GP 5000 TL 28 vs. 32mm - which is faster/better
Quoted: 192 Post(s)
Liked 11 Times
Any thoughts on which of these would be faster? Essentially I’d love to go with the versatility of a 32mm, but don’t want to give up speed if there is much difference between this and the 28mm. What do you think?
Finally...how would these compare to the MAXXIS Velocita 40mm which is described as a high volume endurance slick.
This is going on a Giant Revolt Advanced 0.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Probably no noticeable difference in speed, lil more comfort and grip with the 32s tho. I'm running 32mm GP5K clinchers and they're great.
Likes For Rides4Beer:
Quoted: 1819 Post(s)
Liked 1,696 Times
How bad or good are the roads where you live? Where do you live. Around Montreal where I live roads are frost heaved during the winter resulting in very rough pavement year round. Roads are cracked and broken and poorly repaired. There is a condition on some roads I call "faux pave" feels like cobblestones but doesn't look as attractive. On good roads 700 x 25 is fine, but 700 x 28 feels better. On bad roads a good lightweight tire like the 700 x 32 GP 5000 will glide over the broken pavement much better than a 700 x 28 which will have to be run at higher pressure. The worse your roads the faster a wider tire will be compared to a narrower tire
Quoted: 192 Post(s)
Liked 11 Times
Quoted: 6196 Post(s)
Liked 4,810 Times
You keep track of your ride data don't you? Run one set for a full season of riding then run the other set for a full season. Compare rides on the same routes and let us know in two or three years.
Quoted: 20810 Post(s)
Liked 9,456 Times
You're probably not going to notice any meaningful difference between the two when it comes to ride time over a given course, but you may notice a difference in feel between the two depending upon your weight, roads, riding style, rims, etc. Second-hand experience probably isn't going to meaningfully convey the nuance between the two and, in the end, we're talking about consumables. Buy both, wear 'em out and form your own opinion.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
Put a 28 in the front and 32 in the rear; if the bike's wheelbase gets longer then the 32 is slowing you down. If the wheelbase shrinks then the 28 is slower.
Likes For Sy Reene:
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 389 Post(s)
Liked 325 Times
I have the GP 5000 TL in size 700x32c and setup tubeless on my bike and I love 'em. I was previously running 25c and 28c tires. With wide rims (mine are 25mm internal width) and lower tire pressure (~65psi), the 32's are the most comfortable road tire I've ever used. If they're slower than my other tires, I'd have no idea as I don't race (although I tried to ride fast.)
Roads I ride on often look like the following (of which this IS one of the roads I ride), which is why 32's have become my new best friend...
Likes For PoorInRichfield:
It's likely that the two GP5000 options perform much more similarly to one another than either does to the Velocita.
Quoted: 192 Post(s)
Liked 11 Times
If you have a reason to err wide, err wide. Even on a perfectly smooth and clean surface where there's no obvious benefit in 32mm over 28mm (except for maybe wear life), the performance penalties of a few millimeters of extra tire width are minimal. It's possible to distinguish the added aerodynamic drag by doing careful testing, and physics allows us to predict and model the kinematic effects of the added weight, but these aren't impacts that are casually noticeable on the bike or when just eyeballing average speed data on Strava.
Hard to say without testing. Some casing construction factors, such as protection layers for cuts and punctures, can have big effects on rolling resistance. When comparing two slicks, the performance differences from these factors can often play a significantly larger roll than more visible things like tire width. In extreme cases it can even be the other way around: even on a smooth road, a fast 40mm slick can sometimes be faster than a slow 28mm slick.
Quoted: 41 Post(s)
Liked 28 Times
No real difference in rolling resistance.
https://www.bicyclerollingresistance...endurance-test
Going from a 40 to a 32 is an easier transition than 40 to 28.
Quoted: 850 Post(s)
Liked 344 Times
Regardless of whether you have a 23 or a 32, you can run a certain pressure to achieve the same amount of comfort over mild bumps. The difference is that, with big hits, you will crack your rims riding 23s but be fine with 32s. The only penalty to wider tires is aerodynamics (lol) and weight (lol again).
If faster was the real driving factor shouldn't you be on a roadbike instead of a gravel bike?
Go with the bigger tires, it'll be more comfortable.
In the past year, I've ridden GP4K 700 x 25 which were 28mm wide, GP4K 700 x 28 which were 31mm wide. I'm currently riding 700 x 32 tubeless tires that actually measure 32mm, and while they're super plush, they just feel too wide to me. I notice the weight. I feel like the 'wider is always better' mantra is valid up to around 30mm, but beyond that, I do think the weight and aero become a factor. I know this is controversial, and I freely admit that it could be in my head. I don't care what internet rolling resistance studies say, I know how my bike feels on my routes with different tires.
Anyway, I'm mounting a new set of GP5K TL 700x28 this weekend. I think this will the optimal tire for my riding style. I'll probably run them at 65/60 psi (maybe lower, I will experiment), I'm pretty sure I'll get almost all the benefit of the 32mm tires I'm using now. I'll post back in a month or two with the results.
Quoted: 152 Post(s)
Liked 173 Times
I've ended up with 32mm as my go-to tires. But I ride on a bunch of god awful chip seal roads with plenty of cattle gates for extra fun. If I road on good roads I'd probably drop down to 28mm.
Advocatus Diaboli
Liked 1,533 Times
I think the wide tire discussion is much simpler than most people make it out to be. Think about it like suspension on a mountain bike.
Quoted: 850 Post(s)
Liked 344 Times
^this is with their old 25i/32e rims
