Help me find a Gravel Bike with Road Endurance Manners
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I've decided to throw this out to the collective knowledge of BF members to see if I'm missing anything in my search for a gravel bike, or endurance road bike with wider tire clearance. I ride mainly crushed-limestone paths near my house and paved roads--nothing too harsh. But I have found that 35c-40c wheels are ideal for my riding conditions, and would like the option to switch wheelsets for road rides as well. I really like the Trek Domane, but it only clears 700 x 35c. The Trek Checkpoint has been at the top of my list, but it is not available with the adjustable rear IsoSpeed (compliance is fixed) . So while I figure out if this is a deal breaker or not, I am considering some other options.
Here are my criteria:
Geometry like an endurance road bike (stable handling, low bottom bracket).
Clearance for up to 700 x 40c tires.
Endurance road bike gearing (2 x 11 with 50/34 up front and 11-34 in the back seems ideal).
Weight that approx. 20 lbs with a 56cm frame, or that can be upgraded easily to be under 20 lbs. Something 21-22 lbs stock will be fine. This probably rules out a lot of steel bikes or heavy touring rigs. I would like to use this bike as a road bike with a second wheelset and lighter 28c tires, so I don't want a tank.
A smooth ride that soaks up vibrations. Not squishy, but not jarring.
Hydro disc brakes and thru-axle wheels.
Budget: $2,000-$3,000
Shimano 105 R7020 hydro is sort of my target zone.
What I've ruled out: The Specialized Diverge, due to maintenance requirements for the Futureshock. I like to do my own maintenance and will never bring a bike back to a shop for anything, so something like that is a deal breaker. The Canyon Grail because of it's wacky dual handlebar. I'm still thinking about the Giant Revolt, but have to figure out why it's so heavy. Perhaps it can be salvaged by swapping out some Giant proprietary parts.
What awesome bikes am I neglecting to look at? Mason? Kona? Others? I can also do a frameset, as I enjoy building up a bike from scratch.
Thank you in advance for your replies!
Last edited by HarborBandS; 03-20-19 at 07:20 AM. Reason: Clarifying weight comment and issues with Futureshock.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
I dunno...under 20 pounds for under $2000 is going to rule out most aluminum bikes on weight & many carbon on cost.
Under 25 pounds might be making in-roads to possibilities for metal bikes. Leaning on the $3000 upper bound might likewise open up carbon.
"Gravel" bikes are trendy marketing. A good CX bike from a few years ago might be a good place to look if you are flexible about requiring that the bike be absolutely new.
If it is disc, many people have had good luck with 650b (27.5) wheels. Just factor that into your cost equation & you might be surprised at how many bikes qualify.
My Scattante (store brand Fuji) was $500 and now weighs under 24 pounds with Gatorskins & fenders. All it required was new everything, but even so, much less than $2-3k
How much does a pound or 2 matter to you?
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
Budget is up to $3,000.
My baseline is the Trek Checkpoint SL5 ($2,800), which weighs in at 21.17 lbs in a 56 cm.
Giant Revolt Advanced 0 is also under $3,000 and in the low 20’s.
The Checkpoint SL5 has 105 on it, so I feel like I could realistically get it under 20 lbs with lighter wheels, 28c road tires, and some key component upgrades. I am hoping to have two wheelsets for this bike--one for gravel with 40c knobby tires, and one for road with 28c or 32c slick tires.
The 1st generation Turner Cyclosys is worth a look I think. https://www.turnerbikes.com/bikes/cy...08050537109375
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I have been under the impression that the newfangled "Gravel Bikes" were more like road endurance geometry, with more relaxed head angles, longer wheelbases, and lower bottom brackets, while "Cyclocross" implied more of an off-road race geometry with fast handling and a higher bottom bracket. So I've largely ignored bikes classified as "Cyclocross". But this Turner actually has a pretty relaxed head angle and long wheelbase.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
cross posted from another thread-
https://www.diamondback.com/road-bik...-7c-carbon-d41 $2160 shipped. Carbon, good components, relaxed HTA with pretty standard road STA.
https://fairlightcycles.com/product/...v=7516fd43adaa A Fairlight Secan is $1200 for the frameset. 2161g frame weight in your size and 425g fork. So just under 2600g total which is 5.75#.
This could be built into a bike thats under 21# with Ultegra Hydraulic drivetrain, wheels that weigh 1650g or less, and quality 40mm tires that weigh 375g or less each. Thats very realistic.
The Secan geometry is pretty road oriented- 77mm bb drop with a 72 HTA and 73.5 STA.and 61mm of trail. 853 main triangle, shaped stays, light carbon fork- pretty killer.
This is what I'm riding. I also bought a set of November Bicycles RCG36 carbon wheels, running Schwalbe Pro One 30mm road tires on them. Run 38mm G One All Arounds on the stock wheels. They are interchangeable, just had to add one disc shim to the Stans hubs to align with the DT Swiss hubs.
https://www.bikebling.com/Niner-RLT-...4-18-47-55.htm
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I can walk to a Cannondale dealer, and apparently have a Niner dealer a half hour away. Might make for a fun Saturday some time soon.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
The future shock has a lifetime warranty and requires little to no maintenance. Whatever noise concerns the future shock had were short lived and have mostly gone away. The recall was a simple collar replacement. The system is pretty easy to work on once you get the process down. Really a non-issue at this point.
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
This is an even bigger issue with the Canyon Grail. If I can't change the handlebars and stem myself, I'm not buying the bike. But at least with the Specialized, I can try it out first at a local bike shop.
I also saw somewhere that the Futureshock (maybe on this forum) needs a polymer replacement every 500 miles. Is this a false internet rumor?
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I'm sure I'd be happy with the Diverge at first. But I tend to keep bikes (or at least frames) for a long time, and do all of my own maintenance. And I often swap out parts over time. Not having the ability to swap out a headset or fork myself to something else is a deal breaker for me. I'd rather just have a standard headset and steerer tube.
As for the service interval for the future shock I believe it is 500 hours of use. And then it is only regreasing and checking for wear. If the cartridge itself is disassembled by anyone other than a specialized dealer they will void the warranty. The cartridge can be removed without disassembly, as well as the helper spring can be replaced by removing the stem and a screw in cap.
How about building up one of the two gravel frame types from Carbonda ?
Good thread on the RidingGravel forum.
Whilst in theory it seems good on paper, the service intervals cost you a lot so you're just paying for the lifetime warranty indirectly when it may not be necessary .... no such thing as a free lunch.
Disclaimer: This may have changed in the last year since I looked at it and discounted buying one on that basis.
I continue to be very happy with My SL5 Checkpoint. I'm quite impressed with the IsoSpeed. Riding near the edge on some pretty bad chip seal roads and it smooths out the ride. I have a friend that has to stay in the middle of the same road and look for the smooth spot on his 28's to avoid being jarred into the next county.
Are Merida Silex's available where you are, they have a few in their range that may be worth looking at depending on cost / preferred gearing.
Sunshine
Liked 7,491 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
One of the Jamis Renegade models?
-Tim-
-Tim-
Quoted: 1872 Post(s)
Liked 692 Times
Man, this is pretty much exactly where I'm at. It's like I wrote the original post. *following*
2019 Salsa Warbird
2019 Salsa Warbird
Thanks, that one was definitely not on my radar!
It can be made even gravelly-er by running 650bx47; it is compatible. Scroll down a bit here: https://www.cxmagazine.com/turner-cy...sea-otter-2017
Quoted: 6969 Post(s)
Liked 10,966 Times
