25.4-26.4 handlebar shim?
^that guy^
Bought a new bar for the Bianchi but having trouble with slippage. 25.4 VeloOrange bar with Cinelli 1E stem which im guessing is a 26.4. Is there a shim out there that'll work? I've tried an aluminum can but it slips still. I have a SR Custom stem that'll work but it's not nearly as good looking as the Cinelli.
Quoted: 4493 Post(s)
Liked 6,295 Times
They make dedicated ones but you can go to the "real" hardware store or hobby shop and get some brass or SS sheet in that thickness.
It needs to be only one piece for no slip, clean all parts with acetone, alcohol or brake clean, any residue can undo the process.
Quoted: 1136 Post(s)
Liked 649 Times
Aluminum cans are usually only about a tenth of a millimeter or so in thickness. You need a full millimeter up but with the can you are only getting about a fifth or a quarter of a millimeter.
I don't see any 25.4>26.4 shims available for handlebars, but it is a common shim for seatposts. You could buy one of these and saw it down to size. https://www.ebay.com/itm/Bicycle-Sea...4383.l4275.c10
The best solution is to use a 25.4mm stem.
Quoted: 1820 Post(s)
Liked 3,324 Times
Nitto makes a shim specifically for this purpose. I'm sure it is available from a variety of sources, but here's a link to Rivendell's site:
https://www.rivbike.com/products/nit...-to-26-0-16095
Steve in Peoria
Steve in Peoria
Liked 649 Times
Steve in Peoria
Steve in Peoria
Liked 3,324 Times
^that guy^
I said screw it and just used the Custom stem.. I'll keep the Cinelli stem paired with the Cinelli bar
Likes For ceelint:
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
The no cost method of making this bar and stem combination work is find a standard Coca Cola can and cut 5 shims 33 mm wide X 78 mm long, stack them and inset them between the bar and stem clamp.
Math...
33 mm is the width of my Cinelli 1A clamp
The circumference of 25.4 mm is 79.8 mm (we subtract 1.8 mm so the shims dont butt when compressed = 78 mm).
The gap your trying to fill is 1 mm total = 0.5 mm for 1/2 diameter, = 5 layers of 0.1 mm shim.
Technique...
Use a wedge to slightly spread the Cinelli clamp co you can easily install the shim pack and get everything positioned correctly.
Materials...
The thickness of a Coca Cola can is 0.1 mm
Tools.
Scissors.
Small smooth prying tool.
Cost: $ 0.00
: Mike
Math...
Technique...
Materials...
Tools.
Scissors.
Cost: $ 0.00
: Mike
Booyah Hubba-Hubba!!!
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I dunno the exact sizes, but I just bought a shim like this last month, at a bike shop in Peoria, AZ. I don’t remember the exact cost either, but I want to say $5. Well worth it, to get a nice tight fit. 👍
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 111 Times
This should be pretty close.
https://www.homedepot.com/p/M-D-Buil...6072/205058572
I would disregard the thickness specified on the website. 28 gauge should be right around 1/64", 0.0156", 0.4mm. If necessary, add a layer of pop can.
For that matter, if you have any furnace or dryer duct remnants lying around, the thickness might be in the ballpark as well.
Likes For old's'cool:
Bikes: too many
Quoted: 411 Post(s)
Liked 233 Times
https://www.lowes.com/pd/Amerimax-Al...E&gclsrc=aw.ds
this might work to cut a shim from, and it's aluminum, like the bars and stem. and cheap. if you have a micrometer, are cheap like me, and have the time, take your micrometer to the local hardware/home improvement/local gutter installers and take measurements till you find something that works. (aluminum shim = not having to worry about dissimilar metal corrosion).
Likes For uncle uncle:
Ride, Wrench, Swap, Race
Quoted: 1554 Post(s)
Liked 1,273 Times
Slippage at the clamp is dangerous and was not uncommon during the ~26mm bar clamp days.
Pop cans (most cans, actually) are poly-coated on both sides, and this greatly affects the surface coefficient of friction. The coating can be sanded off easily.
Larger-diameter beer cans like Fosters are necessarily made of thicker aluminum, so if you have a caliper you can determine how many fewer layers/wraps are needed.
I have a screw-top can of nitro-brewed coffee here that is made of some thick aluminum, no way you could crush this can easily!
Bikes: too many
Quoted: 411 Post(s)
Liked 233 Times
Quoted: 4558 Post(s)
Liked 2,798 Times
Add some Park SAC-2 grip compound. Essential for carbon fiber and useful for aluminum too. I use it on carbon fiber, aluminum and even bits that use plastic shims that still slip without excessive bolt torquing or the grip paste.
