Super Record Brake levers
Bikes: BH Turbo single speed,Tommasini Super Prestige,Torrot Tourist ,Vanni,Detto,Colnago Super.
Quoted: 5 Post(s)
Just aquired a mid eighties Colnago Super that has had the gearing changed in the past to shimano hyperglide , I want to put it back to all Super Record as per original but would prefer aero brake levers, do Super Record brake levers come in aero/non aero like the C Record ones . All the Super Record levers i have come accross appear to be non aeros .
Quoted: 7349 Post(s)
Liked 2,474 Times
They were all non-aero.
Quoted: 3814 Post(s)
Liked 3,345 Times
SR levers exist in two reaches. Launch was ~1974 and in ~1976 reach on Campag levers was reduced.
Maybe a pair of Modolo Kronos or Orion?
These were often used with the SR groupset in the first half of the 80's.
But foxy people could transform the SR to aero. In 1984, the great Bernard Hinault competed in the chrono stages with these.
And there was also a way to bring the cable down in the arch of the brake lever, but I recommend this only to a strong twist.
Liked 2,474 Times
What a great picture. I loved Hinault and Lemond.
So a mechanic drilled holes in the bodies of the levers to change the cable routing?
Francesco Moser was the most outstanding TT competitor of his time and one of my personal favourite. But when Hinault took part in Giro in 1982, he won both time trial stages in front of Moser. (but this picture above was made in 84)
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
The aero mod to SR levers is interesting. Did the brake cable make a sharp bend? I'd worry about that for longevity, not important for a team bike where brake cables could be changed frequently of course.
Liked 2,474 Times
Oh come to think of it, I saw it done in summer of 1979. I was working at a bike shop, and another mechanic was doing it to his race bike. I ridiculed his effort, but he said that in races, little things add up.
Quoted: 392 Post(s)
Liked 49 Times
In the aero mod, does the brake cable and housing run inside the bar? Or does the cable exit the brake body next to the bar and the housing run outside the bar and under the bar tape? Eyeing my SR bike...
Here is the crazy another semi-aero way.
Bikes: Caylor, Basso, Sannino, Colnago, Masi
Quoted: 38 Post(s)
I recall seeing a few of the mutilated levers around that time. None of them seemed to work all that well and of course on a TT bike they didn't have to. I'm not an aero hater or above using the aero levers. I have a pair of early Shimano aero levers with white hoods on my Colnago Super and feel no shame whatsoever. And they work just fine and have for some considerable time now.
I think both of these solutions are feasible, though I only saw the in-bar variation. Probably the Modolo Kronos provided the pattern where the cable could be only inside. (There was someone who dropped out of the plastic house's corner to guide the cable under the bar tape.) At the other and later aero levers ( C-Record, Shimano AX and 7400, Aero GC), the out-bar was more common.
Quoted: 38 Post(s)
The cable holes in the bars provided fine places for the bars to break and what with Joe Blow doing it the breakage was not uncommon. But of course, there were always people who just had to try it hahahaha Gotta love that can do attitude ..................
Quoted: 1641 Post(s)
Liked 831 Times
I have a Giro D' Italia Cinelli bars that game with my Montello when I bought it as the third owner. It has holes on the bar where the tops of the lever bodies land, when installed and on the reinforcing sleeve on both side of the knurled surface for the stem to clamp on. First I thought it was a home made jobbie, but after examining the way the holes were drilled, I determined that it was done by Cinelli at their factory as it looks like you need to use specialized drilling equipment to come up with the unusual angled extended mousehole shaped (domed on one end and flat on the other) profile the holes near the stem has. I also saw another example in the net with exactly the same shaped holes, further evidence that Cinelli did issue bars with holes drilled for routing cables in them. I guess eventually they just went to the grooved bar design that must be much easier to produce and does not bring up the question about possible structural compromise from drilling the bars.....
the GDI bars now live on my just completed Bottechia. The brake cables were a bit of a challenge to install, but after doing one side with the help of some string and a powerful vacuum cleaner, the other side was a cinch after that....
So far I only thought the 3ttt Paris-Roubaix was the only factory aero bar in this era. Although I saw some pictures of Cinelli, but I thought the framebuilder was drilling the holes on it. For example, on this sensational Ciöcc.
or this aero Battaglin
Quoted: 3464 Post(s)
Liked 2,831 Times
Interesting the position of the Modolo Aero levers on both of the bikes imaged for a catalog.
Note the size of those chainrings on the Ciocc, and the weird angle of the front brake and fork orientation in the inset image.
I bought a bike with those levers, nice seller provided me a set of NOS NIP hoods for same.
I removed the levers and they sit in a box.
The front brake position is similar to Hinault's Gitane:
At that time, they experimented with them. On Daniel Gisiger's Bottecchia mounted the rear brake to front of the seat stays, similar to the Colnago Oval CX.
Scott 'superbrake' was shown with the cable head, and housing reversed,
in a non modified brake lever,
BITD. like done on that Moser TT bike.
