SE bike questions
Member in Training
SE bike questions
Hi everyone. My son and I are building up a SE Blocks Flyer that we found neglected.
1) We need to replace the bottom bracket and I'm unsure what size or type we need. When we pulled the old one out, the one side was still on the spindle and I had to tap it to get the bearing's off.
2) Rear brakes, unsure what length lever arms.
Thanks
Thanks
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I'm pretty sure it's a Euro bottom bracket. Are you looking to replace the whole crank or just the bearings? If it's just the bearings they often have a number on the side of them and you can usually pick them up cheaper at a auto store compared to a bike shop. The brake levers are all personal choice for length. I looked it up and they use cheapo Promax. I'd just find one that looks cool and matches how you are fixing up the bike.
Likes For cbrstar:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
2018-2020 Blocks Flyers had a Euro bottom bracket; 2021s have a Mid. If the bearing threads into the frame it's Euro. If the bearings press directly in, it's Mid. I believe all had/have a 19mm spindle.
Depending on year, the brakes were either Promax or Tektro V-brakes, so any V-brake lever should work. They spec them with a "2-finger" lever, if that matters.
If you figure out the year model, the SE Archives has many of the specs for each model. Look it up under the "Rad Series" of each year.
Likes For Rolla:
Member in Training
Headset question
Thanks for the info so far.
Its 2019 based on the SN, so it would be a Euro BB.
What I ment on the length of the levers, was for the rear part where the brake pads mount. Maybe there called something different. But while shopping around I seen lengths of 85mm or 105mm. We have determined that we would need the longer one to clear the big tire (26x2.5).
My next question is about headsets. The current one is the caged ball bearing style and some of the ball bearings are missing from the bottom set. I would like to go to a sealed bearing type. I understand I would need to replace the cups and get a whole set. But I'm unsure of difference of 36 degree and 45 degree. I'm not sure what part that relates to, so that I could compare to the current set up. I have been looking at the FSA Orbit, is this do-able or what should I go with?
Thanks again.
Thanks again.
Guest
Liked 3,270 Times
Since I assume you're going to have to press in the headset cups and replace the crown race, you'll want to do that at a bike shop, where they can help you get the right headset.
Pretty comprehensive headset info here: https://www.bikeradar.com/features/t...e-to-headsets/
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 43 Post(s)
Liked 58 Times
Here are the specs for the 2019 model; might help a bit.
Member in Training
Thanks for the Spec sheet. But it doesn't give me the specs for the Headset, just says Tange 1 1/8" threadless. pretty basic description.
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
You will have to pop out the cups of the old headset and measure the diameter of the lip that presses into the frame with a micrometer.
Likes For cbrstar:
Quoted: 43 Post(s)
Liked 58 Times
https://www.bikeforums.net/bicycle-m...read-them.html
See if this helps if not, maybe call/write/email sebikes?
Likes For Juan el Boricua:
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
dont over complicate it, the SE’s are cheap and simple bikes (have had 3 of them over the years and currently have a Big Fler). They dont put anything exotic on them at all.
im just saddened that you found one only a year or so old that was so dogged out it needs all this , but kids can be abusive
Likes For DMC707:
Member in Training
so just buy another Tange threadless headset. Simple
BMX Connoisseur
Quoted: 399 Post(s)
Liked 108 Times
Were you able to measure the cups? On the Tange site the DX4 headsets state a outer diameter of 34mm but you should double check it. Tange makes a Technoglide in a similar size but it's pricey. You will have to google "Standard" 1 1/8th thread less headset. Other brands I can think of is FSA MX 1 1/8th but I'm sure there is others. Also check if your forks need a star nut and make sure that's included if you do. You might need to also order some spacers as the headset height might be different.
Likes For cbrstar:
SE bike tire getting holes
What are the best places to buy tubing for my SE bike and what is the best tubing I can buy so my tires don’t get holes when I run over thorns
my bike is a SE big flyer 29”
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 345 Post(s)
Liked 189 Times
Just get any 29" tubes for appropriate width tires. There is nothing special about the SE bike that would need anything different than 29" MTB tubes. As far as running over thorns - you can try adding Slime or other sealant into your tubes, (Slime brand sells tubes that already have slime in it), try tire liners like Mr.Tuffy - thorns are tough to protect. Best protection is probably going all the way to a tubeless setup, but that's probably more than the big flyer should really be worth.
Clark W. Griswold
Quoted: 4343 Post(s)
Liked 3,980 Times
In terms of your question get good quality puncture protectant tires from known quality brands (think Continental, Vittoria, Maxxis, Schwalbe... in no order) and keep your standard butyl tubes (again quality sources) properly inflated and you will get fewer flats. Avoid any goo or goop or hard liners if you are wanting a liner something soft and foamy like the Tannus Armour is good. You will use a smaller tube with those just FYI.
If you are desperate for putting goo or fluid in your tires you will need to get a tubeless set up first and then find a good tubeless sealant. This would be very different from the mess that is slime or similar and there would be no tubes and generally you would need a tubeless rim and tire.
