If you could afford an e-bike, would it be your "go to" commuter?
#126
Bikes: e-bike and a steel framed roadie
Quoted: 13 Post(s)
Folks do what works best for them. I don't believe an e-bike is the be-all, end-all decision in whether one would commute by bike, or use a bike as transportation in any sense. It is, I believe, a metric of desire,professional image, safe facilities, efficiency, perception, status, the number of cute members of the opposite sex also commuting, and the quality of bakeries and coffee shops on the route. This is MY list. Others list may vary, My point is that the e-bike, in and of itself would probably not be the deciding factor.
There IS an ebike store on my commute.. I peeked in once, but for me, it is of little interest. That could change of course. It is an option.
#127
Quoted: 1186 Post(s)
Liked 289 Times
3. Environment- A My E-Bike will use about 5% the energy my car does. An electric bike does use energy, but way less than a car designed to transport 5 people at 55 mph. The EPA estimates that one gallon of gasoline is equal to 33.7 kWh of electricity. My E-bike will use about 2 kWh to make the 40 mile trip.
#128
I don't have a drivers license & my commute went from 4 miles round trip to 33 miles roundtrip when the job moved so an ebike was my go to solution because I didn't feel like I could do this commute everyday year round. I did go back to my regular 32mm 700c cx bike this summer & found out that doing this commute 5 days a week was quite doable, but will likely stick with the ebike for winter if it's not mild in Chicago this year because I do not see being able to to this commute everyday on a mountain bike with studded tires like I did when it was only 2 miles each way.
My $1900 bionx equipped bike has over 6000 miles on it now through 8-9 months of use & has been fairly reliable with only the freewheel & chain needing to be replaced so far (charger too, but due to being carried on bike through rough roads causing mechanical failure of solder joints). If my garmin 305 GPS HRM is correct I burn over 800 calories through the 16.5 miles oneway.
#129
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
It's the rider's option. I can ride a my carbon fiber road bike on my commute or I can ride my wife's hybrid. The road bike minimizes the amount of work between the two bikes, however, I would choose the road bike each and every time over the hybrid. It definitely has more appeal than riding a hybrid. Would that be considered cheating?
IMO everyone riding a lightweight road bike is cheating too.
Well.....not really.....long steep hills are work even on my light bikes.
#130
Quoted: 52 Post(s)
Liked 17 Times
There are plenty of folks on the commuting forum that are looking for lighter bikes, looking to carry less, go faster... all looking to minimize the work of riding on their commute. I've done it myself. It's rare that I see a lot of posts where someone is looking to make the work harder. Most people aren't looking for a heavier bike or heavier load for their commute. If that's the case, I don't think you'll find many bikes that have the option of making your work harder than you imagined... but an e-bike can do that. It will weigh between 45-70 lbs. Just turn the motor off... or put it into regen mode and it will feel like your riding with your road bike with the brakes nearly locked up. On an e-bike, it's the rider that decides how much "work" he wants to do... not the bike.
Fitness is one reason I commute by bike. I realize that I could get more of a workout with a slower bike, but I want to be rewarded with speed for hard work, and I want the speed to come as a result of my hard work, not the work of a motor. I'm also not interested in working harder in order to charge a battery and I don't want to get a harder workout by carrying some extra dead weight (a battery and motor that I've switched off).
For a long time, I just never understood the appeal of fixed gears and single speeds. I thought they were just a weird fad. My feeling was that a geared bike allowed you to ride in a single gear if that's what you really wanted, so why not just use a bike with gears and give yourself the choice? The answer is that it's not the same.
Now, I'm not trying to convince anybody they should be riding fixed. However, you need to realize that people do make that choice, so obviously for a whole bunch of people, choosing the ideal commuting bike isn't just about the cost, the speed, or getting from A to B with the least amount of effort.
You asked the question, "If you could afford an e-bike, would it be your go to commuter?" For a lot of people the answer might be yes, but for a lot it is "no". That should be OK, right? Why is it so hard for you to accept?
#131
Quoted: 396 Post(s)
Liked 8 Times
Is it safe to assume your job isn't physically demanding? If so, do you think your outlook would be different if it was?
#133
Quoted: 2952 Post(s)
Liked 3,106 Times
#134
Quoted: 52 Post(s)
Liked 17 Times
I also recognize that a traditional bike is a pretty marginal form of transportation in the winters we get and that a velomobile type thing with e-assist might appeal to a lot more people (but cost would definitely be a problem).
#135
Quoted: 396 Post(s)
Liked 8 Times
In a large seat bag I carry a tube repair kit, spare tube, pressure gauge, 3 tire levers, small crescent wrench, small allen wrench set, 8, 10, 13, 15mm wrenches, double tip screwdriver, plug in chain for frame lock, water bottle, rain pants, backup battery light, wool cycling cap, hand wipes, spare bungee cords.
In my work bag which is a 24l Ortlieb rack pack, I carry a insulated soft cooler with the days food in it, wallet, phone, high-viz vest, work shirt, extra socks,
I don't have anywhere at work to store things other than a basket in the break room, and even though I have a bid tractor, it can be taken by a road driver if needed for an indeterminate time, so leaving things at work is limited.
