Frame ID by headbadge?
Bikes: Lots of French, some British and a couple of Italian
Quoted: 247 Post(s)
Liked 130 Times
I've been trying to work out what this frame is for years... literally. For the first time, a couple of weeks ago I noticed there was a single hole for a badge in the HT and what looks like a fairly square surround where the badge would be. French BB, nicely made, has been the subject of another thread a long time ago!
Any ideas from the knowledge bank? Thanks all...
Milo
Milo
Shifting is fun!
Bikes: Yes, please.
Quoted: 2196 Post(s)
Liked 4,595 Times
If glue and hole are related to the same badge (which they might not be), my guess would be that it would have been a badge similar to this one, with a small "pin" on the back that fits the hole to facilitate correct placement.
Quoted: 4722 Post(s)
Liked 3,036 Times
+1, it appears to be for an adhesive backed badge with an alignment pin. These were typically used by the major brands, so I'd expect a serial number that may aid in identification. The investment cast bridge with tangs suggests a higher grade frame though the finishing looks rough on the chain stay ends. Also, the the dropouts are either Simplex 4264/65 (with eyelets) or 4266/57 (no eyelets) which makes it no older than the 1981 model year. Simplex was a shadow of it's former self after the 1985 bankruptcy, so it's most likely 1981-1985. For instance, even Peugeot, who had a very close relationship with Simplex, had it's USA product range diminish from seven Simplex models in 1984, down to two Simplex equipped models in 1985 and zero Simplex equipped models in 1986.
Quoted: 247 Post(s)
Liked 130 Times
Now you say that, it does look much more like a locating pin hole than screw hole.
So, when I first got it, it had Gitane decals, and @verktyg identified it as a Non-Gitane. This album is how it was when I bought it, and here's the thread on Gitane USA.
Serial 9123003.
You lot are pretty darn good at this stuff. Thanks!
Serial 9123003.
Shifting is fun!
Bikes: Yes, please.
Liked 4,595 Times
At first glance, all circumstantial evidence seems to point towards an early eighties Peugeot PX10, known as the "Super Competition" (the PV10 also carried that name, but had mudguard eyelets).
I have two, one with just a sticker on the head tube, but this one has the plastic badge, similar to the Motobecane item above:
Quoted: 247 Post(s)
Liked 130 Times
OOh that would be a good thing! LOL... Is your white steed simplex dropouts? Looks like it and the short point lugs as well!. Looking at it the chrome fork fits but mine has partial chrome on the rear end. Is it by any chance Simplex/Spidel equipped?
Shifting is fun!
Bikes: Yes, please.
Liked 4,595 Times
Yup, Simplex dropouts on the ones I have. Parts are a mix of MAFAC levers, Weinmann brakes (called "MAFAC 605" in the catalog ) and Stronglight cranks. Here's my other (slightly nicer, albeit with a Shimano 600 EX transmission and chain set) PX10:
I haven't got any better pics currently, and both are in storage, so I can't easily get to them. However, you should be able to find lots of detailed pics online, if you haven't done so already. The chrome rear could be a case of just chroming the ends for durability and painting them over. I have seen that before.
Quoted: 247 Post(s)
Liked 130 Times
Thank you non-fixie, I've been looking at pics and I've found a match for the fork, lugs and chrome. Looks like a PY10. I also looked back at the original gitaneusa thread and I think Chas had it spot on. The pic of the seatstay caps is deceptive, they are flat. At least one pic I found also has the 531p decal, so all very good! Sleep now, more research tomorrow...
Quoted: 247 Post(s)
Liked 130 Times
Well there we go. Coffee this morning and a 22 page thread about PY10s. The serial number fits, the lugs and chroming fit, seatstay tops are the same, so I can peel the rest of the Gitane decals off and think about what to do with it. It may be the recipient of the very good condition 600 arabesque group I recently acquired. I'm waiting for approval on the French forum to be able to post it, but i'm fairly convinced it's a December '79 for the 1980 model year. On my Strava profile this frame was called The Old Git. I'll have to rename it.
Have a fine weekend folks.
Shifting is fun!
Bikes: Yes, please.
Liked 4,595 Times
PY? Of course, the chrome. Cool! Enjoy!
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Peugeot? non!
@MiloFrance
The more that I look at your frame the more questions come up.
It has Nervex Dubois lugs which Peugeot used plus late model Simplex dropouts. It looks like a Peugeot Reynolds 531SL fork from that era. In 1982 Reynolds changed the name from 531SL / 531 Super Legere to 531P or 531 Professional. But, bike manufacturers probably had old decals so there could be some overlap.
The big question is the seat stay tops. I've never seen those fluted plugs on a Peugeot.
Motobecane used this style plug from 1977 until the 1980's. They never used Nervex Dubois lugs.
It could have been a frame that came out of Peugeot's Prestige custom/team/special order shop?
Also, I have Peugeot and Motobecane plastic head badges and there is no pin sticking out the rear.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 247 Post(s)
Liked 130 Times
Chas ( @verktyg ) As mentioned, the photo is a slight illusion. Here is the side by side from the PY10 thread linked above, and my blue thing you helped me with in 2014... I think it's pretty darn close
verktyg
Liked 1,238 Times
Peugeot oui
Some info on those PY frames:
ipernity: 1982 Peugeot Pro-10 - by Peter Kohler
Peugeot PY10 1980 - finished | Retrobike
Mystery solved!
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 247 Post(s)
Liked 130 Times
Now I have 99% certainty of what it is, I've just treated it to a wipe over and the paint is not good in a lot of places. Some of it came off with the peeling of the Gitane decals, and the metallic blue is so thin that the white primer is showing in others.
As it's not original, I'm thinking it's not that big a deal to repaint. I have a lot to do so it might take a while, but quite tempted to try the home powder coat method in the wooden box.
Either way, as was my answer on another recent thread, I like tube sets and provenance, and I now have both on this one.
Quoted: 247 Post(s)
Liked 130 Times
I've decided, I'm going to repaint it. I have a plan which may take a while, but I'll try and document it for a separate thread.
Quoted: 247 Post(s)
Liked 130 Times
Well. The repainting plan with Spray.bike didn't go to plan. If you didn't see the thread, my bodyshop owning friend took matters in to his own hands. This is what he sent me last night.
Quoted: 247 Post(s)
Liked 130 Times
And this is what it looks like on camera. In person it's gobsmacking. The white is pearlescent, as are the red and blue, and when the light hits it it's utterly gorgeous. I had spinal frissons when I was admiring it...
Bad example
Quoted: 823 Post(s)
Liked 202 Times
Wow.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Very nice!
obrentharris
Classic & Vintage
31
02-28-18 06:39 PM
ElStellino
Classic & Vintage
51
11-13-14 06:46 PM
messyprofessor
6
05-30-13 01:29 AM
