Trainer Tire
Quoted: 941 Post(s)
Liked 319 Times
Trainer Tire
Considering using my gravel/adventure/whatever bike on an indoor trainer. I'd like to use a trainer tire, but Googling around seems to suggest they cater to road bikers. All I found were 23-25mm tires. Does anyone make on 38mms? Might work with a 35mms, but haven't found one of them either.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Quoted: 941 Post(s)
Liked 319 Times
Haven't really measured it actually. The bike originally had 42mm knobbies as I recall. I changed them to 38mm's with a smoother tread so just trying to come close in terms of width.
Quoted: 353 Post(s)
Liked 92 Times
The size of the tire is irrelevant on a trainer as the height of the wheel axle relative to the floor is always the same and the resistance unit is what is adjusted to accommodate tire size. You gain nothing from using a larger tire vs a skinny one. Get yourself a super cheap wheel to use strictly.as trainer wheel with a normal trainer tire and you're set.
Quoted: 4560 Post(s)
Liked 2,803 Times
Continental Ultra Sport II is cheap and available up to 700x32. The 700x25 has held up so well I use the same tire/wheel on both my Cycleops trainer and on the road.
Quoted: 941 Post(s)
Liked 319 Times
Thanks for the input and suggestions. I was operating under the assumption that the rim would be too wide since it originally had 40mm tires mounted.
Quoted: 101 Post(s)
Liked 41 Times
I’d look for any appropriately wide tire with a smoothish tread. I have a road bike that lives on a trainer full time, and am on my third rear tire...first was the tire that came on the bike, a 23mm road tire, second was a 23/25 mm “trainer specific” tire...both lasted about 5k miles. For my third tire, I bought the cheapest house brand sale tire from Nashbar I could find, a 25mm city/commuter tire with thick rubber but a smooth tread...all signs point to it lasting 5k miles as well.
