Bad BB/headset bearing?
Old 08-04-19, 05:08 PM
jjferrante
Hi All,
Would a bad BB bearing cause a tick/creak? Only does this when out of the saddle and pulling on the bars. I've cleaned and re-greased the headset bearings and all the stem bolts and it still happens so that kinda rules out the cockpit. BB is a praxis conversion that I had installed in order to use a Shimano crank. It was fine for a while so I'm wondering if the BB itself went bad. I've had it pulled and reinstalled...no change. When climbing and pulling on the bars I can relax my pull on the bar and it doesnt go away in the least which still points to the BB. Pedals re-greased, it's not the saddle or seatpost and headset checked as well. There aint much else to look at but the BB. What are the odds its defective?
jjferrante is offline
Old 08-04-19, 05:54 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
When was the last time you changed it? Press fit definitely doesn’t last as long as some of the previous designed BB. Possibly a different brand might help. How it is installed also has a lot to do with wether you get creaking on
colnago62 is offline
Old 08-04-19, 05:58 PM
Dan333SP
Serious Cyclist
Dan333SP's Avatar
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times in 99 Posts
Originally Posted by jjferrante
Hi All,
Check your skewers. Had an identical click under identical circumstances, thought it was my headset, then my BB, then finally pulled both skewers and greased them with chain lube. Creaking out of saddle was gone.
Dan333SP is offline
Likes For Dan333SP:
Old 08-05-19, 09:37 AM
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 359 Post(s)
Liked 179 Times in 111 Posts
Many of us have found this the hard way.
popeye is offline
Old 08-05-19, 12:25 PM
jjferrante
That worked enough for me to decide to buy new skewers.
Old 08-05-19, 03:36 PM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1097 Post(s)
Liked 559 Times in 446 Posts
Try tightening the rear wheel skewer. The only time I had this problem, that was the culprit. Also, climbing out of the saddle should not be accompanied by pulling on the bars. If that's necessary, get some lower gears.
DaveSSS is offline
Old 08-05-19, 10:31 PM
Princess_Allez
Quoted: 173 Post(s)
Liked 57 Times in 40 Posts
I recently replaced my creaking BB with a Praxis unit. It solved the issue for now. My LBS warned me that even with the Praxis it could still creak. It's the tolerances not being precise.
Princess_Allez is offline
bostongarden
Bicycle Mechanics
5
02-12-19 05:04 PM
grnrcr
Bicycle Mechanics
13
06-25-17 04:44 PM
Ze Bike Doctah
Bicycle Mechanics
7
05-17-16 07:28 PM
auxym
Classic & Vintage
13
06-11-14 01:45 PM
spoketacular
Singlespeed & Fixed Gear
11
03-21-11 11:29 AM
