Freewheel options
Freewheel options
I just removed my back wheel to get it trued up and noticed that a few gears are missing a tooth. Does anyone have suggestions or leads on a 6spd freewheel replacement that won't carry an eBay "vintage" premium?
The freewheel in question is a 13-26 Shimano mf z012. Rear spacing is 126, rear derailleur is a Cyclone MK-II that maxes out on a 26t cog.
I'm planning a trip to the coop this afternoon but not sure what condition theirs would be in. I'd hate to put a new chain on a busted up freewheel.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 530 Post(s)
Liked 1,004 Times
Are the missing teeth actually broken off, or are they just shorter than others? Normally some teeth are a little shorter to facilitate better shifting. The short teeth should be distributed around the cog in a regular pattern.
Oh that's interesting. Going back to look it does seem like maybe they're just short. Either way I'll probably look for a new one since I'm putting on a new chain.
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,194 Times
Can you post a picture of your freewheel. It might not really be all that worn and won't need replacing. Sometimes a good cleaning and service will bring it back to nearly as good as new.
Bob
Bob
Bikes: K2 (Marzocchi/Fox), Trek 6000 (red) MARS Elite up front, Specialized Hardrock Sport -> eBike (R7 Elite up front), lastly TREK 820 loaner. Recently sold Peugeot du Monde Record and 1956 Schwinn (owned since new).
Quoted: 75 Post(s)
Yeah, broken. Can't answer your question about anything not carrying a "premium". But eBay is still your best bet for a replacement ...
Quoted: 530 Post(s)
Liked 1,004 Times
I agree, the third cog has a broken tooth and a chipped tooth. The fourth and fifth cogs were made that way.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,831 Times
The inexpensive SunRace are not great.
I have bought 3 and won’t buy again.
Freewheel Medic
Liked 2,194 Times
I have a spare 13-26 Shimano of the same vintage. Let me know if this is of interest to you and we can work out a reasonable price. I'm also about to clean and service a modern Mega Range Shimano 6 speed. It's all chrome so it doesn't have the final black sprocket like most do. However, you have to like 13-24 five speed with the added bonus of the 34T bailout.
Bob
Bob
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
I bought one for the univega I just sold -- a 7-speed sunrace using SIS 8-speed shifters and 6400 rear mech. It indexed perfectly.
For new freewheels, I prefer IRD, but mostly for appearances. They're a little pricey in comparison.
Actually, the only "new" freewheel that ever failed on me was an IRD I inherited from a donor bike. I emailed IRD about the busted pawl, and they sent me another for free.
The biggest problem I have with sunrace is the model the ebay seller ships me is not always as described. So I usually verify it's actually the pretty silver finish model when I checkout, instead of some fugly black one with that horrible bright white logo crap on the big cog. I can't simply remove it with acetone. Shimano does it, too, and it's grotesque and should be stopped out of common decency and all things good.
Veteran, Pacifist
Liked 4,831 Times
My SunRace experience:
1 of mine works great
1 very loud pawls - very loud & replaced
1 would not spin on hub cleanly, still unused.
YMMV
edit: my freewheels all 6 speed
YMMV
Broken teeth, well ridden with little or no PM and looking pretty crusty at this point. Most of the wear on a sprocket is actually on the underside, but from what I'm seeing I don't believe it is worth servicing at this point.
Quoted: 4559 Post(s)
Liked 2,802 Times
SunRace freewheels seem reasonably well made and affordable, but quality control varies. I'd buy 'em again, considering the low price.
The 13-25 7-speed MFR30 chromed SunRace freewheel is fine on my Centurion Ironman. Shifts better and runs more smoothly than the original Suntour 13-24 Alpha. I've used it on all three of my bikes over the past couple of years, no problems. I'm looking for the 13-28 version but can't find it on Amazon.
The MFM2A SunRace 7-speed, 14-28, is a bit loose and rattly. I don't have the tool to tighten it up. It's on my errand bike which is mostly used for short rides to haul groceries.
My pet peeve is the Shimano MegaRange freewheel. There's too big a jump to and from the largest cog, which makes for some really awkward shifts on climbs. And the MegaRange is really picky about chains. Anything other than Shimano or KMC "narrow" chains will skip over the teeth under load. There isn't enough clearance between the teeth and spacers to use some chains. No such problems with the SunRace.
señor miembro
Liked 6,476 Times
Freewheel Medic
Liked 2,194 Times
…My pet peeve is the Shimano MegaRange freewheel. There's too big a jump to and from the largest cog, which makes for some really awkward shifts on climbs. And the MegaRange is really picky about chains. Anything other than Shimano or KMC "narrow" chains will skip over the teeth under load. There isn't enough clearance between the teeth and spacers to use some chains. No such problems with the SunRace.
My observation of Sun Race freewheels is that the sprockets seem to wear out rather quickly when compared to vintage freewheel sprockets. Possibly the metal is softer?
Bob
Bob
incazzare.
