Mysterious pebble rattling in my frame!
Bikes: Trek 600 Series, Miyata 610, Palo Alto Touring, Schwinn Paramountain
Ok there appears to be some sort of pebble in my frame. I can hear it as I rotate the frame, but nothing will come out! First I thought it was the top tube, but then again it seems like it's in the seat tube. The tubes are not sealed so I don't know why it wouldn't just fall out! It's driving me insane!!!
Liked 9 Times
I'll bet it is a bit of slag in one of the seat stays. I had a frame like that, it sort of drove me crazy, I was turning it upside down and all, got all OCD about it. But then afterI built it up, I never noticed a thing. As a matter of fact, I had forgotten about this until you reminded me. Rats, now I'm going to be listening on my next ride...
Oh I definitely have one stuck in my sealed top tube, afraid it is there forever. I'm noticing it now when I turn the bike as I sand and paint, but it will be quiet once I'm riding down the road again, I hope. At least I never noticed it the first 30 years of riding.
Liked 9 Times
In case you haven't figured it out, the short answer is don't worry about it. I personally guarantee you that if, after the frame is built up and you are riding it, it suddenly changes to an angle relative to horizontal that causes the debris to make noise, you've got a LOT more to worry about than a little rattle in the frame.
Disraeli Gears
I fixed this on a fork by knowing where the bit of stuff was, and putting some thin cyanoacrylate into the vent hole near it. I don't recommend it unless you're really certain where the offending particle is, and don't use too much -- otherwise your bike will be off-balance.
car dodger
treat the frame with framesaver, the slag may stick still, and you will be protecting your frame.
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Randomhead
Liked 3,696 Times
What kind of frame is it?
if it's a typical steel lugged frame then it can only be in the top tube or the seat stays. Top tube seems more likely to me. Depending on the quality of the frame, it may be a ball of flux, or if it was a factory frame, it could be some steel that rusted loose. There is also the possibility of some brass in the seat stay.
I once found a spare nipple in the cavity of a deep section rim on a prebuilt wheel. Despite the fact that it was undetectable whilst riding, I absolutely HAD to remove a spoke nearby to get it out. Drove me crazy.
Quoted: 39 Post(s)
Liked 32 Times
It is a lugged steel frame... I don't think it's a bearing bc it does not roll smooth, it's more likely a pebble of some sort based on the skipped sounds. I tried shining a light in there but could not locate the culprit. It did not come with a BB and I do all the work myself so I don't think it was an intentional ball bearing... However I did boeshield the whole frame, and it's been drying for a few days now. The sound is gone... I guess it stuck to something inside. The thought is still quite annoying though. Guess we'll never know what it is =( but thank you for all your help!
Yes it's probably a small ball of brass from the brazing used to make the frame. I had a small piece of actual brazing rod in an old frame once. It WILL drive you nuts for sure, but it'd be best just to forget it, and ride.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I had a simular experience, stripped a frame to repaint and noticed a rattle in what I thought was the seat tube. For several days, I turned the frame every which way shaking it hoping remove whatever was in the frame. Eventualy it dropped out of the seat tube, a very dry kernel of corn!
Randomhead
Liked 3,696 Times
HAHA and thanks for the scope offer =) I'll just keep shaking it ugh... I have some time before I can afford building it up anyway =)
The kernel was probably deposited by a field mouse or some other critter. My cousin went on vacation one time only to find several pounds of dog food hidden in her sofa upon returning home. They're crafty little buggers!
