Moving brake lever to right side -adapting
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
I want to move my front brake lever to the right. I don't want to swap my brake levers on my freewheel bike which I ride 20% of the time.
I use my front brake more than a lot of fixed gear riders - for my knees and so I can stop hard and fast and save tires.
Questions:
Will I quickly adapt to new position on the fixed gear bike? That is when I get in an emergency stop situation in the first few weeks will I forget.
Will I adapt switching between my other bikes with levers reversed?
Yeah I know I can try it and find out, but each swap means re-wrapping bars.
Al
Questions:
Al
LF for the accentdeprived
I have no experience in this, but I'd certainly switch on all my bikes at the same time. It's enough to pull the wrong one too hard once...
Well, actually, I'd leave the levers as they are now.
re:member
Bikes: unknown make TT bike, fixed; Romet Sport, gone; titanium Pinarello gone;Colnago with Campy C-Record/Super Record,on it's way; Funny Gianni Motta; Buehler track, Polrad track chrome; titanium MTB on 28'', fixed; Tri Wheeler, fixed
Questions:
Al
Questions:
Al
On the other hand after first half mile I no longer try to stop/slow with my legs on my road bike, nor I fumble for hand brake on a fix. Somehow you are subconciously aware what bike are you on.
spin
Bikes: raleigh m-60, azonic steelhead, schwinn world sport fixed gear
I have my levers the regular way on my ss MTB but the front brake is on the right on my fixie I have no problems going back and forth...although my MTB is basically only used on the trails
Arizona Dessert
Liked 2,169 Times
Hey, I appreciate the responses! Makes me think twice about doing it. The only reasons was so I could mount a mirror into the end of the left side of my bullhorns which the TT lever is now occupying.
Al
Al
Bikes: DW
when i had a brake on my bike it was on the right. reason being my last bike was a dj set-up, rear brake only, so i got used to the idea of my right being my braking hand. if i was switching between bikes and one was going to stay on the left i wouldn't do it.
i don't think it will be bad at all. if you get used to the fixed setup, you'll accidently squeeze your rear brake on the road bike. its not like that will kill you, and i'm sure you'll notice, and catch on to use the front as well in most situations. and on your fixed, it'll be pretty hard to mess up, since theres only one lever.
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
I run the front brake on the right on all my bikes that have front brakes so they'll match the setup on my motorcycle. Was too confusing otherwise. But that is just me, you'll never know for yourself until you try.
I built my fixie up days before moving off to school, without my road bike. Fixie is right hand front brake, road bike is normal (left front). Once during the first week on the fixie, I grabbed for both brakes, even though there wasn't one to grab on the left (Didn't squeeze the front brake too hard or anything, just my left hand kinda flinched). I was off the road bike for a couple of weeks, but was home and rode it, the only time the brake position screwed me up was when I was about to start, and I grabbed the right brake and leaned forwards, to lift the rear wheel off the ground so I could adjust my pedal position. I quickly realized that I was grabbing the rear brake, not the front, and that I can back pedal on the road bike.
You'll be fine.
You'll be fine.
Senior Moment
Bikes: Gunnar Street Dog, Gunnar Roadie, Lotus Elan FG Conversion (in pieces), Trek 850 Antelope
Questions:
Al
Al
Seriously though, you should be fine. I switch bars, bikes, etc often enough and haven't had any problems.
Although I suppose it could happen, I'm just too lazy to move things around sometimes.
I run the front brake on the right because I was used to that from motorcycling, but it works well for me for a couple of other reasons too. mainly if I am carrying something, or towing another bike by the stem I use my left hand for that. going down hills with extra weight, and only 1 brake it really NEEDS to be the front brake.
Arizona Dessert
Liked 2,169 Times
Originally Posted by bostontrevor
I run opposite setups on my fixed gears and road bike. I have not died. Go for it.
Al
'possum killer
Bikes: mountain bike (Litespeed Pisgah), touring bike (Giant Frankenbike), tandem (Burley Samba), fixie (Raleigh Rush Hour)
Liked 8 Times
I run right-hand front on my fixie. Left-hand front on geared bikes. I haven't had a bit of problems adapting. Forgetting I can't coast on the fixie...that's almost thrown me a few times.
Now Wheaties are cheaper than gasoline!
