Any old friends here?
bironi
Quoted: 98 Post(s)
Liked 291 Times
Hello,
I'm pretty new to this forum and more so to this sub forum.
I'm wondering if there others of my generation riding fixed and single speed.
I took up riding road fixed gears 10-12? years ago.
I'm now 72, but it's still my preferred choice.
I especially want to hear from my seniors for inspiration.
Thanks much in advance to your response.
By
By
Quoted: 2484 Post(s)
Liked 2,956 Times
I'm 72 as well. My first good racing bike (i.e., with tubular/sew-up tires) was a track bike and was given to me on my 13th birthday. I've owned maybe a couple of dozen high-end bikes over the years, including a series of track bikes. There are still 3 fixed-gear bikes in the collection, although I do fewer long hilly rides on them than I used to, out of consideration for my knees.
Brown Bear, Sqrl Hunter
I took up riding fixed probably close to the same time. It was maybe the golden age of the fixed gear trend? I think TejanoTrackie is old school cool
Quoted: 4806 Post(s)
Liked 3,932 Times
70 here. I raced long ago. My club vets told me I needed to set my beater bike up fix gear to educate my legs to pedal better. They were so right! Learned that winter that fix gear riding was like driving in snow with a standard vs automatic. Easier to stay upright. (And nothing to break when you couldn't.) Sold. That was 1976.
Since then I have always had one; that bike as a continuous entity with parts replaced as needed. (The frame 4 times. Once all but the Campy track hubbed rear wheel. Stolen with an inferior wheel on it.) And starting 2006, I added one, then a couple of fun, performance road fix gears. (That first was and still is a '70s-'80s frame, fenders, LowRider rack, U-lock and miles of reflector tape workhorse.)
Now I have two good ones. The bike of my avatar photo - a custom Ti Cyles, fix-fix hub - and sometimes a lightweight chainwhip you can see on the top tube and all the cogs from 12 to 24 teeth. And my old Peter Mooney, now running an 1/8" triple and fix-fix hub. For mountain days, I run a 21-17 double cog on one side and a little downhill cog on the other. Typically a 46-42-36 crankset. 3 very different gear ratios, 3 very good chainlines. And all on a regular horizontal Campy dropout. Fun! Both bikes have been up to Crater Lake, around and down.
As you might have guessed by now, I absolutely love riding fix gear.
Last edited by 79pmooney; 03-06-24 at 11:43 AM. Reason: Accidental post. I was still typing
Likes For 79pmooney:
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
I just turned 64 and have been riding "mostly" SingleSpeed for the last 10+years because I discovered how peaceful it was to ride Solo and at my own pace.
The last time I rode Fixed was when I was still in my single digits on my Big Wheel . Learning to ride Fixed now gives me the Willies.
My most recent SS purchase also happens to be my first BMX. Looking forward to ripping up the hood lol
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
This thread is an older thread but generally active-ish:
https://www.bikeforums.net/singlespe...thread-41.html
Also another +1 for TejanoTrackie he is up there (I want to say 80s and still racing?) and I think has almost all fixed gears and single speeds, dude is what we all should aspire to be : )
Likes For veganbikes:
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1333 Post(s)
Liked 764 Times
Likes For TejanoTrackie:
Bikes: yes
Quoted: 14 Post(s)
Liked 10 Times
Next month I'll be 82 and have been riding mostly one speeds for 30 years.
I'm a better runner than cyclist. I did finish 5th in vets class cyclocross nationals once, but there was snow, and I got to run up the hills.
The bike has saved my chronic achilles, and I consider it cross training, but in truth, I love it more than running.
Tried fixed gear, but scared myself on downhills. I don't know how you guys do it.
Likes For halb:
Veteran Racer
Liked 764 Times
It’s really easy if you use a front brake. The secret is to keep pedaling so that you don’t bounce, and ride the front brake to control your speed. Also, good foot retention is a must.
Clark W. Griswold
Liked 3,995 Times
Basically it is just a commitment you are making with your bike to stick with it and trying on more mellow hills will help build that up. I am certainly a bit more of a nervous cyclist at more potentially dangerous points but knowing people do it all the time and just saying you got this helps get that confidence up and you get through it quite easily.
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
I'm 47 and the fixed gear riders here are really an inspiration. I want to keep it up for another 30+ years!
I haven't raced since 2009 but I think this is the year I get back into road racing and I'm hoping to get up to TTown to try my legs on the velodrome.
An inspiration, I tell you!
Phil
Phil
Liked 3,932 Times
Now, it is true that you will have more pedal unclipping related crashes. But those happen at speeds of downwards of 3 miles per hour. Usually not life threatening. I've lived through dozens. Skinned a couple of elbows and knees. Holed a few pieces of clothing. Dented my ego. Scuffed bar tape and pedal outers. But all my joints still work. (Trick - great the road with every corner you have. Elbow, knee, then forearm, ankle and hip. Rotate elbow and knee out. Not rigid, but just a firmish first impact. Enough places and none get more than very minor bruising. You are going slow so you will probably not even break the skin.
