Rim Tape width
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Rim Tape width
How do I know what size rim tape I need? Just got a new set of wheels ordered but I need to install rim tape.
I attached the specs of the rim. I was going to order Velox rim tape but didn't realize I have 10,13,16,19,22mm width to chose from.
I am sure this is probably a dumb question but I have never in my life installed it.....just one of those things I have never needed to do.
FWIW its a 700c wheel by H plus sons
thanks
thanks.
thanks
thanks.
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
I've only ever bought 16mm for my Mavic SUP and similar wheels. Ditto Zonda 15s. I think that would work for your rim. Is probably a similar inside width.
Likes For CyclingFool95:
assumed tubeless - not.
Quoted: 6194 Post(s)
Liked 4,810 Times
Someone mentioned tubeless.... you weren't asking about rim tape for a tubeless build were you?
Just in case you aren't talking tubeless, 11 mm is my go to. I just want to cover the spokes. Anything that laps over to the bead seat area for the tire just seems to be potential for making it harder to change tire and seat it properly.
Likes For Iride01:
Quoted: 1438 Post(s)
Liked 1,092 Times
Ideally the tape would cover the entire base of the rim without going up the side walls. If it too narrow it can squirm to one side and expose the spoke holes; too wide and it will interfere with tire mounting and bead seating. Perhaps you could cut a piece of paper to size and measure it to help you decide.
I have standardized on Continental Easy Tape. It is thin so interferes less with tire mounting than Velox tape and they make numerous widths. If you like to run REALLY high pressure they even have a series of high-pressure tapes which will take 220psi. https://blobs.continental-tires.com/...ip-en-data.pdf
Likes For dsbrantjr:
That looks to be an archetype rim..I have them and recognize the pic from their site; they have an internal width of 17.5mm and are not designed for tubeless. 16mm or 17mm velox tape works.
Likes For DOS:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Sorry I should have been more specific. yes they are the archetype rims and hard no on tubeless.
@DOS thanks for that spec. I can get 16mm so that is a winner. I have Velox on my other wheels even though I didn't install any of it and never had an issue so going to use the same stuff.
Thanks!!
Thanks!!
I agree w/what dsbrantjr said and I’ve also standardized on a thin tape but it’s made by Zipp. It’s got a few widths to choose from, is not expensive and is very tight so it stays in place.
Likes For 77Eric:
Quoted: 1188 Post(s)
Liked 1,154 Times
The Schwalbe blue tape is next level from Velox. Super strong and doesn't absorb water. Only thing is getting the valve hole in it as it's so tough. Helps if you can pre punch it.
Likes For Trevtassie:
Quoted: 5224 Post(s)
Liked 3,581 Times
fwiw - the last tape I bought for my road bike was 16mm
Likes For rumrunn6:
Enough to cover the spoke head holes in the rim, without interfering with the tire installation.
Likes For fietsbob:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Thanks....heading to the shop this morning to get a roll. If 16 does end up to be too wide I can return it no issues.
They only carry 16 and 10 on hand for some reason.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I sort of accidentally bought 13mm once...kept getting flats. 16mm all the way for me with road rims.
Quoted: 148 Post(s)
Liked 119 Times
For installation, locate the hole in the tape over the valve hole in the rim and unwind...straight... If there's excess length, you can trim back but leave a little overlap. In 20 years, the tape will shrink, or such is my experience. Of course, it also dries out and loses its stick.
Likes For ART_K:
