Catapulting Disc Brakes
Quoted: 3777 Post(s)
Liked 1,047 Times
I've been riding for over 30 years and have yet to try out the relatively new Disc Brakes. In the early years I catapulted over the handlebars on at least two occasions and nearly catapulted at least two other times, before it became instinct for me to squeeze the rear brake first.
I'm curious how easy is it to catapult using front disc brakes (compared to traditional brakes)? I'm wondering if my current methodical use of traditional brakes, where I brake first with rear brakes, then employ the front brakes would smoothly cross over to use of disc brakes.
(I guess this question is best for riders that rode many years with traditional brakes, that recently have transitioned over to discs).
Quoted: 6972 Post(s)
Liked 10,968 Times
Depending on the rim brakes you're using, disc brakes may be a little more powerful (mechanical discs) or much more powerful (hydraulic discs). As with anything, it's simply a matter of becoming accustomed to them. But yeah, starting with the rear brake, and then applying the front, will be a good starting point.
Quoted: 576 Post(s)
Liked 1,003 Times
The harder I brake, the more I put my butt behind the saddle and stiffen my arms. Standing on pedals lowers your center of gravity and makes it much harder to do a Superman
Likes For DorkDisk:
Liked 1,047 Times
I forgot to mention that as one of my methods of braking is to put my butt as far back as possible. However, I usually only do that on very quick stops, but I still hit the rear brake first. So I'm not sure how that (shifting my center of gravity) would works with a fast stop using front brakes at speed (over 20mph).
Likes For work4bike:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Any brake worth a poop will throw you over the bars if you squeeze hard and don’t lean back some.
None of these brakes in and of themselves are more likely to do so than others. For ALL brakes it is a matter of getting used to the way they react to lever action.
Many people will argue that brakes with better “modulation” are less likely to throw you OTB or skid, but then argue for pages over what better modulation actually means.
I like powerful brake that stop me with less lever pressure and movement. The trick is to do a lot of practice hard stops to learn how the brakes react to lever input.
Likes For Kapusta:
Liked 1,047 Times
I'm not faulting disc brakes for being a kickass catapulting mechanism. I'm just wondering if other riders (with many years of riding) that have switched over from traditional brakes have had to change how they prevent the catapulting.
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
If you suddenly grab a handfull of brakes and squeeze as hard as possible, yeah, hydraulic disks will throw you a** over teakettle. But it's the same thing as any other brakes - good brakes need to be used correctly. I don't know that you need to do the rear first - I don't - but if it works for you, go ahead.
Quoted: 643 Post(s)
Liked 1,526 Times
You need to learn about proportion. I've never come close to catapulting with any braking system and can't even imagine how you could do that other than in a severe panic situation. Don't squeeze any harder than you need to to slow at whatever rate is required.
Any Harley rider care to explain how using the front brake causes you to superman.
It's all about center of gravity and the speed of the weight transfer. If your center of gravity is high, and your weight transfer is fast (because you didn't prepare your body in anticipation of the braking), then you WILL fly over the bar.
But if you prepare yourself, then you can brake as hard as your brake can allow all the way up until the point of lockout (assuming a straightline and dry condition) and you will never go over.
NOTE: going in a straightline on dry clean pavement, it is virtually IMPOSSIBLE to lock the front wheel.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
A good front brake should be strong enough to lift the rear wheel. Most decent disk brakes I've ridden can do that with 1 or 2 fingers on the lever. Adjusting to good brakes is easy, they are almost telepathic. Going back to cantis or calipers for a ride or 2 can be frightening until you remember to squeeze like you mean it.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I have yet to be catapulted by a bike or anything for that matter. If I have an issue of braking it is usually just a matter of knowing how to brake and making sure I am not just grabbing a fistful of front brake.
On casual level JRA Bikes with V brakes they have supplied a "modulator" .. your cable housing pushes down a spring in the 'noodle'..
that softens the initial bite ..
with disc brakes the modulation is a skill .... + basically some calipers better than others ..
I swapped the front Avid BB7 for a TRP Hy Rd, it's internal hydraulics, don't come on as abruptly as the ones that came on the bike..
still cable operated..
One option : Anticipate the need for heavy braking a couple second before hand,
push your butt back , low off & behind the saddle I brace your straight arms against the forces.. of that deceleration..
Liked 1,047 Times
Boy, I just love all the freakin' exerpts on this website
Liked 1,047 Times
Quoted: 1034 Post(s)
Liked 1,290 Times
Huh? As someone who mainly rides motorcycles instead of driving a car, what exactly are you implying? Are you saying to not use a front brake on a motorcycle because it will catapult you over the bars? If so you are so far off base it isn't even funny, especially on a Harley.
Likes For phughes:
Liked 1,047 Times
BTW ALL, the reason I'm asking the question is because I'm in the market for a new bike and I'm seriously considering disc brakes, simply because of the stopping power (I've heard of) during wet conditions. Can't tell you how long it took me to develop the skill of riding with virtually no brakes in the rain.
I didn't go 'over the bars' , but i did have the bike stop short, , I kept moving,.. I was going slow , then..
I put out my hand , to catch myself.. as I hit the sidewalk, that did not help my wrist ..
Liked 1,047 Times
There are a few accidents I had when I first started cycling that still pop in my head while riding today. Front brake is one of them, but the other is when I accidentally veered off road and immediately swerved by onto the road and as my front tire hit the raised lip of the road, I went flying into the middle of a two lane roadway where cars are going at least 50mph.
I don't know how, but I instinctively jumped up, grabbed my bike and ran out of the road before the car behind could hit me -- one of those incredible times in your life.
That was back in the mid-80's and to this day, every time I start to veer off the road, an image of that accident jumps in my head.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I find that most disc brakes are much easier to modulate than linear pull "v-brakes." Many powerful rim brakes have an on/off feel rather than a good amount of middle ground feeling. You have to pull a disc brake hard to lock up a wheel and there's a fair degree of modulation before that.
Quoted: 668 Post(s)
Liked 529 Times
Have to wonder just how experienced of a rider you are if you are honestly worried about braking sending you over the bars. You sound like the people on the recumbent sites.
Been riding 50 years and have had absolutely zero issues transitioning to disc brakes. In fact, a good set of hydro discs have better modulation than some of the older brakes giving the rider considerably more control over braking force.
Quoted: 325 Post(s)
Liked 109 Times
I did a true superman impersonation. I'm sure it was entertaining to the "spectators".
The one and only time I've ever gone over the bars was when a stick went between my front wheel & fender, causing the fender to snap and lock up the wheel went it went under the fork crown. In that crash, I managed to instinctively tuck my chin and land on my shoulders and upper back, my head never touched the ground. Other than needing to replace the fender, there really wasn't much damage to the bike at all, and I only had some minor abrasions and a few bruises.
Quoted: 4806 Post(s)
Liked 3,931 Times
I choose brake power considering how I ride. I grew up and learned on the ancient centerpulls, raced side-pulls, got introduced to driving on a Willis Jeep nearly as old as I am, and I was 34 years old before I drove a car with power anything. The instinct to squeeze hard is embedded in my reactions, At 67 , I am not re-training them (unless I am willing to do several flips over the bars). I very intentionaly stay away from powerrful brake combos. (My brakes are very good stoppers. They just require a real squeeze.)
I haven't made the jump to disc and probably won't Dual pivots work way to well for my hands so I "de-tune" them with V-brake levers. (LIkewise cantis.) They still stop me really well, but it now takes the real squeeze I've been doing all my life. Since I swapped out the levers, I can stop in a much shorter distance because I don't lock up or have to back off to keep the rear end in line.
I have had the same issue with my cars. Power brakes just keep getting more powerful, more sensitive. Hard stops, instead of getting better, have gotten worse, until my last car with (finally) ABS, After 7 years, I still need it. That old Willis and my first car, a '71 VW bus, taught me really well.
Ben
Ben
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
One person in the class had a bad habit of grabbing a handful of front brake. She high-sided twice during the weekend - no kidding.
Not suggesting that's what happened, but it's something to consider at least.
Glenn
Liked 1,047 Times
Very helpful input, thank you!
Liked 1,047 Times
re-read the post, this happened back in the 80's when I was in my 20's and first starting out in cycling as transportation. The only bikes I rode before this was when I was a kid and used the old pedal-braking bikes.
