Quintana Roo PR5 and PR6 Fork and Frame Design Flaw
Bikes: Trek 5000, Quintana Roo PR5 2018
The Quintana Roo (QR) PRFive Frameset (S/N: F1611M3212) that I purchased in September of 2017 has an obvious design flaw related to the Frameset's frame and fork tolerances. When the fork assembly (front wheel) is turned to its limit in either direction, the front edges of the frame make direct contact with the side surfaces of the forks. This contact is atypical of a "high end" triathlon bike and causes the frame to dig into the painted carbon surfaces of the forks. This isn't ordinarily an issue when racing but often occurs when moving the bike from place to place and the handlebars turn left or right as a simple result of gravity when not holding the handlebars.
The solution to this problem, as described to me by the bike shop where I purchased the frame, is the application of clear "stickers" to the side surfaces of the forks. These "stickers" are not substantial enough to prevent the front edges of the frame from digging into the painted surface of the forks nor do they prevent damage to the frame itself. The bike shop expects that I'm supposed to replace the stickers with new stickers when the original stickers wear out. When the stickers are removed, they also peel paint off of the forks. Hardly a solution for a $3200 frame.
Has anyone else experienced this same problem with Quintana Roo PR5 or PR6 or know of a fellow triathlete that has experienced this problem?
Quoted: 30 Post(s)
I’d reach out to QR on that. That’s not even 6 months. What will that look like in 2 years!
Tell the bike shop to keep the clear stickers and get off their behind and help you warranty it.
Sr Member on Sr bikes
Dan
Chases Dogs for Sport
I would guess that QR doesn't think you'll ever actually ride the bike with the fork turned that far -- and they're almost certainly correct. But still, a rubber bumper or internal stop of some sort would have been a better solution.
OP, let us know what QR does about this.
I ran into the same problem and asked my LBS for warranty
Waiting for response so far
Were you successful in asking for warranty? I feel this is a design flaw and QR should consider recalling the fork for safety reasons
Quoted: 4722 Post(s)
Liked 3,038 Times
The frame and fork are designed for optimum aerodynamics when traveling in a straight line. Consequently, the fork will be wider at it's leading edge and taper to where it meets the frame. When the fork is turned far enough, the wider section will contact the frame, but normally this limit wouldn't be reached even at the turn around of a triathlon bicycle course. IMO, it's a very minor drawback for having an aerodynamically efficient bicycle. Anybody who rode during the days of down tube shift levers will be well aware of the chips on the side of the down tube, caused by the front brake caliper's barrel adjuster (even when they had a rubber bumper), when you let the wheel flop too far. Nobody complained about it being a design deficiency.
If this was aluminum, I would have agreed with you
But this is carbon fiber
and QR corrected this on the latter models by replacing the part where the fork hits the frame with rubber contact point
so they clearly acknowledge this issue
