happiness may not be obtainable.
J.Higgins is offline
Old 06-20-20, 04:07 PM
MaxDB
MaxDB's Avatar
Bikes: Batavus Comanche, Fangio Vitus 788
Quoted: 11 Post(s)
Liked 40 Times in 14 Posts
Nice project and nice sanding!
Going with full black tires or tan walls?
MaxDB is offline
Old 06-20-20, 04:33 PM
67tony
67tony's Avatar
Quoted: 163 Post(s)
Bought Continental Ultra Sport II's, with the subtle yellow stripe.
67tony is offline
