Tire fit
Tire fit
Hi,
I'm having a problem fitting a folding continental gatorskin 700x23 to an old Campy Omega clincher rim - 700c. I know that this tire is supposed to be notoriously hard to mount, but this is ridiculous. Are these compatible?
Thanks,
Keith
Thanks,
Keith
Quoted: 5877 Post(s)
Liked 3,445 Times
Campy rims can be tough to mount tires on or at least that has been my experience. A kool stop tire jack should do the job.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
Likes For ThermionicScott:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Tire fit from different manufacturers is akin to clothing fit from different manufacturers. They'll all have the same BSD, but some might have a little more below (inside?) that than others.
Stiffer rubber compounds make the job a little harder, supple rubber is a little easier. Gatorskins obviously come from the former group, and you might need to resort to judicious use of steel core levers to pop that bead in place. +1 to thinner rim tape, since that extra mm of depth can make the difference between needing a lever or not. I swapped the front tire this morning for a more supple compound over the Michelin ProTek I bought for better control on Mackinac Island's unpaved road segments. I only recently realized that the cheapie Forte Urban II tires that were on the bike when I bought it are 1) lighter; and 2) more supple.
Quoted: 1370 Post(s)
Liked 1,743 Times
The smaller the profile (width) the more difficult it is to mount a tire, in my opinion. In Jamaica, last winter, I had a choice between 700c x 23 o4 700c x 32. I bought the 23s and managed to get one on the rear rim. The other one, for the front, no way! So, I went back and bought the 32s putting them on with bare hands. And I learned something - bigger is better in the world of comfort. No more 23s, or 25s for me...
Likes For randyjawa:
Quoted: 4559 Post(s)
Liked 2,798 Times
Some Conti road tires can be very difficult to fit on many rims. Ultra Sport II are tough as well. Same with a Vredestein Fortezza Tri Comp I mounted recently. Ditto Schwalbe One V-Guards from a couplafew years ago.
Get a Kool Stop bead jack. I rarely leave home without it stuffed in my jersey pocket, in case I flat on the road. I like Conti tires but it's almost impossible to horse 'em across some rims without leverage. And it's more difficult now with arthritis in my fingers and wrists, especially in chilly or wet weather.
There are more compact bead jacks but they don't offer the same leverage. The Kool Stop is a bit bulkier but about the same size and weight as my Topeak RaceRocket HP mini pump, so not a big deal. Sure beats wrestling with tire levers and causing pinch flats (yup, done it with brand new tubes), or making the Call of Shame.
Powdering the tube and bead can help. I used Monkey Butt skin powder the other day, since it's all I have (talc free too). Helped a lot.
Velox and other cloth tape hasn't been a problem as long as I get the narrowest tape that covers the spoke nipple holes. If the tape is wide enough to climb up the rim shoulders it'll probably hinder seating the bead. I think I use 10mm or 12mm at widest.
Not all Conti road tires are that tight. I recently tried the Grand Prix Classics, 700x25 skinwalls, and they fit fairly easily the first time, and more easily the second after the mold release and bead edge was burnished a bit from previous mounting.
incazzare.
The tire gods are telling you not to use those tires. They're terrible. They're only good at preventing flats, on every other criteria they are junk.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Señor Member
Quoted: 1491 Post(s)
Liked 1,072 Times
Crank Brothers' Speed Levers are one of the best tools ever.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
pedro levers work for me. i've not had one break
again, try stretching. i got the tip from a gravel forum where tubeless tires are the norm and tend to fit snug by design
Quoted: 1324 Post(s)
Liked 927 Times
Something to consider with any hard-to-mount-tire. If it's that hard to get on at home will you be able to get it off if you puncture on a ride?
Many years ago, circa 1991, I had a puncture on a Michelin folding 19mm slick. I broke two tire levers getting that tire off.
Just recently I had the LBS install two Victoria Zafiro 25mm tires onto my Matrix rims. They must have had a heck of a time getting them on because when I tried to take the tire off the toasted rear wheel after a ride, I had to use the rounded ends of two cone wrenches I have in my tool box. That too was after breaking two tire levers trying to remove the tire. I'm sure glad I didn't puncture that tire/tube on a ride.
