Any Suggestions On How To Repair A Leaky CycleOps Fluid 2?
Interocitor Command
I called them today about my leaky resistance unit. In spite of having a lifetime warranty on all parts the dude said they don't cover things that are due to normal wear and tear.
Anyway, any suggestions? I've done a google search and nothing came up. They said a replacement unit would cost $200 sans shipping. No thanks.
Quoted: 1438 Post(s)
Liked 1,092 Times
I would call them back and ask to speak with the "dude's" supervisor about their warranty policy. I would not accept having them classify an oil leak as "worn out through normal use." https://www.cycleops.com/support/warranty
Interocitor Command
I don't think I have the box or original documentation. I bought it back in 2004. I'll have to look.
Update: I found the original box and documentation. However, there was no receipt inside. The warranty on the manual says the Fluid 2 has a lifetime warranty against all manufacturing defects just like the web site.
I'm going to call them again tomorrow and see if I get a different ... dude.
Interocitor Command
I had a leaky Fluid 2 and they replaced the unit, no questions asked. The replacement has not leaked after about 5 years. There was a defect in the original units and they were prone to leaking. As I recall, I could easily spin out on it, and this was my clue that something was wrong as I couldn't do that when I first got it, compared to my old wind trainer.
Here's something else to ask them: Would they replace it with a "smart" Magnum unit since the base stand looks to be the same? And if so, how much? My guess though is the stand is the cheap part, and they won't do it for much less than the cost of a new one. Can't hurt to ask.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
So, are the cycleops units pretty durable except for the issue the OP describes?
Also, anybody own one of the variable (settable) resistance cycleops units? I guess that this woudl be the Hammer or the Magnus. I'd like something that I can use to give me a programmed workout this winter. Set it "hill course" or some such. Does this make sense?
Like I said, the original units were prone to leaking, but the newer ones seem to be ok. I'd like to try a smart version of it myself, but can't decide on a smart trainer or a pair of power meter pedals. I don't think I need both.
Quoted: 5779 Post(s)
Liked 2,576 Times
Let's be real. Everything has a service life, and a lifetime warranty against defects does not mean something lasts forever.
The fact that the OP got 13 years of service out of it pretty much proves it was free of defects. Stuff wears out, especially things like O-rings. It's sad that they don't offer a rebuild program or at least a service kit with O-rings and a bottle of fluid, but IMO, the OP isn't entitled to a freebie here.
FB
Chain-L site
FB
Chain-L site
Bikes: 2015 Giant Escape 2,
Quoted: 52 Post(s)
Let's be real. Everything has z service life, and a lifetime warranty against defects does not mean something lasts forever.
Interocitor Command
Anyway, I spoke with someone different today and they offered a replacement resistance unit for $109.00 shipped so I bought it. It should arrive in 3 days from Wisconsin.
If anyone is interested, the fluid they use is Mobil DTE746 Turbine Oil. He said to use exactly 5.24 ounces to get the correct power curve.
Liked 2,576 Times
I absolutely love the 5.24oz. Not 5-1/4 oz. but precisely 1/100th of an ounce less.
Does anybody really believe that folks are measuring to within 1/100th of an ounce?
FB
Chain-L site
FB
Chain-L site
Interocitor Command
I just googled Mobile DTE 746 and it doesn't seem to be readily available anywhere so I doubt people are topping off their units with the correct fluid, let alone exactly 5.24 ounces.
Interocitor Command
Could be. I know my O-rings don't work as well as they used to.
Once I get the replacement unit in I may try to disassemble the old one and replace any gaskets, O-rings and seals I find. If I do I'll take pictures, document the process and post the results for the posterity of future Fluid 2 owners.
Yes, definitely a reasonable solution. The person I spoke with yesterday wanted $200 for a replacement unit.
Oh, and you can easily use gasket in a can from the auto store to replace the original gasket/o-rings, just an FYI.
Seems like you can get the oil on eBay--a bargain at only $1200! (Or best offer!)
Quoted: 84 Post(s)
Liked 5 Times
Liked 2,576 Times
If a weld or casting were to crack, that might imply a defect. But shaft O-rings and bearings are wearing parts, so there's no reasonable expectation that they'd last forever.
But don't take my word on this. Do a search on the internet. There's plenty of documentation proving that a warranty lifetime is shorter than most people believe.
FB
Chain-L site
FB
Chain-L site
Quoted: 15 Post(s)
Cycleops has replaced 2 different Fluid resistance units one was a worn out bearing, and was replaced with just a phone call, and the other was a leak and for that one i had to send the unit back in for replacement.. Turn around on both units was less then a week .
I have found their customer service to be top notch. This season i made the decision to go to a smart trainer and the way i was treated by them the decision to go with a Magnus was a no brainer.
Quoted: 2026 Post(s)
Liked 1,096 Times
Years ago when people wanted to argue against our proposed conversion to the metric system they would express US measure cliches to absurdly precise metric equivalents as in: "A miss is as good as 1.609344 kilometers."
Liked 2,576 Times
I also think he converted a metric measure to ounces and expressed it to excess accuracy. 5.24 fl-oz are 155 ml which sounds like a reasonable number.
The other day I warmed a frozen entree. The instructions said to heat at 350 for 56 minutes. Really? Will it be over cooked in 57?
FB
Chain-L site
FB
Chain-L site
For replacement oil, maybe someone can find the viscosity of what they used and find something similar. I'm sure it is some standard hydraulic oil or something. i doubt they have their own oil refinery and chemical lab... they just buy it bilk somewhere.
Interocitor Command
If those gaskets are weird shapes or not available, you can try one of these liquid gaskets. Obviously it is not re-usable and every time you open the unit need to re-apply. google that company since they have different products for different type of fluids, but eh one linked should work.
... i doubt they have their own oil refinery and chemical lab... they just buy it bilk somewhere.
leaky cycleops... me too!
Mines about 12 yo and has been leaking for some time. Funny its not continuous, but just sometimes. I called Saris and was offered a Fluid 2 power unit for $99 and Magnus for $499 without proof of purchase. I'm the original owner but for the life of me I can't remember where I bought it.
I asked about the fluid and the quantity. They did not answer. then I stumbled of this thread. Thank your Dr Morbius! I could not find hydraulic fluid viscosity index 46 in a small enough quantity , but automatic transmission fluid type F has a viscosity index of 38 and in the temp range the unit experiences theres alot of overlap. I think my unit has ATF and not the Mobil 746 since its GREEN.
I put some in , didn't even drain the old stuff. Resistance is back ! And seems to work fine. I might drain it and measure the 155ml to see if it makes a difference. I just rode it for about 20 min and so far no leaks.
