Ultegra 6800 - change cranks
Quoted: 5 Post(s)
Hello
I recently bought a bike with Ulterga 6800 and 172.5mm cranks.
I would like to change the cranks for 170mm (I don't want to start another bike-fit discussion so let's just put that to one side).
What is the cheapest and easiest way to achieve this? I can buy an Ultegra crankset for about £120 but this comes with chainrings, axle, etc which i don't need.
Is it possible to change only the cranks while keeping the same chainrings etc, and is it possible to buy only cranks? What is the compatibility of Ultegra 6800 with non-Ultegra cranks?
Thanks in advance.
Thanks in advance.
Quoted: 1820 Post(s)
Liked 1,696 Times
The "axle" that you think you don't need is part of the right hand crank arm and cannot be separated from it. As far as I know, Shimano does not sell cranks without chainrings. Changing to a different brand of crank would also involve changing your bottom bracket
Quoted: 2026 Post(s)
Liked 1,096 Times
The "cheapest and easiest" way to get a 170 mm crank is to buy a complete 170 mm crank. Your 6800 crank is a Hollowtech II design and the spindle is part of the crank arm. Either sell the 172.5 mm crank or keep it's chainrings to install on the new 170 mm crank when it's chainrings need to be replaced.
Quoted: 5 Post(s)
Thanks very much for your replies. I had kind of figured out all of these things since posting.
I'm resigned to buying a full crankset and then selling the left-overs.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Bought it new from a shop? Inquire about a swap. Or look for a used one that may have rings that aren't as nice ans swap yours on.
Quoted: 8 Post(s)
Quoted: 1422 Post(s)
Liked 7 Times
They're easy to swap and having more sizes can be useful if you travel to other terrain.
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
Quoted: 18378 Post(s)
Liked 4,512 Times
E-Bay?