With good brakes and toeclips, downhills become fun. You pedal just shy of going bouncy haywire. A little too much? Dip on that brake. Keep doing it. You will get smoother and faster and have more fun. And you reap wonderful pedaling benefits all the time on any bike you ride. Plus this wonderful gift of learning to recover as you pedal. Races and group rides that are a little too fast? Thank you, fix gear! Every slight break in the action you can go full-time into recover pedaling 120 RPM.
70 years old now. I do far less of this stuff. But still, more than half my miles are fixed. I did my last 450 mile Cycle Oregon fixed at 69. Long ago I used to ride up Oakland, CA's Joaquin Miller Road to Skyline, turn around and descend insanely fast. Never got passed by a car going down. Nice wide road but I was probably considered too crazy to mess with. (And side benefit - I would be completely loose and relaxed when I got home despite climbing 1000' on a 42-17.)
Quoted: 896 Post(s)
Liked 2,065 Times
Just 63 here; been riding fixed just over a year. Kind of loving it actually.
I've been into randonneuring since 2010, and was inspired to see guys on long brevets riding fixed. In England two years ago I came across an old school fixed gear dude - wool jersey, wool shorts, toe clips. He was probably ten years my senior.
Finally jumped in, and rode my first fixed 100km ride December 2022. Per Strava I have 2k miles fixed. I think about eight 100km rides and one at 200km. This year I'm going all in and attempting a Super Randonneuring series. We'll see how that goes.
Bikes: rockhopper w/26x2.5 rear
Quoted: 23 Post(s)
Liked 10 Times
55 and have a track bike since 1987. A DeBarnardi frame. A workout! Want a thrill? Do a track bike ride and then get off and go for a jog. Your legs will be burning. Have a good one.
Liked 2,956 Times
Started riding track bikes in 1964, at age 13, with a Reynolds 531 Helyett; so 60 years ago. Still have one steel 531 track bike - a mid-1960's Peugeot with all its original Campagnolo components.
But I do all my fixed-gear riding on a Specialized Langster - aluminum frame and fork, road geometry. Of the many bikes I've owned over the decades, it's my all-time-favorite.
Came with two brakes; took the back one off when the bike was new, in 2005; put it back on last year. That little bit of increased safety has made the bike more fun to ride, especially in traffic.
Likes For Trakhak:
Quoted: 238 Post(s)
Liked 405 Times
I swapped out the drops for bull-horns a few years ago and found the TT levers provide so much more stopping power.
One of my "never sells" ...........
Likes For Speedway2:
Life Is Good
Bikes: Zipp2001 Carbon Belt Drive SS, Kestrel RT900SL, Kestrel KM40 Airfoil 1x10, Orbea Occam H30, Trek Stache 5 29 Plus, Giant Yukon 2 Fat Bike
Quoted: 277 Post(s)
Liked 870 Times
Soon to be 64 youngster here riding a 31-year-old bike set-up as a carbon belt drive single speed.
hello
69 here, and I started riding fixed gear in 1995 after purchasing an Ibis Scorcher. Over the years I’ve sold off most all of my FG rides. I still ride fixed on occasion…an old Bianchi Pista.
Likes For IAmSam:
Quoted: 823 Post(s)
Liked 1,395 Times
62-year-old here, on-again-off-again cyclist since 1974 or so, and more than half my mileage since 1998 has been on fixed or single-speed bikes. I only owned one track-ish FG, a Bianchi Pista I bought in late '99 and sold maybe a year later. Today I own THREE fixed-gears, a converted '71 Gitane TdF that is my get-on-and-go beater, a converted '73 Raleigh Competition )set up with 35 mm cyclocross tires with a Surly Dingle cog and a White Industries 2-speed freewheel and two chainrings which gets me fixed pavement and gravel road gears on one side of the hub and general noodling and gentle single track freewheel gears on the other), and a full-on custom road fixed-gear I spec'ed for long haul distance rides like centuries and brevets.
The hipster scene never came to this corner of South Carolina, but I have a couple of associates I ride with sometimes who understand the appeal of fixed or ss on the road. It helps that there WAS a serious scene of single-speed mountain bike guys here a few years back - the local twisty, turny, woodlands trails in this part of the Upstate work really well with fully-rigid 26-in tire bikes!
I have never been a competitive rider, but I have led several multi-surface rambles around here, while riding fixed and attempting to revive old-school British cycling club jaunts rather than all-out hammerfests.
Liked 3,932 Times
Bikes: 1980's Viner Track Bike, Litespeed M1
Quoted: 43 Post(s)
Liked 107 Times
51 here did the BMX racing thing mid and late 80's. Switched to road from 1991 until current. Started the fix gear about 6 years ago. I really like the workout and the simplicity. Below is my fixed (pedals are now toe clips). Usually do 10-12 mile routes couple times during the week and ride the road bike on the weekend.
Likes For EJM73:
Tiocfáidh ár Lá
Wow! Allow me just to say you guys are an inspiration! Age is just a number, keep on keepin' on brothers and sisters.
