Shimano STX Shifter Problem
Quoted: 67 Post(s)
Liked 49 Times
I was having some ring gear shifting problems on my Trek 7000, so I tried to take the bottom cover off of the Shimano STX shifter to see if I could lubricate it. The bottom cover has a small phillips screw and allen bolt. The allen bolt was a little stiff, but never came off completely. I can't get to tighten now, either. The whole mechanism is now loose. I seem to be missing something here. Any pointers?
Quoted: 1438 Post(s)
Liked 1,092 Times
It sounds like the bolt or its mating threads may have galled or otherwise jammed. I would suggest trying to get some penetrating oil (Kroil or PB Blaster) in there and get the bolt turning again so you can tighten it up again.
Quoted: 1944 Post(s)
Liked 2,164 Times
John
Quoted: 67 Post(s)
Liked 49 Times
I sprayed it. The bolts just spins, even when I pry and twist at the same time. I'm not sure how to get the top from the other side off.
I found some old stock replacements, but should I upgrade to something like Deore XT ST-M760 instead?
Assuming front (left unit), is the shifter set to smallest chainring position? The interface between the shifter, brake lever bracket and the window gear indicator unit on some of these shifter must align to mesh together. This is in the small ring position (front) and small cog (rear).
Another possibility is that a part between the shifter unit and the indicator slipped out of place and no longer aligning properly.
Quoted: 4205 Post(s)
Liked 3,864 Times
IIRC this version of shifters have the center bolt threading into a Tee nut. The flange of that nut can slip out of it's fitting and thus spin, like a stripped bolt might. The bugger is that these can also have some sort of thread locker on the bolt and help make the loosening more challenging, especially if the nut is no longer held in place. One trick it to pull on the bolt while loosening it. Not easy to do with just the 4mm hex wrench but does work. This helps to seat the Tee nut and keep it from freely spinning. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 67 Post(s)
Liked 49 Times
Quoted: 67 Post(s)
Liked 49 Times
Here is the exploded view from Shimano.
Not sure if the attachment will load, so if not, try the Shimano web site directly. It is under Manual and Technical Documents.
Liked 2,164 Times
Quoted: 67 Post(s)
Liked 49 Times
I got it. I was able to grip the top nut with a needle nose pliers. The top nut spun in the housing, as the bolt was rusted. Now I need to put it all back together.
Liked 2,164 Times
Quoted: 67 Post(s)
Liked 49 Times
I got it together finally. Thanks for all the help.
It's too bad that I had to go through with all of that, but it happens. I see now that I could have sprayed lubricant through the side.
Years earlier that T nut wouldn't have spun in its housing, but the bolt and nut were rusted and the aluminum housing couldn't take the torque necessary to free the bolt.
