Tires - Road/Gravel, bigger than 700c x38mm
I have a number of decisions to make for my next bike. Because of the type of riding I do, I need to choose between 650b and 700c. I ride on extremely bad paved roads and gravel. Some rides are 50% of each, but even if it's mostly paved the roads are so bad most of the gravel is easier and nicer than the pavement. I have been riding on 700c x 38mm panaracer pasela tires. I now consider this size to be the minimum for me and would like something a bit fatter if I stick with 700c, but would not like anything knobby.
Any suggestions for 700c between 40mm and 45mm? I see the Compass Barlow tires in 44mm. I probably will get a pair, but would like something a bit sturdier that still rolls decently on pavement and doesn't weigh a ton. Thanks for any suggestions.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Schwalble G-One Allaround? I'm not sure about sizes but it is a fast rolling tire on pavement.
They wear very fast though;
-Tim-
-Tim-
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I'd give the Compass a try. I'm using the 38mm on mine at the moment, on roads similar to what you describe. I've also lived in Lewiston, Me, so I have some idea of what you are dealing with.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I recently mounted Panaracer Gravelking SKs in 43-622 on my hybrid. They have a micro-knobby tread that rolls well on pavement without much noise and handle the rougher stuff nicely.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Unless you need really big-diameter wheels for your riding, I'd suggest that bigger 650B tires might serve you better than trying to find really fat 700C tires.
RUSA #7498
Originally Posted by noglider
I have found these to be awesome and light. I have them in 42’s, but they go up to 48. I use them in a similarly described environment. Just make sure to get the “EX” and not “SL”. Here’s the link
: https://www.modernbike.com/soma-supp...black-skinwall
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
I have been riding these or their equivalents in size 47-622 (700 x 45C) for over 20 years. I almost never have had a roadside flat in over 60,000 miles of riding. I normally replace them with no less than 5,000 miles on the rear, and 15,000 miles on the front tire.
Size-700 x 45C
Execution-Performance Line, Wire Bead
Color-Black-Reflex
Weight-985 g
Load-115 kg
PSI-45-70
Price-$41.00
If your frame has clearance for it .. there is 622-40 & 42, 45 & 47, tires
and the 29er plus bikes can go even wider ..
Continental travel contact bike tires?
https://www.continental-tires.com/bi...travel-contact
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Donnelly (formerly Clement) has some nice, wide options in both 650b and 700c. The Strada USH seems to be the updated version of Xplor USH. I have been happy with the Xplor USH for both actual gravel riding and cycling on bad roads.
https://www.donnellycycling.com/collections/adventure
You're getting right up near the point where 700c tires start to feel a little ponderous to me. I like 650b for anything bigger than 38mm-the smaller overall diameter helps front tire/toe clearance, keeps wheelbase length reasonable and helps maintain a more responsive handling feel. Of course, some conditions call for more stability and rollover, in which case 700c might make more sense for you. For me, riding 52-54cm sized bikes, the smaller diameter wheel just makes sense.
Lots of good options above.
Note that Compass / Rene Herse tires are unbeatable in terms of feel and speed but have extremely fragile sidewalls. Worth it to give them a try but might leave you stranded.
I'll also throw in:
Maxxis Re-fuse - more of a tough road slick, very fast
Maxxis Rambler - basically a Re-fuse with knobs. Still very fast rolling
WTB Resolute - tan walls, great tread design. For medium gravel and a bit of mud. Love these tires.
Schwabe G-One Bite - a more knobby version of the regular G-One. Supposed to be really good, fast.
Donnelly X-Plor MSO - my go-to gravel tires. Great puncture protection, durable tread, relatively fast rolling, good traction in a bit of mud. One potential drawback: don't clear mud as well as other options.
I'll also throw in:
junior
Bikes: 2020 Surly ECR / 2018 Norco Search XR steel gravel bike with GRX / 1983 Bianchi Campione D'Italia / Gary Fisher Wingra / Motobecane Nomade mixte (daughter's)
Quoted: 72 Post(s)
Liked 12 Times
I had Clement MSO XPlor 40c tires on my gravel bike's stock 700c wheels. They were very very nice. WTB Riddler 37c and 45c are also very nice for mixed gravel/pavement.
I have since gone to 650b wheels with Teravail Cannonball 650b x 47 tires, and they are fun! still mixed gravel/pavement. I would have gone with the WTB 650bx47 Venture tires, but they had not been released yet and i didn't want to wait another 6 weeks.
All of these are relatively fast rolling for pavement but work well in gravel too. Not so much for mud (though i haven't tried the Ventures at all)
eric/fresno, ca.
eric/fresno, ca.
I also know what it's like going from a 38 to a 28 tire. I hate it. After riding 38s, the 28 tires feel twitchy and overly responsive. This is on a Surly Disc Trucker. So I guess I'm shooting more for the cadillac type ride, but with better handling and lighter weight. Long, comfortable rides is my goal.
Bikes I'm looking at in 700c are Kona Sutra (I know - weight), Salsa Cutthroat (expensive with gearing challenges), Kona Rove, Black Mt Cycles road+ and MCD, Canondale Topstone. Bikes in 650b, well, I just don't know. Any bike would also have to be capable of some light touring.
junior
Quoted: 72 Post(s)
Liked 12 Times
If you're like me, and you go bigger on 700c, you're interest would still be piqued about 650b. a gnawing, ever consuming interest that could keep you awake at night. just jump the 700c boat and have fun!
eric/fresno, ca.
eric/fresno, ca.
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
My completely minimally informed perspective (as someone who doesn't ride particularly fast). In actual experience, it feels like a bike with 650b tires feels pretty much like riding a 700c bike. Other than being a tiny bit lower to the ground. And as a small frame rider - less toe overlap with fenders for sure.
The only thing that sucked is finding tires in stock at every bike shop. That has improved, but on the scheme of things is easily remedies by keeping one on hand at home.
As mentioned, there are wider tires easily available in 650b. And really I see no reason not to do it, unless for some reason you don't like the proportions of a 650b bike.
Quoted: 714 Post(s)
Liked 800 Times
Terrene Elwood 650b x 47 are very nice tires. I find them to have much lower rolling resistance on pavement than Gravel King SK's and they are better at absorbing bumps at similar tire pressures.
Non omnino gravis
Soma Supple Vitesse 700 x 48 - 'EX' (extra wear) or "SL" (super light). There is also the Soma Shikoro - significantly heavier but may be more durable.
https://www.somafab.com/parts/tires
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Strange, I mounted Override 38s, they measured 37.5mm after they snapped in. That is on my 21mm wide-internal carbon hoops. Maybe they'll stretch in overnight?
I understand you said no knobby tires. This is my experience....
I have a hybrid Schwinn. Ran stock tires for about 1,000 miles. I recently bought a road/gravel bike so I wanted a more aggressive tire on the hybrid. Through BikeTiresDirect I bought a pair of Surly Kinards, 41c. I was utterly amazed when I first these tires on the 40lb. hybrid. They are very light and I noticed that right away in the pedal stroke. But what I noticed more was the rolling resistance. My average speed increased by 2mph and I moved up 2 gears for cruise speed. Just incredible for a tire that costs $25. Utterly amazed. I love these tires.
If you look at the center ridge you will notice there is very little rubber on the pavement. These tires are fast.!! Coast forever....
Eavesdropping. Similar situation. Got my 2017 Giramondo 650b for a song and it has tubeless ready wheels on it. Yaaay.
but the 650x2.1 slant sixes are a huge watt suck. They carry well but ya gotta muscle them up there. Not going less than 40 wide or more than 48. Staying 650 though. Knards you say?
I sometimes wonder whether I should buy a pair of those inexpensive 650b wheels from Velomine and try them on my GT Grade. The only problem is I don't think I could put 47s on. 42s for sure, but if I went the 650b route, I would definitely want the two sizes for my riding. Anyone know exactly how far I measure from the dropouts to measure?
Even though the wheels are pretty heavy, I think I would know if 650b would be for me or whether I'd be better off sticking with 700c. Expensive experiment, but maybe worth it over buying a new bike that doesn't work out.
I've used the Supple Vitesse EX, it's extremely similar to the Compass tires and Rivendell's Jack Brown tires. I think they're all made by Panaracer. Very high quality tires that roll superbly but not exactly bulletproof.
