Marathon Racers for touring?
Bikes: Dahon Mu P24, Trek 7300
Anyone uses Marathon Racers for touring? Or is it too crazy of an idea? I use them for commuting outside of winter, but I wonder if they would be suitable for touring (paved roads, some dirt roads, very occasional "recreational" paths). The sidewalls are thin and light, and I wonder how they would handle stuff like gravel, some stones and roots. Real life experiences?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
I started a tour NY to LA on the tires. Average 260 miles per flat, untill I took them off. 700 X 32 Marathon Racers tires.
Fred "The Real Fred"
Bikes: 2000 Specialized FSR, 2008 Cannondale T1
Yeah, I started a tour with Marathon Racers too, made it from Alberta to southern California but got quite a few flats along the way... Switched to XRs and went thousands and thousands more kms before the next flat. Sadly, I don't think you can find many of those around anymore... Definitely wasn't super impressed with the Racers.
Bikes: IF steel deluxe 29er tourer
The Racers wear out pretty quick. But so do the Supremes. Fortunately, I have a 5 year stockpile of XR's.
Bikes: Cannondale t1, Koga-Miyata World Traveller
Marathon Racers came stock on my Cannondale t1. I have just about worn out the rear tire and have purchased a new one to put on. I've only had one flat.
Now that I've said it, the flat gremlins will pursue me with a vengance.
From what the others have said, I must be lucky, or something.
I nearly bought a pair last summer, but ended up going with reg msrathons. In my case, I went for the deeper tread and tougher construction as the weight gain wasn't a factor given that I nearly always ride with a pannier of stuff, or two panniers full of stuff, so a few hundred grams diff is nothing. Plus I ride my other bike when I want to go faster.
That said, I've ridden on dirt roads and over roots etc with 28 slicks, but a tougher tire is usually a better idea if you specifically plan to ride on rough stuff with a load--that's my take on it anyway, good luck with your choice.
SurlyLHT26in08
Touring
13
03-23-16 04:24 PM
wheelinthai
21
01-27-15 10:53 AM
