How to choose a bottom bracket spindle length for new cranks on a new frame?
Old 06-30-20, 01:54 AM
Funktopus
Quoted: 28 Post(s)
Liked 4 Times in 4 Posts
I'm putting some Stronglight 200lx cranks on a Vitus 787 frame. Both are new to me, so there's no precedent to compare to. I know a need a threaded 68mm square taperered bottom bracket, but I just can't figure out the spindle length I need.
Googling around seems to suggest it's a case of just trying a bottom bracket and seeing how the chain line is. Is that really the case? And if so, what's the best guess I can go with?
Thanks
Funktopus is offline
Old 06-30-20, 04:43 AM
plonz
plonz's Avatar
Quoted: 455 Post(s)
Liked 93 Times in 66 Posts
Thanks
There might be someone here using the same crankset who can tell you the spindle length they’re using. If not, you’ll need to use the method described above. Really only need one BB to get an initial reading, then you can source the correct one. Be mindful of different tapers which can impact arm seating and measurements.
plonz is offline
Old 06-30-20, 04:52 AM
J.Higgins
J.Higgins's Avatar
Quoted: 1001 Post(s)
Liked 224 Times in 161 Posts
My method is simply to use the same spindle length as the original and wing it. It works for me on most builds 99% of the time. I also have several junk sealed BBS, and spindles to fuss about before I order anything new. I also think most manufactures will have a recommended spindle length, but there are other ways HERE.
"Hammers, like any tool has great value when applied correctly, when not they can have some of the most disastrous results which can also serve to build skill after the fact but is better avoided by forethought." -Merziac
J.Higgins is offline
Old 06-30-20, 05:32 AM
SJX426
SJX426's Avatar
Quoted: 703 Post(s)
Liked 249 Times in 167 Posts
Funktopus Having gone through this challenge lately, I learned that you can take a shortcut by finding out what the spindle length needs to be for your specific crank.
Without that knowledge I would start taking measurements. Specifically the distance between the center of the rings and the surface of the boss around the inside of the spindle opening. Next number is the distance between the center of the bike and the center of the sprocket cluster. This last number plus the crank number will give you a close target for half the length of the spindle. Oh of course you need to know how far the spindle is likely to enter the crank.
This last measurement could be taken from an existing bike with a square taper BB. Measure the distance between the washer surface and the end of the spindle and subtract from the overall length of your crank taper and add that number to the last number above. Somewhere between 108 and 118.
It is harder than determining the crank BCD (122)
SJX426 is offline
Old 06-30-20, 03:55 PM
Funktopus
Quoted: 28 Post(s)
Wow interesting. I won't have a chance to do this until the weekend, but I'll give it a try. Some phrases I don't understand - what's the "boss around the inside of the spindle opening". A raised lip around the square hole on the bracket-side of the cranks? And when you say center of the bike, is that the center of the bracket opening?
Thanks!
Old 06-30-20, 05:33 PM
SJX426
SJX426's Avatar
Quoted: 703 Post(s)
Funktopus Kinda yes. Here is a picture but you really want to measure to the edge of the tapered hole. We are trying to get close, not exact.
P1030067, on Flickr
And yes. One would hope the center of the BB shell is the center of the bike. Better location is the center of the down tube or seat tube.
https://www.sheldonbrown.com/chainline.html
SJX426 is offline
Old 06-30-20, 06:06 PM
Dfrost
Dfrost's Avatar
Quoted: 339 Post(s)
Liked 72 Times in 54 Posts
You might try Velobase, looking at the Stronglights to find your crank. Their database often lists the correct BB length if your crankset is there.
VeloBase.com - View Brand
Does that model Stronglight crank require special threads on a crankpuller?
Dfrost is offline
