How to deal with toe-overlap on switchbacks?
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400 // Santa Cruz Stigmata CC // Bridgestone MB-3 BoxTwo 1x Conversion // Bridgestone MB-6 // Santa Cruz Highball C // Ibis Spanky
Quoted: 67 Post(s)
Liked 19 Times
Hey everyone -
So I just got my first gravel bike (Scott Speedster Gravel 30 in 54cm (same size as my road bike) with 700x35 G-Schwalbe AllRounders) this week and I've done a few rides with it. There are a few trails near me that have some really tight switchbacks. I noticed that, especially going uphill, my toe hits my tire when turning at low speeds. It didn't happen as much downhill, but maybe once or twice.
How do I go about dealing with this? Is it due to cleat set-up? Shoes? (I'm using some old road shoes for now - don't have MTB/CX shoes) Technique?
Thanks!
Thanks!
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Go faster! Just kidding. I also have some TO on my 700c gravel bike (my 650B one is way better in that regard). Mine's a size 50 so it's pretty inevitable. Probably 70% of my riding is singletrack like you describe. It's just gotten kind of subconscious for me now--I unconsciously adjust tire to pedal relationship as much as one can at least(sometimes it's simply unavoidable). I expect you'll just adjust mentally the more you ride those tight sections. I ride flat pedals with pins and mtb shoes so I can move my feet around but honestly I don't really do that much in this case.
Likes For pbass:
Quoted: 427 Post(s)
Liked 339 Times
You can try and push your cleats up more towards your toes. And get used to an occasional contact. My touring bike has toe overlap and I have just become used to it.
Quoted: 67 Post(s)
Liked 19 Times
Quoted: 67 Post(s)
Liked 19 Times
The cleats are almost maxed out currently. I shifted them this morning to check but I still barely get a touch with the current setup. Thankfully, the cleat position is still comfortable - I did a 3 mile gravel climb at 8.5% average and I didn't notice any hot spots. Do you know if MTB shoes would be better than the old road shoes I'm using now? Are road shoes maybe more "pointy?"
Likes For speedyspaghetti:
Quoted: 284 Post(s)
Liked 313 Times
Quoted: 427 Post(s)
Liked 339 Times
I think MTB shore are more popular on gravel bikes, but I'd say the 'hot spot' issue is more related to the specific shoe than the shoe type.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Admittedly, I've never tested different cleat positions since where I have mine works. Is it really a non-issue to move the cleat around?
Quoted: 67 Post(s)
Liked 19 Times
Is there some sort of specific drill/training you would recommend? Or is there a better technique to uphill tight switchbacks I should be practicing? Admittedly, my lines aren't very/smooth, but I'm not sure what I should be practicing.
Quoted: 67 Post(s)
Liked 19 Times
Is one more "pointed" than the other? I ask because it's literally just the tippy tippy top of my toe that touches the tire on my road shoes.
Quoted: 576 Post(s)
Liked 1,003 Times
I've a 54cm road bike that I use on gravel with a bit of toe strike; its the only bike I have with 170mm cranks (normally 172.5-175), which helps minimize the contact to a tolerable rub. YMMV. Also, smaller tire helps, but I run the fattest I can squeeze in and don't like going that route.
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 358 Post(s)
Liked 122 Times
How much to overlap do you have.. ? if it's not that much toe overlap you can drop your heal in the back , which will give you more clearance, also there's the one where you could just pedal with one foot, depending on which side you're turning.
Likes For rossiny:
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
It's geometry. One of the things I like about my Revolt is that it has a longer front center, which makes it more stable, and as a bonus, has no toe overlap, even with big tires.
I noticed more contact with toe clips than clipless pedals. But I prefer toe clips on around town bikes than clipless.
It has fit consequences. The most immediately obvious is that it has a dramatic impact on leg extension (so changes to the fore-aft cleat position tend to require simultaneously changing saddle height), but it also changes how your leg has to brace itself for pedaling force. For instance, a farther-forward cleat tends to put more stress on the calf and heel because in increases the length of the "foot" lever; I gave myself an achilles tendon overuse injury last summer because my cleats were too far forward, it kept me almost totally off the bike for a couple of months.
Sunshine
Liked 7,491 Times
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
My bike has toe overlap but years of trail riding makes my sense of where I am in my pedal stroke something I don't have to think about. I always keep the outside pedal low and behind the bottom bracket in tight corners. Just pay attention, form some habits, and after a while it becomes second nature.
I personally would not adjust your cleat position to escape toe overlap and make sure your cleats are set up for your leg extension and pedal stroke.
Likes For KJ43:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I don't see how cleat position, adjusted for minimal toe overlap, is going to hurt anything. Yeah, you may have to change your seat height, but that's not a showstopper. I have my cleats all the way forward so that the pedal spindle is under the ball of my foot. I maximize power and minimize toe overlap.
But for the most part, I'm going too fast to get toe overlap (you just can't get that large a steering angle at speed). I do get some toe overlap on the tight turns of a CX race if I have a 700x54mm tire, but I just keep pedaling because it doesn't really impact anything under strong power.
How tall are you? You could move your cleats, increase the rake of your fork (if you don't mind more agile steering), make sure you have small shoes, go to tires with a smaller diameter. 650b wheel is probably the most effective mechanical change (if you don't mind the lower BB). If its a slow speed problem for ya, ratcheting the pedals, or just coasting through tight turns are two techniques that will work. But, if you are carrying your momentum and carving a smooth turn, you aren't going to get those steering angles unless it is a really slow tight CX type turn.
Quoted: 67 Post(s)
Liked 19 Times
Quoted: 590 Post(s)
Liked 445 Times
N+1 was my answer to toe overlap.
My Trek Madone had overlap that caused me to have enough low speed U-turning falls that the next bike I got had to have zero overlap, or it was a deal breaker. The Madone is now relegated to the trainer where it exhibits zero toe overlap.
Likes For Riveting:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Usually, toe overlap only occurs at a very specific point in the pedal revolution and a very specific point in the wheel's steering arc. Learn where that point is and practice getting your toes out of the way with a small backpedal. Cleats should be positioned to place the foot on the pedal in relation to your knees, not your front wheel.
Likes For Rolla:
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
Usually, toe overlap only occurs at a very specific point in the pedal revolution and a very specific point in the steering arc. Learn where that point is and practice getting your toes out of the way with a small backpedal. Cleats should be positioned to place the foot on the pedal in relation to your knees, not your front wheel.
Likes For KJ43:
Liked 415 Times
I'm about 5'9. I was using some hybrid road/mtb shoes but I just bought some MTB specific shoes which should allow a bit better cleat adjustment. I'll take a video of the turn next time I go ride it - it's really a non-issue on 98% of the rides I do, it's just these two turns on one of my favorite trails. I agree that I definitely need to work on skill / technique more. I think my line is also messy, resulting in me having to turn the bars at a much steeper angle. It's a short, almost 180 degree switchback that enters gradual and exits steep.
Yep, a 180 degree uphill turn is the type where you will have that problem.
I have a dozen bikes - but the only time I get toe overlap is with my track bike (which is designed to only go in a straight line), and when I put 54mm tires on my CX bike that is designed around 33mm tires. But I put my pedal spindle under the ball of my foot, so the cleat is basically as far forward as it will go.