Cheers
Cheers
Liked 927 Times
Cheers
The dropped
Liked 1,014 Times
Liked 927 Times
Quoted: 18320 Post(s)
Liked 4,489 Times
I've also tried veloplugs. I think they may be a might bit narrow, and have used electrical tape on top of the plugs.
What have I gotten myself into?!!! I can mount the tire without a tube. With the tube, I can't see the tube when I'm trying to get the last 4" of the bead over the rim. Are there any other tires with great puncture resistance that are easier to mount?
Thanks everyone for your responses!!!!
I mY go back to riding sewups. Lol
Bikemig is right on the money; the Kool Stop tire jack is the greatest tool for tough tires. I don't know why it doesn't get more recognition. It makes a horrible job easy. After you use it, you'll realize tire levers are the wrong design for mounting a difficult tire.
Likes For ljsense:
Ride, Wrench, Swap, Race
Quoted: 1554 Post(s)
Liked 1,274 Times
As canklecat mentioned, lubricating the tube and tire with powder really helps. It allows the bead to slide and thus stretch more along it's entire circumference, so the slack can be more easily concentrated toward where the lever is working.
Now tires can be quite grippy against the rim surface, so will benefit most from bead lubrication.
Sometimes you just have to pinch the beads in all the way around the tire as the tire lever is pulling, but the tension has to be maintained or the bead may slide back in the wrong direction and take the slack back up.
Quoted: 1924 Post(s)
Liked 1,954 Times
It's the rims and not the tires. I freed a pair of nice hubs along with 64 spokes from some Matrix rims that were way too much work.
Liked 927 Times
Cheers
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
But at least the tire's on. So when I see (by squeezing the two beads together all around the rim, starting with the last segment to mount) that the tube is herniated out from under the bead, I slip a tire lever under the bead to one side of the visible tube and elevate gently. Sometimes the herniated tube reduces spontaneously. Usually it doesn't. So I give a couple of squirts of air with the pump with one hand while keeping the bead elevated with the other. (A floor pump works better for this than a frame pump but the latter will work if the wheel is braced against a tree or some such to free both hands.) Invariably, the tube retracts back inside the bead as it rounds up -- it's the elevation of the bead away from the rim floor that allows it to do this. Then remove the tire lever and check all around the rim again for any more hernias. Inflate and ride.
On a particularly difficult rear wheel I replaced an old Campanolo aero rim with a DT Swiss rim of the same effective rim diameter -- sorting the SpocCalc rim database by ERD helped find it -- and life has never been better since. I ordered two rims but, oddly, the tire came right off the front with no difficulty. Intrigued, I tried to remount the tire and pop, went right back on. So I left it intact.
I don't like to leave a tire on a rim that I needed tire levers to mount. Will I even be able to get it off (much less back on) to fix a flat in the rain when my hands are cold?
Quoted: 649 Post(s)
Liked 453 Times
I've experienced this with new tires from time to time. I read (on this forum I think) to leave them out in direct sunlight and try again. Makes a ton of difference (provided you have a source of warm, direct sunlight).
FWIW, I've never had an issue taking a tire off that was difficult to get on.
FWIW2, I prefer snap-on rim strips to tape these days. I've had really good luck with Specialized's strips. Nashbar's are a bit wide but still work ok. Giving Ritchey a try on my current build.
Liked 1,274 Times
Could be that you let just a bit too much air out of the tube before prying on the last section of the bead(?).
I usually count on the tube having some shape to it to prevent the tube from getting trapped, even with tubes that are rated larger than the tire size.
I find that it can be difficult to dislodge a trapped tube, so I slap the deflated tire a few times away from the side with the trapped bead, which usually moves the tube back in.
I think it's partly due to the shape that tubes come out of the box that leads a deflated tube to migrate to the wrong places.
Quoted: 297 Post(s)
Liked 245 Times
I'm going to try your more judicious approach with my next puncture. Thing is, ever since beer in cans replaced beer in deposit bottles here -- the beer that gets sold to be drunk in moving cars at least -- there is very little glass on the roads and punctures don't happen often enough to keep one's technique sharp.
Liked 2,798 Times
Cheers
Cheers
But there are bound to be just enough differences in rims to make some tires easy and others a PITA.
I've also noticed most tires get easier to mount after a couple of flat repairs. My best guess is the friction burnishes the rubber over the beads and scrapes off the mold release, so it's easier to mount.
