Battery repair
Quoted: 137 Post(s)
Liked 81 Times
Battery repair
I have a 3 yr old 48v 17 ah down tube battery I got with a Bafang bbshd kit with a problem w the on/off switch. A half a year ago the rocker on/off switch was inconsistent turning on so I left it on all the time then it started cutting out when hitting slight bumps. I知 usimg a cheap spare battery I got from Amazon. Curious if other folks have had similar problems. I ride off road most of the time and assumed the battery can take the vibration. I知 hoping this might be something I can fix myself once I have enough understanding of the problem. I figure shipping and repair costs would get me 25%+ to a new battery so gathering info now. While I ride off road I知 67 and not going off jumps, 10-15 mph is my speed.
At 3yr old, you're starting to approach the lifetime of the battery. Li-ion chemistry starts to degrade at around 3yr and generally progresses more quickly as time goes on. Might not be worth fixing.
You'd have to take it apart to see how it was built . Often those packs are not soldered but spot welded almost so fixing them can be difficult. I doubt you're going to get anyone to fix it because no one would want the liability of the battery pack not knowing what it's been through (fire danger etc...) or the quality of it's safety circuits. It's kind of a lawsuit waiting to happen.
Quoted: 340 Post(s)
Liked 276 Times
Depends on the battery and your skills. Some switches can be replaced with the same switch or a better one.
Might be OK to simply bypass the switch and leave the battery permanently turned on, like you already do. I only turn off my batteries that have LED lights glowing blue or red. Otherwise, I leave them turned on too.
Quoted: 883 Post(s)
Liked 824 Times
Battery life depends on the battery too. I have a Haibike hardtail MTB with a Yamaha system that's six years old. The display reads the battery's state of charge (SOC) in percent. I've maintained the battery at 30% - 70% SOC and AFAICT it's still working great. The other day I rode about 10 miles of varied off road terrain in ECO mode (I seldom use any higher setting) and the battery used about 80 watt hours or 20% of its capacity. This suggests the battery is still capable of 40 miles or so.
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 207 Post(s)
Liked 269 Times
Most battery cases are pretty easy to take apart. If it's cutting in/out while you're riding, my bet is on a loose wire somewhere. Shouldn't be difficult to diagnose and repair. I have many electrical devices that use batteries, and 3 years is not enough time to get rid of a battery. Sure it will lose some capacity, but there's still years left.
Likes For XxHaimBondxX:
Before attempting any repairs, make sure to disconnect the battery from the system and follow proper safety precautions. Additionally, consider reaching out to the manufacturer or dealer where you purchased the e-bike kit for guidance and possible warranty support, especially if your e-bike is relatively new.
Bikes: 3
For my Ecotric 36 volt electric bike, this battery went right into the bike without any issues. I did need to use the included slide lock bar, because the hole for the battery lock was in a slightly different position.
Easy 1 screw change out. Battery came out of the box with more than half a charge so I was able to test it out immediately.
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
I've had issues with my charging jack on a RAD City bike. I had to remove the case and the charging plug interface was easy to work on. I did this work outside on a large patio. If you get one of these batteries burning by accidentally shorting it out you want lots of room outside around it so it won't burn down your workshop/home. The charging jack on mine needed some tightening however I could have done solder work where it was located with no problem. The battery cells were in a large welded tab assembly below the charging jack assembly and I didn't have trouble keeping away from them while repairing the jack. This simple cheap repair kept an expensive battery pack on the road where it is still working to this day.
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 238 Post(s)
Liked 323 Times
There are two factors with the battery vibration:
The battery mounting arrangement is something that deserves a lot of engineering effort, even on a road bike. (some roads will be even more jarring than offroad situations; with busted concrete...)
- Vibration of the battery itself, relating to its internal components
- Vibration of the battery against the mount on the bike.