#136
Quoted: 396 Post(s)
Liked 8 Times
It is a safe assumption and yes, my outlook might be much different if my work was physically demanding. It might also be different if my commute were much more difficult or if I had a bad knee. So I'm not knocking e-bikes. Just explaining why cost isn't the reason I don't use one, - which was the question that was originally asked.
#137
Quoted: 396 Post(s)
Liked 8 Times
#138
Forget the whiners !
I don't think they're sold in the US, but I tried those while in Europe:
Moustache Bikes - Saison 5 | samedi 28 Black
They're based on a Bosch system, pedal assist only, with a torque sensor. The system adds a certain %age of the torque you produce directly on the crank (something from 20% and 300% in believe). Riding around the Alps on one of those was awesome, and I could do it with friends who are not enough in shape to do it with a standard bike.
Apparently a ton of people use them for commuting, as you can get through difficult climbs without sweating too much.
#139
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
The way I see it, most commuter fall into one of two categories: 1) bike enthusiasts who also happen to commute with their bikes and 2) those who use bike as a mean for commuting to work. For the first group, e-bike makes little sense and as for latter, e-bike would be one of the option. I happen to be in the first category.
#140
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
Well, for full disclosure, I was an enthusiast some 25 years ago. So perhaps born-again enthusiast would be a more apt descriptor.
#141
Liked 289 Times
#142
Bikes: 2017 Kona TI, 2016 Bike Friday Haul-A-Day, 2015 Bike Friday New World Tourist (for sale), 2011 Mezzo D9, 2004 Marin Mount Vision Pro - for now :)
Quoted: 103 Post(s)
Liked 5 Times
InTheRain hits on something I have thought of often, and that is the fitness aspect of riding a bike. I have spent many thousands of dollars "upgrading" my bikes over the years so I could go faster and longer with less effort. I do not compete in races, etc. So, I felt that was a way to allow me to enjoy riding more, but when I was "training" I did suffer a lot (very stressful workouts). What gives with that? On that same note, why would someone put aero bars on their bike for training (as just one example)? Wouldn't it be best to ride a Huffy for training and then ride the 18 pound aero bar bike for the tri?
I think we are very confused in the US, and are often times in "competition" mode - even though we have no intention to compete. I just enjoy the riding more now, even though I am on a Big Dummy with pedal assist, or my Mezzo, or my Velo Orange while wearing cotton shorts and a button up shirt - no more jerseys.
#143
Liked 3,106 Times
No, it wouldn't be better. If you turn up to a TT or triathlon without having spent anytime training in the aero position, you will not have a good day. It's not just how many watts can you push; it's how many watts can you push in the aero position. You have to spend time on your TT bike and for many racers, there are only so many riding opportunities during the week. Which means that they will occasionally ride the TT bike to work.
#144
Quoted: 52 Post(s)
Liked 17 Times
Yes to the original OP's question.
However, pedal assist is using a hyrbrid form of power and that's not something that interests me for my current commute.
#145
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
#146
For several years living in San Diego I commuted about 18 miles each way to work on my bike (I am retired now, so no longer commuting). At work was lucky enough to have a shower facility and could store professional style attire in my office. 18 miles got me good and sweaty (some good hills along the way). If I didn't have a shower available really couldn't have done this riding my bike. If I had to commute in wearing my work clothes an e-bike would have been a good solution, where I could keep my HR down, sweat less, but still get some exercise and get to work in a reasonable amount of time.
So much would depend on work conditions (what you where, can you shower, OK to smell, secure parking etc) and route you take, distance etc. I can see e-bike make sense in some cases, but not make sense in many more.
#147
born again cyclist
i could afford an e-bike, but my commute is so short (5 miles one-way) and so flat (chicago), that riding a regular old bike seems to work just fine for me.
i like being my own power. it's the same reason why i own a kayak and not a speed boat. i could afford a small speed boat, but kayaking is simply way cooler in my opinion. i have more fun doing it.
that said, were my commuting circumstances different, i might consider an e-bike as an option.
#148
Quoted: 103 Post(s)
Liked 5 Times
#149
I've been passed by e-bikes on the MUP. Guess what - I can tell there're e-bikes in about 2 seconds. And it pisses me off. Not because they're going faster than me - but because they're riding a MOTORIZED vehicle on the bike trail! You want to ride a motorized vehicle - get on the road.
This seems to me to be the main attraction for e-bikes - to be able to ride them on infrastructure built for bicycles. And since there are very few e-bikes out there, the rules haven't caught up to them in many cases.
If you want exercise, you'd be riding a normal bike. If you want speed and convenience, you'd get a scooter, motorcycle or automobile. The e-bike seems like a solution in search of a problem.
#150
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
As we've already seen in this thread, e-assist bikes with drop bars are available. It would not be difficult to set one of these bikes up in an aero position very similar to the TT bike.
