modifying a steel 16" folder to imitate brompton.
transport, not sport.
i am prepared to get negative comments.
i will just ignore them.
the question is:
has anyone here with welding skills ever tried to modify a cheap steel 16" folder to fold like a brompton?i
the question is:
We have only modernized an 16 years old brompton into Barcelona limited edition look-alike.
Its more than just welding..
Have Pictures of your home Machine shop to Pull that concept Off?
DancesWithSUVs
Quoted: 7 Post(s)
Considering the amount of effort it will take,why not just build your own frame modeled after a Brompton? A cheap bike will prolly be crappy hi-ten,if you start fresh you can use much better steel.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 11 Times
might be cheaper to locate a NeoBike used.
Speed Uno
Dawes Kingpin 2speed
Speed Uno
I do not really understand this post..if you are skilled enough to make one then go ahead..but make it a cross between a Bike Friday Tikit and a Brompton and you could make a fortune..
Pivot axis is behind the BB, whole rear sub assembly has bushings that are machined for alignment, after they are in the frame
with the reamer Brompton had custom made for the purpose .. Tikit folds at an angle, along side the main frame .
After you make all the assembly Jigs then the parts all fit better..
By all means, go for it, You First , Show your Work.
