Strava estimated power vs. indoor power??
Let's not get into that trope.
If you bothered to look at the link to his rides, he rides outdoors plenty. Not everyone can ride outdoors 100% of the time all year round.
Looking closer at the rides also, seems he's on a good start on Trainerroad. Just keep with it. If anything, I would figure out how to ride the outdoors rides when it is a little cooler and focus on holding the Z2 power on the longer rides. That heat on those looks oppressive and might be bringing down how productive those rides are.
Likes For showlow:
Takes a lot of work to get fast, a lot of self-flagellation, self-loathing, and questioning of your purpose and existence as you struggle to eek out one more 5 minute repeat....
And then, once you get fast, inevitably you want to get even faster, so it never really ends... You kind of come to terms with it if you're lucky.
Frustration comes from, despite all that, being pretty mediocre, especially on longer rides.
Quoted: 942 Post(s)
Liked 526 Times
As others have said, it is a calibration issue. I have a friend who was doing 400+ watt indoor rides on a snap. Come to find out never checked tire pressure and the tire was very lightly on the roller. Also never did a spin down. Once made aware of tire pressure, how to properly attach the bike, and performing spin downs....watts are now normal.
Quoted: 942 Post(s)
Liked 526 Times
Since you are comparing indoor and outdoor power, have you ever tried going all out on an outdoor ride? Power meter will definitely let you know what you are doing outside.
If you have an FTP of 296 averaging 20+ mph on a solo outdoor ride on relatively flat terrain should be no problem.
Well if you routinely check your tire pressure (I can't remember what Wahoo recommends, I think 100 psi or something) and the bike is attached properly (appropriate amount of turns on the knob IAW instructions) and you do spin downs, then your watts should be in the ballpark.
https://strava.app.link/sTVyZOhZR8
Quoted: 942 Post(s)
Liked 526 Times
Only once have I ever gone over 20mph average. Might have been the wind that day. Totally flat ride. If I go all out outside it tends to be on segments that take 10 mins or less.
I weigh about 175 or so. 6ft tall. I was riding a high quality steel bike from the 80s with modern parts. Prob about 20lbs for the bike. Used to weigh as little as 165 in my salad days, but I have no data from that time period. No idea if I was much faster then. Avoided Strava in those days for this very reason. Knew if I opened the worm can it'd become an obsession. Well, here I am now, officially obsessed. About to pull the trigger on the power meter.
Likes For showlow:
Likes For jadocs:
Quoted: 6177 Post(s)
Liked 4,794 Times
burnthesheep It was a serious question. I don't feel that riding a trainer indoors and riding a bicycle outdoors are the same thing. Several times I've actually met young people claiming they have no time to ride outside and all they do is ride a trainer indoors for many hours. When going outdoors for a few times they wonder why they can't perform like they did on the trainer.
Don't get me wrong, trainers are very useful, but for conversational purposes it'd help to know which is being talked about.
Yes. There are many questions that can only be answered by a power meter that resolves the contribution from both legs (which doesn't necessarily require a two-sided meter). You may or may not care about answering those questions.
Likes For showlow:
No, don't care. Only concerned with power.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Do I understand correctly that you calibrate your trainer, which has a built in power meter, and you've done a recognized FTP protocol (TR ramp test), and you now have your FTP. You're questioning that number because your one hour power on a hard ride is less than your FTP. Do I understand correctly?
Very few people can actually ride their FTP for an hour in anything less than a high level competition under controlled settings (i.e. hour record, time trial, etc). If your ftp is roughly 300 watts, and your rides (even the hard rides) show an estimated average power in the low 200s, the estimated power is probably pretty close. Most riders spend most of their time riding at 50-80% of their FTP.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Strava has never estimated 200w for me avg on an entire ride. Think the highest I've ever seen was 171.
Quoted: 672 Post(s)
Liked 417 Times
If that's the case, your FTP is your FTP, within the margin of error for your trainer (likely within 2% or less). This is especially true if you're using TR to train, and will be using your trainer and TR for your structured workouts.
FWIW, My bike has a power meter. I know my FTP and have an accurate measure of every ride I do. My rides nearly all have averages of 50-80% of my FTP. It's just nearly impossible to go at 100% for an uninterrupted hour.
In my experience, Strava estimated power is roughly as good as a power meter with a wider than normal margin of error, assuming it has accurate weight info. BUT - and this is a big but - it is much closer when looking at your average power over an entire ride than it is for a specific segment or smaller increment. Trying to use estimated power for intervals or segments invites a lot of error. Better to either just use RPE or invest in a power meter, IMHO.
BB
BB
BB
BB
Likes For showlow:
Quoted: 1027 Post(s)
Liked 325 Times
Strava's power estimates are terrible. It doesn't account for wind, road surface, position on the bike, clothes you're wearing etc. I wouldn't take those very seriously.
Having said that, your trainer could also be off. And, as others have said, it's often very tough to ride near your FTP for an extended time out on the road. You'll find that you coast a lot like turning corners, rolling up to red lights or stop signs, going down hills etc.
Version 7.0
Bikes: Too Many
Quoted: 1338 Post(s)
Liked 2,474 Times
Let me offer another aspect of cycling to obsess about...making every pedal stroke count.
When I go to the gym (when they are open), I make every rep count. What happens then is I rest. I may chat with someone, think, listen more closely to my music or what ever but my brain takes a break and my muscles recover. Then another set and I make all reps count. As the sets progress, I get tired and the reps on the final set feel much harder than the reps in the first set but I do not lose mental focus.
When I am on the bike training, I try to make every pedal stroke count for the goal of the interval or whatever and independent of terrain, wind and other distractions but of course putting safety first. Making every pedal stroke count at 80-100 rpm is mentally draining. So even if I have the physiology to complete a workout at a given power, I may not have the mental focus.
IMO, mental focus trumps physiology. So unlike the gym, where there is a lot of rest and brain downtime, there is little brain downtime cycling if you want to hit power targets.
IMO, that is why I find aerobic training harder than gym training. I never miss a gym target unless I am completely wasted but it is quite easy to miss power targets on the open road. I lose mental focus or I do not like the distress feeling in my legs since my brain knows I have but yet another, for example, 30 minutes to go and the feeling is not going to get better but worse.
On the trainer, it is easier for me to hold mental focus but the trainer feels harder to make power for the same level of perceived effort. Hence, my ability to hold constant power is better on the trainer albeit at a lower power level assuming I am not bored to death. That effect may vary from person to person and if I ride the trainer a lot, I get closer to the road. YMMV.
Comparing indoors to outdoors, without power feedback, it is easy for me to rest a couple of pedal strokes outdoors and speed will seem okay and HR seems okay but I am decelerating. Strava will pick that up as a speed change to the negative and lower power.
Likes For Hermes:
Liked 325 Times
FWIW as a point of comparison, Strava would estimate ~115 watts on my commute. Riding at roughly the same effort,but on my bike with the PM, I'd average ~185.
Likes For OBoile:
Liked 325 Times
Likes For OBoile:
Quoted: 942 Post(s)
Liked 526 Times
I hadn't really thought of this before, but totally I experience this too. If I'm with other people, my power will generally stay high as I'm focused on keeping up. But, when I'm by myself, it's very easy for my power to drift downwards without me really noticing. Then I check my PM, see it's low and pick it back up. But, as soon as I'm not looking (i.e. paying attention to the road) it starts to go down again. Next time, I'll try to specifically concentrate more on my effort with every pedal stroke and see if that helps.
