Severely stuck fixed cup of BB
Old 02-14-20, 09:56 AM
EamonPVD
Quoted: 12 Post(s)
Liked 3 Times in 2 Posts
Hi All. trying to remove a veryyyy stuck fixed cup that I need to replace. I’ve built a few of those Sheldon Brown type fixed cup removal tools and have used them a couple times to success on other bikes. This bike (mid 80s Team Fuji) however, is trickier. Ive wrenched down on the tool, on this specific bike, so much that the fixed cup is breaking apart. Here is a pic:
any advice on how I should proceed?
thanks
EamonPVD is offline
Old 02-14-20, 10:04 AM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 1236 Post(s)
Liked 963 Times in 628 Posts
Heat wrench PLUS the Sheldon Brown method. Soak threads with Kroil or 50/50 ATF/acetone mix first (over a few days). Make sure you are turning in the proper direction (to the right).
wrk101 is offline
Old 02-14-20, 10:07 AM
EamonPVD
Quoted: 12 Post(s)
not sure the tool is gonna be of service anymore as it is punching through the fixed cup
EamonPVD is offline
Old 02-14-20, 10:10 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
+1 on making sure that you're loosening this cup. The fact that its Japanese hints at the more common "English" type of threading: the drive side is left hand threaded. To loosen, turn clockwise.
If you have a very good bench vice with nice, sharp 90° jaws, one of the best ways to do this it to put the cup flats in the vice and use the bike frame itself as a wrench handle.
Pre-treating with Kroil is good advice. If all fails you can use a small grinding wheel on a Dremel tool to cut slots in the cup (but not the thread) and break this out. The machinist's approach would be to use heat, as in applied with a torch, but that could hurt your paint and (in excess) the strength of your bottom bracket.
WizardOfBoz is offline
Old 02-14-20, 10:30 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
The first method would use the intended tool, a fixed cup wrench. If only the low cost flat stamped "box" type wrench is available some way to secure it to the shell will be needed. But if you have access to (like a better shop will have) a Var/Campy type of vice tool all the better. Only when this vastly better fixed cup tool isn't the correct size has this method failed me. The tool can be held in a large bench vise to make the frame the lever arm.
Next up would be the Sheldon method which is borrowed from the Kingsbridge type of tool (Bicycle Research made a smaller version too). Using the specific to BB cups tool, and not generic bolt and washers, helps a lot. I've removed a number of fixed cups that customers brought in after the Sheldon method didn't work and my Kingsbridge tool did. Again using that bench vise is a big aspect and how you hold VS turn which side of the BB shell you're on is important.
At any point along this process soaking with a good penetrant, like Kroil and not WD40, can help but isn't a guaranty of an easier effort.
When all else fails there's heat or mechanical erosion methods. heat means well more then boiling water levels, think burning paint levels. And with the mass of steel this will take a powerful heat source applied for a while. Errosion usually means grinding with a die grinder or Dremel. At least until the cup's threaded wall is thin enough to see the thread tips. This only needs to be done in two locations, roughly diametrically across from each other. Then a careful application of a cold steel chisel against the two "halves" of the cup can break them free of the shell's thread. Of course if you have access to a big EDM machine that would work too
The images suggest that the OP hasn't tried much, if at all, with a fixed cup wrench. Is this true? Why not? Do you have a LBS near by that you can work with? With no location listed in your profile I don't know if this option is easily available to you. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 02-14-20, 12:07 PM
EamonPVD
Quoted: 12 Post(s)
fixed cup wrench did not work- too stuck
EamonPVD is offline
Old 02-14-20, 12:18 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
I'm simply amazed at the lack of evidence of penetrating oil being used?
What are you thinking?
Here's my "tool set" for removing these cups-
Bill Kapaun is offline
Old 02-14-20, 12:20 PM
Steelman54
Bikes: Allegro Model 77, Gitane Team Pro SLX, Waterford R2200
Quoted: 68 Post(s)
Liked 57 Times in 38 Posts
I have successfully used vice on bench method above, never fails if you have decent jaws on the vice. good luck
Steelman54 is offline
Old 02-14-20, 01:07 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26374 Post(s)
Liked 10,346 Times in 7,189 Posts
....I used to have pretty good luck with this method. I think I even put some pictures of my setup in the hints and tricks thread.
Eventually, I got one of these. To the OP, look around and see if you can find some bike shop or mechanic that has one.
Unior makes one, and so does Hozan. Probably some other manufacturers as well.
3alarmer is offline
Old 02-14-20, 01:39 PM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
I’ve broken a vise on a stuck BB once. I’ve had good luck with the bolt-and-washers method. Once or twice I’ve welded a piece of steel to the cup to get some solid leverage.
dabac is offline
Old 02-14-20, 01:50 PM
stevoo
Stevoo
Bikes: Road and mountain tandems, single bikes too.
Quoted: 34 Post(s)
Liked 4 Times in 4 Posts
I have run across this challenge on occasion.
Quick and easy to weld a big nut or bar etc to the cup. Then BIG wrench will remove.
Good luck
stevoo is offline
Likes For stevoo:
Old 02-14-20, 01:54 PM
WizardOfBoz
Good heavens! What was the failure mode of the vice? What broke?
I'm thinking a Wilton or Yost (non-swivel is best). I have a Yost (with the swivel).
The welding approach has the advantage that you are adding heat to the system.
Old 02-14-20, 02:12 PM
dabac
One of the knurled jaws broke. Took off a shard about halfway down the vertical face, the full thickness of the jaw and 30-40 mm long.
dabac is offline
Old 02-14-20, 02:28 PM
WizardOfBoz
Wow, that was one stuck BB cup. Thx.
Old 02-14-20, 02:46 PM
Russ Roth
Quoted: 1079 Post(s)
Liked 1,015 Times in 718 Posts
I'd have the frame on its side, fixed cup down and for me near the washing machine. Every time I walked by I'd add more liquid wrench for a week. It'll move easier, penetrating oils do work. Next I'd grab a quality wrench, not a thin park of bicycle specific, something like a Wright (my personal choice), SK, Proto or Williams; the kind that never slip. I'd use a bolt and 2 giant washers to hold the wrench aligned for extra measure and a frame alignment tool on the arm of the wrench for extra leverage. A quality wrench like wright will rip the head off a grade 8 bolt before it ever slips and they don't have much give in them. Don't use an adjustable it will fail as will cheaper wrenches.
Russ Roth is offline
Old 02-14-20, 02:57 PM
dabac
Well, I had several things going for me.
Big, heavy workbench. Solidly bolted to the wall.
Badly stuck BB on a frame I dared to pull HARD on.
And while the vise had done good service up to that point, it wasn’t a brand name item.
Still, it made me jump a bit when the jaw cracked with a loud noise.
dabac is offline
Old 02-14-20, 05:54 PM
Mad Honk
Quoted: 1296 Post(s)
Liked 1,882 Times in 1,132 Posts
I'm suspecting the tool being used on this bottom bracket is like one of the old Var tools that clamped down on the cup and then the pressure of the tool allowed the cup to be turned. I see it as now wasted and should be replaced. but to remove what is left would require a Campy, Var or even the 36mm wrench clamped down with BK's kit. and some added leverage like a big pipe. The 4 foot pipe has always worked for me. Smiles, MH
Mad Honk is offline
Old 02-14-20, 07:12 PM
Andrew R Stewart
As did the mentioned Var and Campy. Andy
AndrewRStewart
Old 02-14-20, 07:52 PM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times in 429 Posts
The worst ones I've seen have come off with penetrating oil, an electric heat gun and a mallet on the standard BB wrench. The mallet on the wrench alone usually does it.
andrewclaus is offline
Old 02-14-20, 08:08 PM
Ptcycles
Bikes: 73 Schwinn Continental, (my first), 1993 Nobelette, Cannondale 500,Team Fugi, Raleigh Supercourse, Raleigh Gran Sport, 1976 Krystal, Tsunami, Giant Boulder SE, Series 30 Paramount, Scott Unitrack, As long as I have room the Hoard will grow...
Quoted: 26 Post(s)
Liked 25 Times in 15 Posts
Crude, but it worked
A few months ago I needed to replace a worn BB. Took apart and found a crossed threaded cup that was fully threaded. Broke two removers before I went for broke. Laid the bike on it's side, and installed my remover on an impact and went slowly back and forth till it came out. I had to apply full pressure, All of my weight and it worked. Lots of penetrating oil and a good heating with a heat gun.
Good Luck!!
Ptcycles is offline
Old 02-14-20, 09:05 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
...sorry, Andy. I know you mentioned it early on, but I thought maybe the OP was confused about what we were actually talking about, and a picture link might help. I figured he was talking about the flat ones that slip off the cup if not held on with a bolt and washers.
3alarmer is offline
Old 02-14-20, 09:17 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
...the piece that fits on (most but not all) fixed cup wrench flats and has a square opening to fit on the squared shank of these tools is what makes them work better than the Sheldon Brown fixed cup bolt/washer kludge. I never had much luck with that setup, even though I hear people raving about how well it worked for them here. And like Andy already said, you can grab the round shank of the tool in the pipe jaws of a bench vise, using the frame as a lever. And colorful language helps a lot sometimes.
3alarmer is offline
Old 02-14-20, 10:59 PM
BoozyMcliverRot
BoozyMcliverRot's Avatar
Bikes: 1991 Diamondback Master TG 1990 Trek 850 Antelope
Quoted: 117 Post(s)
Liked 325 Times in 106 Posts
If you know a welder or have your own machine you could weld the end of a steel bar to the face of the cup. You will have all the leverage you need to turn it without fear of the wrench coming off.
BoozyMcliverRot is offline
Old 02-15-20, 06:44 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,392 Times in 1,927 Posts
The best tool for the OP's type of fixed cup is the Hozan C-352 @3alarmer mentioned above, or the VAR-30 or Campagnolo-793 others have mentioned.
The advantage the VAR-30 has over others is that other jaws are available to fit different styles of fixed cup. The Campagnolo-793 has flats on the body that can be clamped in a bench vise for extra leverage. All are relatively expensive compared to the home-made Sheldon Brown tool. Perhaps a local bike shop has the proper tool?
JohnDThompson is offline
Old 02-15-20, 07:08 AM
gearbasher
gearbasher's Avatar
Quoted: 450 Post(s)
Liked 877 Times in 376 Posts
^^^ You would think VAR would at least have the fixed cup on the proper side of the bike in it's illustration.
gearbasher is offline