You can buy new Shimano ones still, but I think they're all 14-28. Are you 100% sure you can't do a 28T cog?
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
I'd say 90% sure. According to Velobase the Cyclone MK-II maxes out at 26. According to the Disraeli Gears site I think it said 28 was possible if you use a longer bracket. Since I'm on forges dropouts and I've never measured the distance, I was always erring of the side of caution. Although having a 28 would be beneficial with all the hills around me.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
I purchased a 105, 6 speed, 14/28 freewheel from E-bay a couple of months ago. It was new and my memory is that it was $14 with free ship. I can check my E-bay order history and get the right info, including the seller. I bought because after putting on a new chain the gears were slipping. I also purchased new 105 chain rings, 53/42, off E-bay. They were on sale for $10 each. I cannot recall the seller but can find that also.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
The seller for the freewheel was kingpaguy and the seller for the chain rings was bikewagon. I have purchase numerous items from bikewagon and have been highly pleased with them. Quick shipping and good communication.
Pedalin' Erry Day
I've had a similar failure rate: I've got two bikes with SunRace freewheels that are doing just fine, but I've also had two of their freewheels give out on me - they stopped spinning freely, then developed extra play, then started to do what felt/sounded like internal grinding, at which point they were replaced. The common factor is that the freewheels that suffered were both used on commuting bikes at sub-freezing temperatures, while the two that are still working are on bikes that I don't take out in inclement conditions, so it may be that there's something about the metallurgy or factory lubrication that's not designed to tolerate those conditions.
I have several Sunrace freewheels in service and they have yet to fail, however I lubed them with Phil Wood Tenacious Oil before they were put into service. Had a Shimano freewheel freeze up once, flushed and lubed fixed it.
If you can handle a 24 tooth as a low gear, take the Shimano Mega Range freewheel and cut the 34 tooth off. I have done this twice and it works very well, plus gives a bit more space between the spokes and rear derailleur when in low gear.
Liked 2,802 Times
Some rides, like today on some climbs into the wind, I wish I could find the 13-28 version, chromed, but I can't find one in stock anywhere. Might need to order directly from SunRace.
The MFM2A 7-speed SunRace 14-28 freewheel has only a couple hundred miles on it at most. The six smallest cogs are browned carbon steel. The 28T big cog is blue/black steel, resembling the Shimano MegaRange style. But there's no objectionable jump between the sixth and seventh cogs. It looks more cheaply made, and developed a rattle. I couldn't loosen the lockring with a punch and hammer to see if I could snug up anything so I'm just gonna let it go as-is. But it should be okay on the errand bike. It doesn't skip like the MegaRange tended to when it wasn't paired with a chain specifically marked narrow.
BTW, is it true that freewheels 7-speed and up aren't as well supported as comparable 7-speed and up cassettes on the smallest cogs? Don't remember where I read that but it preys on my mind every time I stand to stomp up a climb instead of shifting down. I suppose if it was a serious problem big guys on the pro tours would have broken a lot of hubs and freewheels and we'd have heard more cautions. I'm not sure how credible that one article was. I doubt I'm heavy or strong enough to break anything anyway.
Thanks to everyone for all of your assistance and advice. I currently have a new freewheel on the way but I'll certainly keep some of these sellers and part numbers in mind .
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
They only show up every now and then, but they do show up. My guys charge, at most, five bucks for a Suntour or Shimano 5/6 cog freewheel. So I look every time I drop in (once or twice a month). The prices for the used ones on e-bay are approaching ridiculous at this point, so I always have a couple in reserve undergoing cleaning and restoration. There's good information on removing and replacing cogs on older Suntour and Shimano freewheels, so once you get an eye for what's worn out and what's not, you can usually manage to replace anything worn (it always seems to be the 15/16/17 cogs that are worn out on most of what I find).
Anyway, good luck with it. I can't get a Cyclone rear derailleur with a short cage to handle better than a 26, but they did make long cage ones too. Something else you can look for at the co-op.
Quoted: 18372 Post(s)
Liked 4,507 Times
@The_Joe, other than your one broken tooth, and one chipped tooth, overall the freewheel doesn't look too bad. Does the chain skip?
I'd probably clean the freewheel, and just try a new chain. If the chain doesn't skip, then you're fine. If it does, either put on a new freewheel before it starts getting bad, or try to avoid the bad sprockets, and source a "newer" freewheel for the next chain (depending on your mileage).
You have the old style freewheel, essentially "Uniglide". They seem to be long wearing, but a little klunky with the shifting.
The new "Hyperglide" style freewheels shift like a dream, but I believe also wear faster.
My Closet Masher really likes the DNP Epoch 7-speed 11/28 freewheels. At least the ones I was getting a couple of years ago were slightly wider than other brands, and a tight squeeze on a 5/6/7 hub, but you should be able to make it work with some adjustment.
However, I never liked the gearing progression.
11-13-15-18-21-24-28T
Skipping the critical 12T & 14T.
And, that sent me spiraling down a rabbit hole.
