Broken Spoke
Broken Spoke
Old 10-19-19, 08:09 AM
kingston
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1759 Post(s)
Liked 488 Times in 313 Posts
Broken Spoke
I bought a used Velocity A23 Pro wheelset a few years ago and have ridden them I would guess 5-6k miles. The front wheel is 20 spoke radial lace and one broke at the nipple this morning. Should I replace just that one spoke or get a new set of spokes and start over? Also, I noticed that Amain bought Dan's Comp. Wonder if that means the days of 60¢ double-butted spokes are coming to an end.
kingston is offline
Old 10-19-19, 09:01 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
Dan's comp still lists 14/15 gauge butted Sapim Stainless spokes for 60 cents (with nipple, apparently!).
First, I'd inspect the existing spokes to see if the nipple comes out of the rim in line with the main part of the spoke. That is, are the nipples canted, with the spoke bending a little? If so, I'd buy new spokes.
If not, I'd buy a few spokes and fix the one. May be an abberation or an off spoke. If you start popping more in 100km or so, replace all.
WizardOfBoz is offline
Old 10-19-19, 11:17 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
I'd buy 2-3. 1's a fluke.
If you use them all in relatively short order, wish you's bought 17 more.
Actually $12 for the whole wheels worth really might be worth the peace of mind.
Fix it once?
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 10-19-19, 02:29 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Did it break through the spoke threading? If the spokes aren't at least coming up to the screwdriver flats in the nipples, I might get the replacements a bit longer.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 10-19-19, 02:52 PM
berner
Quoted: 663 Post(s)
Liked 496 Times in 299 Posts
Fix it once?
This seems like good advice to me. I always imagine that if and when thing go wrong, I'll be 30 miles from home and there are lightening flashes on the horizon.
berner is offline
Old 10-19-19, 03:37 PM
Bill Kapaun
Good point!
You can examine the current spoke length in situ in relation to the bottom of the screwdriver slot.
Ideally, you want the spoke end flush. (With a double wall rim, I'll round up a bit more generously.)
You can "adjust" to the correct length if needed.
IF you respoke the whole wheel, buy a spare or 2 to keep the evil spirits away.
I dropped a wheel I'd built into an old fashioned sewer grate about 20 miles into it's life. about 3 years later I had the "button" pop off the J bend.
You could see a "flaw", but I don't know if it was a bad spoke or damage from the incident. LBS's here don't carry butted spokes......
Someday, when I buy spokes, I'll replace the straight gauge oddity that I had to use.
Old 10-19-19, 06:13 PM
kingston
Jedi Master
kingston's Avatar
The spoke broke off a mm or so into the nipple so probably the last thread. The ends of the spokes are flush with the bottom of the slot, so I don't think I'll go longer, but I do agree with others that I might as well just rebuild the wheel with new spokes. It's not that expensive and winter is coming so I'll have the time. I used these wheels on several brevets this season, so I'm glad the spoke broke 15 miles from home. Could have been worse.
kingston is offline
Old 10-19-19, 06:22 PM
ThermionicScott
On the plus side, radial wheels are easy to build/rebuild, and you needn't take it completely apart. You can just replace one spoke at a time.
RUSA #7498
Old 10-19-19, 07:00 PM
Bill Kapaun
Are you in a salt air/humid environment?
Maybe a victim-
SSINA: Stainless Steel: Corrosion
Old 10-19-19, 07:30 PM
kingston
Jedi Master
kingston's Avatar
I'm in the suburbs of Chicago and bought the wheels from a guy in the city, so no salt air.
kingston is offline
Old 10-20-19, 12:57 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
Replace the broken one and order a couple of spares and tape one to a seat stay and carry a spoke wrench. If more spokes break then it is time to replace the rest.
I am not a fan of boutique wheels with low spoke count, but to each his own.
davidad is offline
Old 10-20-19, 01:12 PM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
Well, Chicago is on a major body of water and has cold winters during which the city undoubtedly uses salt to keep the roads clear. If those wheels were used in late fall, early winter, winter or early spring they were exposed to copious amounts of salt
alcjphil is offline
Old 10-20-19, 03:03 PM
kingston
Jedi Master
kingston's Avatar
Good point. As long as I'm ordering spokes, maybe I'll just get them for both wheels.
If the failure mode is the same, I would need to pull the rim strip to replace the nipple. Something I'd prefer not to have to do on the side of the road when I'm trying to get a ride in, so I've decided to replace all the spokes.
I agree. They seem to be more trouble than they're worth. I already have a lot of high spoke count wheels and thought I would take a chance on these. They were holding up pretty well for a while, then the NDS spokes on the rear started going loose, so I had to fix that, now the broken spoke on the front.
kingston is offline
Old 10-20-19, 09:24 PM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 533 Post(s)
Liked 312 Times in 236 Posts
https://www.wheelfanatyk.com/blog/sp...-getting-real/ is a thoughtful article on spoke breakage.
I'm inclined to chalk a single spoke breakage as a fluke and do a quick spoke replacement. If more than 2 go then I'd replace the wheel, generally speaking. If rebuilding your wheels sounds like a pleasant way to spend part of a winter afternoon, more power to you.
cpach is offline
Old 10-21-19, 07:54 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
If you're up to to spending the time, by all means rebuild the wheel. I would give a lot of thought to lacing with a 2-cross pattern, though.
If this were my wheel, however; I'd just replace the single spoke and let the future decide whether that was the right strategy. You can always rebuild later, right?
Moe Zhoost is offline
Old 11-02-19, 07:30 AM
kingston
Jedi Master
kingston's Avatar
I finally got around to measuring my spokes today and see that Dan's Comp no longer sells spokes and has the same crappy website as Amain/Performance/Nashbar. Thanks Amain.
kingston is offline
Old 11-02-19, 09:36 AM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 837 Post(s)
Liked 1,258 Times in 663 Posts
they do salt the roads in Chicago and it takes some time to wash it down after the spring rains.
Suggest you go see Marcus at Yojimbo's Garage, he's a wheel and spoke guy, he'll sort you out. Take the wheel with you.
1310 N. Clyburn Ave, Chicago. https://www.yojimbosgarage.com/ Recommended !
Mark Petry
Bainbridge Island, WA USA
mpetry912 is offline
Old 11-02-19, 10:39 AM
kingston
Jedi Master
kingston's Avatar
Thanks for the suggestion. It's not that convientent for me to get to the near-north side, and I can get replacement spokes from rose for under twenty bucks so I'll probably just do that.
kingston is offline
