ISO: Crank Bolt "Washer" Single or Pair
Old 09-15-20, 09:09 PM
orangeology
orangeology's Avatar
Bikes: i don't have a bike. a few frames, forks and some parts. that's all
Quoted: 54 Post(s)
Liked 52 Times in 33 Posts
looking for a single crank bolt washer. or a pair if can't be separated like the cat siblings at ASPC.
brand don't matter. mine's Campy (i know Sugino washers are slightly thicker), but no one's gonna check both side of the crank to see if matching.
for those with loose screw bins, it's like one in the pic.
outside diameter is 20.x mm, inside is 12.x mm
orangeology is offline
Old 09-15-20, 09:24 PM
brian3069
brian3069's Avatar
Bikes: Raleigh Supercourse
Quoted: 218 Post(s)
Liked 167 Times in 101 Posts
PM your address and I'll send you a couple.
brian3069 is offline
Likes For brian3069:
Old 09-15-20, 10:00 PM
orangeology
Quoted: 54 Post(s)
search is over, POST CLOSED. thanks!
