Ripped Selle Anatomica
Quoted: 896 Post(s)
Liked 2,063 Times
Discovered this when I removed it to replace the seatpost. Shocking ;it's 7 months old, about 3000 miles, I've kept the tension per recommendations, it's an H2 and I'm well under the weight. Treated with their sauce on the underside, little expose to moisture. I was just starting to feel like I was getting it dialed in. We'll see how their warranty policy works out.
Quoted: 18413 Post(s)
Liked 15,536 Times
FWIW, many years ago I had a different model. A rail cracked, probably when I hit a hard, invisible bump in the road. Selle warrantied it with no questions.
Good luck!
Good luck!
Quoted: 1856 Post(s)
Liked 664 Times
It looks like you have the carbon rails👍🏻.
Bikes: There is always room for one more.
Quoted: 184 Post(s)
Liked 389 Times
Selle Anatomica makes it very clear that you should NOT use Proofide on their saddles.
Don
Don
Quoted: 896 Post(s)
Liked 2,063 Times
The rails are chromolly steel, the only option on the H1 big boy model. I guess pictures can lie.
Quoted: 1034 Post(s)
Liked 1,290 Times
Yes, but applying Proofide would not cause it to crack, it would actually do the opposite. It would be more apt to stretch when over-treated with something lie Proofide. That is what Selle Anatomica is concerned about, since their saddles tend to stretch more than say a Brooks. The leather cracked, that is from a leather being too dry.
Quoted: 942 Post(s)
Liked 527 Times
I would definitely contact them and send them some pictures. I have this saddle on my trainer bike. It is not exposed to the elements, but it does get a lot of use. I have not treated it at all with anything. I'll have to keep a closer eye on it.
Quoted: 896 Post(s)
Liked 2,063 Times
Following up, they did warrant the saddle. I'm awaiting the repaired saddle now.
Liked 2,968 Times
Likes For Troul:
Likes For phughes:
Quoted: 896 Post(s)
Liked 2,063 Times
Likes For downtube42:
Liked 664 Times
Liked 2,968 Times
Liked 664 Times
