Fuel resupply - white gas
#52
Quoted: 3459 Post(s)
Liked 1,465 Times
The list of alkanes in Coleman Fuel is C5 to C9 hydrocarbons. Although not listed, it probably contains hexane as well, not that it will make much difference. Mineral spirits has alkanes of C6 to C10. Lighter fluid is in the same range. Kerosene is more in the C8 to C12 range.
#53
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
It would be good to know if petroleum based lighter fluid (e.g. Kingsford) is acceptable in MSR stoves using the kerosene jet, since Kingsford in common in the US. Some lighter fluids have an alcohol component which would likely make them unusable. Other impurities in petroleum lighter fluids may cause problems, perhaps more so than auto fuel. I have contacted MSR in the past about this since I would like their engineers to chime in on this, but no reply. I have always been able to find white gas and especially so in Canada on months long tours. However, in recent years, it is more difficult to find. When you ask younger people at campgrounds if they could spare a cup or two, they have no idea of what white gas/coleman fuel is. I understand people like the simplicity of butane canisters, but I feel it is wasteful.
#54
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
The list of alkanes in Coleman Fuel is C5 to C9 hydrocarbons. Although not listed, it probably contains hexane as well, not that it will make much difference. Mineral spirits has alkanes of C6 to C10. Lighter fluid is in the same range. Kerosene is more in the C8 to C12 range...
I remember some 30+ish years back when I ran a GC (gas chromatograph, I'm also a chemist, pre-retirement) on a sample of Coleman fuel and 87 octane gasoline. I wasn't happy at the time at the price of coleman fuel, given my experience growing up of buying white gas at a gas station out of a pump. Since I had the equipment available, I figured I'd take a look. The chromatographs were distinctly quite different. Most of my curiosity was to find out if coleman was selling regular gas at a premium, and then some, price. I continued using coleman fuel..
#55
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
No. I’m a chemist who has spent a career looking at alternative fuels from biomass. That requires a lot of knowledge about (unalternative?) fuels since we want the same, or similar, results from the alternatives. I also took some graduate classes in catalysts which are heavily targeted towards petroleum.
I suspect that the gasoline had a lot more BTX (benzene/toluene/xylene) in it than Coleman fuel. Depending on the season, it may have had more butane and pentane (winter) than Coleman as well. The butane and pentane are added to increase volatility in cold weather. It’s removed in the summer to keep the fuel from vapor locking. Today’s fuel would also have ethanol in it...about 10%.
(No disrespect intended to cycco).. I believe cycco is a chemist, although this info is first-semester-level organic chemistry ("the Chemistry of Alkanes" chapter) and doesn't require refinery experience.
Stuart Black
Stuart Black
#56
Liked 1,465 Times
#57
Quoted: 759 Post(s)
Liked 810 Times
Likes For fishboat:
#58
FWIW, I dug out my old SVEA 123 and fired it up for fun. It might have been sitting for 30 years or so if my memory is correct. I am actually thinking of using it again. Maybe not for bike touring, but definitely for canoe tripping, but I was surprised how close it came weight wise to being competitive with modern stoves like my whisperlite when it came to weight. I had pretty much dismissed it as too heavy long ago, but it really is pretty close to the whisperlite and I like that it is super simple and super reliable.
So I am back to thinking about naptha fuels and alternatives. For canoe camping just buying Coleman fuel or some other alternative by the gallon is not only fine, but the best bet since I can typically just carry what I need for the whole trip from the start and not worry about resupply. If I were to use it for backpacking or bike touring there are all the naptha options as well as the possibility of burning unleaded gasoline in a pinch. If used over time gasoline has the disadvantage of gumming the stove up and it also has toxic additive, so it isn't a great option. That said used with care for a short while in a pinch it can be an option.
