Bicycle MechanicsBroken bottom bracket? Tacoed wheel? If you're having problems with your bicycle, or just need help fixing a flat, drop in here for the latest on bicycle mechanics & bicycle maintenance.
Does anyone have any beta on getting a replacement aluminum brake lever blade for a left Rival hydro shifter? I called Sram and they don’t sell the blade only, only a new shifter. My wife bent hers in a crash. The lever is bent, but everything else is tight, solid, and leak free on it. Thanks!
Unfortunately, I think this is about the best you can hope to do. I haven't found anywhere online that sells replacement blades (the lever itself) for any of the newer shifters. And that listing is CHEAP.
