28h dynamo wheel strong enough?
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
After agonizing over which dynamo hub to get for 2 weeks, I finally settled on the SP SV-8. Unfortunately, my retailer only has the 28h version in stock. I was planning on doing a 32h build, but a 32h hub would take 8 weeks to ship.
This would be paired with a DT Swiss R460 rim, and I'd run 32 or 28mm tires on it. The purpose is randonneuring, and some of the roads around here are a little rough. I weigh 170lbs, maybe 175 occasionally.
Will I be okay with 28h, or should I spring for 32? I can find another retailer with the 32h version in stock, but mine is selling 'em for $30 less than other places. (Yes, I'm cheap.)
your plans or riding style , is unstated..
I have 28 spoke wheels , but they are 406 20" (2 on my bike trailer )
and a 16" on my Brompton.. (I have the original & one made around a Schmidt New XS dynamo hub..
8 weeks? you ordering from Asia? bring as you say, cheap ,
that the case why not just get a shimano dynamo hub wheel off the peg
with a rim of modest cost like Sun CR18?
good luck..
good luck..
Quoted: 213 Post(s)
Liked 93 Times
700c wheel to be used for brevets. I don’t know about my “style,” but I’d prefer something reasonably durable. I’ve never broken a spoke or anything, but then again, I’ve never had a 28 spoke wheel.
I can get the R460s for about $10 more than the CR18, and it seems to be better in just about every way. (This coming from someone with two sets of CR18s.)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
IDC sells 24h 700C wheelsets with that hub: https://www.intelligentdesigncycles....speed-wheelset
As Bob mentions, how you ride will determine whether that's enough spokes. I built my dyno wheel with the 32h version and wouldn't blame you if you held out for the same.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
My CR 18 is rolled down to 406 20"...
boxing the bike to fly to Paris, for P-B-P, shipping & handling , may be the most stress..
Quoted: 2604 Post(s)
Liked 1,933 Times
After the first couple years' riding, the extra $30 cost for a 32 spoke wheel won't matter any more.
When randonneuring there is usually no support like being on a tour. I would go for the higher spoke count even thinking about 36 double butted spokes.
Quoted: 213 Post(s)
Liked 93 Times
Good point. Luckily I just found a 32h hub someplace else for only $10 more than the original place. So I went for it--better safe than stranded with a taco'd rim two hundred miles from my destination (or fearing something along those lines).
Half way there
Quoted: 986 Post(s)
Liked 880 Times
The SV-8 hub is designed for smaller wheels (400-536), which spin faster at a given speed. Power output will be reduced slightly if used on a larger diameter wheel. This may not be significant, but if you also plan to power your phone or other devices it may be iffy. The PV-8 is recommended for the larger wheels.
Quoted: 980 Post(s)
Liked 582 Times
I just installed a 700c wheel I built with a PV-8 hub. There's still a bit of flickering until the speed gets up to 7 or 8 miles per hour. I have a 406 wheel with an SV-8 on my folder, which works well with that size wheel.
Quoted: 213 Post(s)
Liked 93 Times
I’m just using it for a front light, no rear, no charging. Not too worried about power output.
Liked 2,568 Times
That was my rationale for using an SV-8. It's not a bike I have to ride at super-low speeds, so it works out.
smurf hunter
38
02-13-12 09:42 AM