My preference for buying small quantities of fuel on tour or while backpacking or for using mail drops with small quantities might be well served by using the small bottles sold for wick type cigarette lighter (like the old zippos). Ronson and Zippo sell a variety of sizes (4, 5, 8, and 12 ounces) that might actually serve as my fuel bottle. Mailing fuel I prefer to use unopened factory sealed containers so these would be ideal. They'd be great for both filling and priming the stove from since they are designed for filling lighters. The drawback is that the little bottles would be expensive per ounce, but my usage is low and I want to carry only a little.
#59
Quoted: 18411 Post(s)
Liked 15,531 Times
Don’t believe it’s legal to mail flammable liquids.
#60
Liked 1,465 Times
#61
I think you have to follow the ORM-D labeling and packaging requirements. They vary with flashpoint and amount of the liquid. It is limited to surface and domestic mail only. It is very similar to mailing butane canisters which I have done.
https://pe.usps.com/text/pub52/pub52apxc_011.htm
#62
USPS does not allow flammables/corrosives since they use the airlines for mail transport over 200 miles. UPS and FedEx will, but they have restrictions on volume -- AND it would most likely be limited to ground transport.
#63
#64
aka Phil Jungels
Back in the 50s and early 60s, almost every neighborhood gasoline station sold "white gas", which was the common power lawn mower fuel back then.
IKNOW, i'M SHOWING MY AGE!
#65
Liked 4,217 Times
That was likely unleaded gasoline. It was not the same as what has commonly come to be called “Coleman fuel”. Coleman fuel has an octane rating of 50. I’m not even sure you could even start an engine on that fuel much less run it.
Stuart Black
Stuart Black
#66
I actually had a chance to test that out. We were out of gas in a dangerous situation back in the late 60s in a 6 cyl chevy van. We added a gallon of coleman fuel to the tank and limped some number of miles (10-12 maybe) to somewhere safer. It rattled, pinged, knocked, and shook, but it ran, barely. I thought it might die on the spot and I don't think it ever really ever ran well again after that. The van was already an old clunker at that time though.
#67
#68
It was during the Baltimore riots kicked off by the assassination of Martin Luther King, Jr. We were stuck in a spot where many of the businesses had been burned or looted the night before and a curfew was going to kick in soon. It really wasn't a time and place we wanted to spend the night in the van. We cut through town to get home. Everything was shut down including gas stations so no gas was available.
#69
Thanks stae, isn't that something, a discussion about camp stove fuel leads to this.
And how it makes one think of both the changes and similarities that have taken place in the last fifty years, camp fuels and otherwise, my emphasis on otherwise.
#70
Thinking back to those times made me reflect on the similarities and differences between then and now, but this isn't the place to discuss them.
#71
back on topic. In august, I was glad I found the large container of methyl alcohol I bought years ago, getting ready for a short trip. The local outdoor stores were pretty threadbare for so much camping stuff this summer, supply chain and so many folks trying camping during this covid summer.
cheers stae, take care
#72
Quoted: 1034 Post(s)
Liked 1,290 Times
In summary, white gas is not the same as unleaded gasoline, but, unleaded gasoline can be used instead of Coleman white gas. You can buy more bottles, or ask other campers for a small amount, offering to pay, or you can use unleaded gasoline. Alternatively you can throw in a stove that uses a different type of fuel.
Now, continue the riveting debate about details that do not change the reality of the options.
Likes For phughes:
#73
Liked 15,531 Times
Likes For indyfabz:
#74
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
I often ran my Svea on pump gas when I toured on my motorcycle in the late 60s-early 70s. I haven't done it, but other campers told me that one can drain fuel from gas pump hoses simply by putting your container down near the ground. Worth a try just to see. Gets around the whole fuel problem. The Svea is now a polished brass shelf ornament as I've switched to an Optimus
Results matter
Results matter
#75
also makes me remember that "Oh sh...t" feeling when you'd already turned the petcock to reserve the night before, then forgot the next day, and when the sputtering began you'd be slaloming back and forth to get the last dregs in the tank down the line.
Even my light Kawwy 175 enduro got tiring pushing it to a gas station.....
fun times those years
