Go Back  Bike Forums > Bike Forums > Utility Cycling
Xtracycle LT2 U Tubes on newer Big Dummy?
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Old 03-22-20, 04:12 PM
bark_eater
Quoted: 753 Post(s)
Liked 737 Times in 422 Posts
After a bit of an Alien abduction, I am getting back to putting together the Big Dummy I picked up last year. I thought I would be rideing it last summer and bought a bunch of Xtracycle parts to put on it. I was assured that I would figure out how to get the LT2 U tubes to work on the newer Big Dummy , but the folks I bought the stuff from demurred as exactly how to to make them work together and which company's warranty to violate first. Any ideas?
bark_eater is offline
Old 03-26-20, 10:54 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,629 Times in 933 Posts
Link to assembly pdf from this Extracycle web page.
Also on the above web page is this compatibility guide. It's a pdf.
Car dependency is a tax.
base2 is offline
Old 03-28-20, 09:18 AM
bark_eater
Quoted: 753 Post(s)
They are listed as incompatible. I think I've got a solution that avoids drilling extra holes in the frame.
Old 06-24-20, 10:27 PM
emailsfh
car dodger
Bikes: 2007 Moots Vamoots SL, 2007 EAI Bare Knuckle Fixed, 2014 Surly DT, 2019 Surly Big Easy | Wife's: 2008 Specialized Ruby Elite, 2014 Charge Plug 3, 2014 Mercier Kilo Fixed | Son's: Strider, Weehoo, Woom2, Islabikes | FOR SALE: Roark Ti
Quoted: 25 Post(s)
Would love to hear what you came up with. I'm looking to do the same and just ordered the LT2 tubes. Can you tell me if the LT2 holes line up with your frame?
emailsfh is offline
Old 06-25-20, 03:35 AM
bark_eater
Quoted: 753 Post(s)
I drilled through both sides of the LT2 and tapped for 6mm. If I was doing it again I would find a set of Hooptie rails and do the same. The LT2 ends up narrower than the Hooptie I have mounted on top.
Old 06-25-20, 07:26 AM
emailsfh
car dodger
Quoted: 25 Post(s)
So what exactly is the fit issue? That the holes don’t line up before it hits the dummy foot rest in the frame (that’s what I read in a few places)? How far in from the end of the LT2 did you end up having to drill?
emailsfh is offline
Old 06-25-20, 07:45 AM
bark_eater
Quoted: 753 Post(s)
Rear holes line up with rack at maximum extension marks. Rear hole is oval, so need to drill all the way through to tap the far side. Front was spotted at same extension and drilled and tapped. High strength loc-tite was used on bolts. New hole is 3/8"? farther in on LT2
Old 06-25-20, 07:14 PM
emailsfh
car dodger
Quoted: 25 Post(s)
Do you have any pics? Sometimes it’s hard to visualize. Also what year Dummy is this?
emailsfh is offline
Old 06-30-20, 06:38 AM
bark_eater
Quoted: 753 Post(s)
I think its a 2017-18. Pictures will show a bolt head and washer. Its all locktited together, and I have no plans to take it apart, sorry.
Old 06-30-20, 09:25 AM
emailsfh
car dodger
Quoted: 25 Post(s)
I just wanted to see how far in or out the u-tubes sit on your frame, if any of the holes show, etc. No need to disassemble.
emailsfh is offline
Old 07-02-20, 03:44 PM
bark_eater
Quoted: 753 Post(s)
The second max inset line is is still in the frame. I'll try and get a picture,
