Need to strip 0.1 mm off some derailleur housing for ferrule
Quoted: 1163 Post(s)
Liked 441 Times
I need suggestions on a slick way to remove just a very small amount of clear outer housing on Jagwire housing that is about 4.6 mm outer diameter. The derailleur housing is Jagwire woven stainless steel look, gold color with a glossy clear cover. I’m needing to extend them a short length due to miscalculation. I did a nice tape job on my bars and the housing exits near the stem and plunges down to the down tube braze-on adjuster. The regular ferrules fit fine but i’m trying to use a double ended ferrule in order to gain about 3” extra. I found some nice Jagwire ones at the bike shop for $2 each that should work but don’t. The inner diameter for the double ended ferrule is ~4.5mm, 0.1mm too tight.
Is there any handy way to ream the ferrule to gain the clearance I need? Or, what would be the most efficient way to strip away some of the clear outer cover to create a perfect fit?
I know i’m over thinking this but sometimes it’s the little annoying things like this that really mess with your mind!!
Thanks for any help.
With a pair of reading glasses (it happens to everyone eventually...) and an Xacto knife that would take like 3 minutes. But yeah, sandpaper should work too.
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
Ditto the sandpaper. I've done it a couple times to clean up the plastic when it expands from heat created when I grind the end of the housing flat.
Jeff Wills
Jeff Wills
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
razor knife with a fresh blade.
Quoted: 136 Post(s)
Liked 57 Times
If you go with a blade, use it 90 degrees to the housing to scrap vs slice off the excess. trying to slice it off will be a disaster (I've done this with other items)
Quoted: 1438 Post(s)
Liked 1,092 Times
You might be able to heat the plastic cover with something like a hairdryer, enough to insert it into the ferrule. Or try dipping into alcohol or hot soapy water and just shoving it in. If you only have 0.1mm interference it might go right in.
Licensed Bike Geek
Isn’t there a step-down 5mm~4mm ferrule?
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
.1mm equates to .004". A piece of notebook paper is .003" thick. I think the sand paper will get rid of your excess thickness in about 3 heart beats.
Jon
Jon
Liked 441 Times
https://flic.kr/p/22ePwyJ
Thinning the outer housing with a diamond Swiss file had been my plan. Problem is, the weave or mesh is just below the clear outer cover and it appears quite delicate. So reaming out the double ended ferrule (and leaving the housing alone) seemed the more satisfying course of action. I used a 3/16” reamer at low speed in my drill press with some tap oil for lubrication & it worked great!
https://flic.kr/p/21cKAfm
PS: I’m using Flick’r for my images which does appear to work to create a link. But my desire is for the image to immediately pop up without clicking the link. Can someone tell me how to use Flick’r more effectively?
Liked 441 Times
https://flic.kr/p/CDtMHM
Here you get a view of last week’s fresh tape job with the too short derailleur compressionless housing...
Liked 441 Times
“Extenders” in place on compressionless housing: https://flic.kr/p/22i4vae
