How to bore a MTB Shifter to Fit on a Dropbar?
Quoted: 761 Post(s)
So want to put the Shimano SLX 7000 shifter on dropbars. Everything is bought.
Being a MTB shifter the clamp is bored for 22.2mm but the drops are 23.x.
Removing 1.xmm of ALU cant be that hard can it or am I missing something.
I was going to try just using sandpaper on my finger to start with.
Quoted: 18354 Post(s)
Liked 4,502 Times
It looks like you should be able to take off a half mm of material, and still be fine. Don't take off too much. The strap may almost reach as-is if you used a longer bolt. Anyway, you will want a tight fit.
I'd probably use a round file or a small drum sander.
Have you seen the Microshift Mega 11-Speed MTN Bar End Shifters?
https://www.microshift.com/en/product/bs-m11/
Quoted: 2026 Post(s)
Liked 1,095 Times
Sandpaper wrapped on a wood dowel will probably work faster and do a more even metal removal job.
Quoted: 2480 Post(s)
Liked 2,948 Times
Just did a search, and it appears that inexpensive aluminum 25.4/22.2 drop bars are available. Use shims from a beer can at the stem and you're in business.
If you go the sanding route, wear eye protection and a respiration mask.
Reaming
You are removing 1/2 the differences in diameters , the measurement is a radius..
I use bar end shifters on all my drop bar bikes,
Trekking bars are 7/8'', 1" center,, they use MTB/straight bar controls..
also offer a lot of variety in hand holds..
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), Yess World Cup race BMX, Redline Proline Pro24 race BMX Cruiser
Quoted: 345 Post(s)
Liked 186 Times
