Hunt XC Race Wheels -- TOO light?
165 pounds, building a full-rigid bike for VERY easy singletrack (I'm 50 and very bad) plus fire trails and gravel. The Hunt XC Race wheels are dirt-cheap and CRAZY light. Do I need to worry about shattering spokes and bending rims and sounding like a steel drum?
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Your usage would seem to be the target demographicfor these wheels. I wouldnt take them to a jump park intentionally, but for use and weight, go for it
Quoted: 878 Post(s)
Liked 726 Times
I can't imagine that you'd wreck them if you slap on some fat tubeless tires inflated to a low but not too low pressure. I've had sub-1500g Hunt Aero Light Disc wheels to ride on crummy, potholed roads for a few years now and have never had a single issue with them, even when I rammed into some road furniture recently after forgetting how to pay attention to that kind of thing due to riding mostly indoors over the past year.
Thank you!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
1500g is kinda light, not so light that you need to worry about them. Spokes don't 'shatter'.
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
I've always considered 1500g to be a maximum weight. Like my old beater Helium's for everyday use. The light stuff was more 1100-1200.
Nowadays, between disc brakes and tubeless instead of tubulars wheels have gotten heavier. Even heavier when 29 wide became standard instead of 26 narrow.
I still don't think that 1500g is crazy light, just not heavy. They should hold up to your weight no problem.
I have a ~1350g set of e13 XCX wheels on my Intense Sniper and I hammer them on pretty techy/rocky XC rides. I run 2.25" tire tubeless at relatively low pressure. I'm 185-190lbs ready to ride. No issues at all with the e13 wheels (even with a 24 spoke front wheel!), so I wouldn't be concerned about the Hunt wheels at your weight and for your intended use.
FWIW, I had a set of Hunt XC wide wheels on a Honzo hardtail, and they were great reliable wheels.
